While loop with continue statement skips space characters but gets index error
10 replies · 3K views · last reply
shivajikobardan
Thread moved from the technical forums to the schoolwork forums
Summary:: confused in program.
Write a while loop to display each character from a string and if a character is a space, then don’t display it and move to the next character.
Use the if condition with the continue statement to jump to the next iteration. If the current character is space, then the condition evaluates to true, then the continue statement will execute, and the loop will move to the next iteration by skipping the remeaning body.
what is this program supposed to do can you explain a bit about that?
Python code with a while loop that prints each character of 'Je sa a' except spaces, using isspace() and continue; below it, the output shows J e s a a.
Here is what it is doing. But it is very unclear to me what are we trying to do.It doesn't make any sense. IMO what it means is to not display spaces but display other alphabets. SO I wrote a code-:but this code doesn't work properly as I would like it to work. It gives error at last after doing everything right.
Python:
word=input("Enter a string")
i=-1
while(i<=len(word)):
    i =i+ 1
    if (word[i].isspace()):
        continue
    print(word[i],end="")
Enter a string-: Joe Biden
Output-: JoeBiden
Which I believe is correct what I want in that above program.
But here is an error that is ruining my mood.
File "E:\Udemy My Courses\LoopsTutorials\main.py", line 6, in <module>
if (word.isspace()):
IndexError: string index out of range
Your string "Joe Biden" is composed of 9 elements, but if you follow what your code is doing step by step, at some point you are trying to obtain the 10th element. I.e., at some point, your code asks for 'word[9]' which, since the word only has 9 characters, doesn't exist. That's what the error is telling you as "string index (9) out of range (0-8)"
Code:
i=-1
    i =i+ 1
You've checked whether i is less than or equal to len(word), and then immediately increased it. So now it might be 1 + len(word), which is out of bounds. Since list indexing starts at zero, it is in fact out of bounds when it equals len(word).
Gaussian97 said:
Your string "Joe Biden" is composed of 9 elements, but if you follow what your code is doing step by step, at some point you are trying to obtain the 10th element. I.e., at some point, your code asks for 'word[10]' which, since the word only has 9 characters, doesn't exist. That's what the error is telling you as "string index (10) out of range (0-9)"
I understand why it is coming, IDK if this is fixable.
You're off by one here. The string contains 9 characters, so the indexes run from 0 to 8. word[8] is the last character of the string.
Of course it's fixable.
As @Mark44 said, of course it's fixable. You could check how many characters are in the string before you start the loop and only iterate that high. Or you could use an iterator and only iterate through the characters in the string. Or you could use a try..except inside the loop and break from the loop if it fails. There are probably other ways as well.
This site gives some ideas. https://www.geeksforgeeks.org/iterate-over-characters-of-a-string-in-python/
Something like this:
Python:
word=input("Enter a string ")
for ch in word:
   if ch != ' ':
      print (ch, end = '')
True, it was a typo, I've corrected it thanks.
Python:
for ch in word:
   if ch != ' ':
Well, technically the question asks for a while loop.
Right, but I was elaborating one of the suggestions that @physguy made about iterating through the characters in the string.
Here's a while loop version:
Python:
word=input("Enter a string...  ")
wordLen = len(word)
i = 0
while(i < wordLen):
      i += 1
   else:
      print(word[i], end='')
      i += 1
Another possibility uses list comprehension.
Python:
# Create a list of the characters with spaces removed.
shortStrList = [ch for ch in word if ch != ' ']
# Print each character in the list.
for ch in shortStrList:
