Why a balloon sticks to the wall
  • Thread starter Thread starter jace
    Balloon Wall
A negatively charged balloon sticks to a wall due to the induction of positive charge on the wall, which attracts the balloon. When the balloon touches the wall, some negative charge transfers to the wall, causing a repulsive force that eventually makes the balloon fall. The balloon adheres longer in dry air because the lack of moisture prevents the rapid dissipation of charges, maintaining the attraction between the balloon and the wall. This phenomenon illustrates the principles of electrostatics and charge transfer dynamics.
  • Understanding of electrostatics and charge interactions
  • Knowledge of charge induction and transfer mechanisms
  • Familiarity with the effects of humidity on electrical charge
  • Basic principles of equilibrium in physical systems
  • Research the principles of electrostatic induction
  • Study the effects of humidity on charge retention
  • Explore the concepts of charge transfer and equilibrium in electrostatics
  • Investigate practical applications of electrostatics in everyday materials
Students of physics, educators explaining electrostatic principles, and anyone interested in the behavior of charged objects in different environmental conditions.
jace
I cannot find this in my book and i cannot wrap my brain around it...i am more of an analytical person...
The question is-A negatively charged balloon is sticking to the wall. Does this mean that the wall is positively charged?Explain.Eventually, the balloon falls down. Explain why. The balloon will stick to the wall longer when the air is dry. Explain Why.
2. None
Why would we assume the balloon takes on a negative charge and the wall a positive one? The balloon falls, equilibrium is reached and the attractive force is diminished, correct? The balloon sticks to the wall longer when it is dry outside due to the fact that the charges do not dissipate in the dry air as easily as it does on humid days.
When a negatively charged ballooon is close to the wall, positive charge is induced on the wall, which attracts the balloon. When the balloon is in contact with the wall, some negative charge is transferred to wall making it negative. Due to repulsive force balloon falls down. In dry air wall is dry, and hence transfer of charge from balloon to wall is slow.
18K
  • · Replies 18 ·
21K
10K
