mitocondrio
- 8
- 0
How can you have a simple coil connected to a battery without having a short circuit in it? How do they make electromagnets that don't heat the battery?
Philip Wood said:The wire is coated with insulation (except, of course, at the ends, where the connections are made). So it doesn't matter if the turns touch each other; the current cam't cut corners.
Philip Wood said:It's all a matter of design. In general, motors use thicker wire and less of it than you'd use for an electromagnet designed to run for more than a few seconds on a d.c. supply.
[Can't resist saying to Drakkith that he's right, of course, but making the resistor out of extra wire added to the electromagnet coil will have the advantage of making the electromagnet stronger! Just teasing.]
