Which Salt Makes the Best Hot Pack?
  • Thread starter Thread starter Icycomb
    Chemistry Lab
1 reply · 3K views
Icycomb
Which salt will make the best hot pack when combined with water?
Independent variable: Salt
Dependent variable: TemperatureIn the experiment I have a 50 ml beaker of water and I measure the initial temperature of the water. It was 24.5 degrees Celsius. I then add 10g of Sodium Chloride (table salt) to the same beaker. Now my question is will the temperature increase, decrease, or stay the same as the initial temperature of water.
I also did the same for two other salts: Ammonium Chloride and Calcium Chloride. The temperature of the water was 25 degrees Celsius for both of these salts. When I add the Ammonium Chloride and Calcium Chloride will the temperature stay the same, increase, or decrease?
Any help would be appreciated.
I don't understand the situation. You have measured initial temperature - it was 24.5 deg C. You have added salt. Next logical step is not asking the on the forums "what will happen", but measuring the temperature for the second time.
Ditto for the other two salts.
