Which of the following objects has the greatest moment of inertia?
The discussion centers on determining which object has the greatest moment of inertia among a hollow cylinder, solid cylinder, solid sphere, and hollow sphere. The correct equations for calculating the moment of inertia are provided: hollow cylinder = 0.5M(Ri² + R0²), solid cylinder = 0.5MR², solid sphere = 0.4MR², and hollow sphere = (2/3)MR². It is established that the hollow cylinder's moment of inertia is greater than that of a solid cylinder, and when comparing a hollow cylinder to a hollow sphere, the hollow cylinder can have a greater moment of inertia if it is a thin shell, as its mass is distributed further from the axis of rotation.
  • Understanding of moment of inertia concepts
  • Familiarity with the equations for hollow and solid objects
  • Basic knowledge of mass distribution and density
  • Ability to interpret physical equations and their implications
  • Research the moment of inertia for various geometrical shapes
  • Learn about the impact of mass distribution on rotational dynamics
  • Explore the differences between thin-walled and thick-walled cylinders
  • Study applications of moment of inertia in real-world engineering problems
Students studying physics, mechanical engineers, and anyone interested in understanding rotational motion and moment of inertia calculations.
fatcat39
Hollow cylinder = 0.5M(R^{2}_{i}+R^{2}_{0})
Solid cylinder = 0.5MR^{2}
Solid sphere = 0.4MR^{2}
Hollow sphere = (2/3)MR^{2}
I know that the solid object has a lesser moment of inertia than the hollow one, but I'm not sure which is greater, the hollow cylinder or the hollow sphere. I think it's the hollow sphere, but can someone verify that?
Thanks in advance.
I read somewhere that the hollow cylinder's moment of inertia equation is actually 0.5MR^2, like what you find normally. Is this true? If so, then the hollow cylinder has a greater moment of inertia, right?
No. 0.5MR^2 is for a solid cylinder. If the hollow cylinder is a thin cylindrical shell, then its moment of inertia is MR^2. (Use your equation for the thick hollow cylinder to see this.)
I presume all objects have uniform density and the same dimension R and mass M. If the cylinder is thin shelled enough, then its moment of inertia will be greatest. This should make sense, since it will have all of its mass as far from the axis as possible (for a given radius).
  • · Replies 40 ·
14K
