Why are neither sin(x^-1) nor xsin(x^-1) continuous at x=0?
  • Context: Graduate
  • Thread starter Thread starter coverband
    Analysis Continuity
The discussion centers on the continuity of the functions sin(x^-1) and xsin(x^-1) at x=0, exploring definitions of continuity, limits, and the behavior of these functions near the discontinuity.
  • Debate/contested, Technical explanation, Conceptual clarification
  • Some participants argue that sin(x^-1) is not continuous at x=0 because it is not defined there, while others suggest it fails to meet the criteria for continuity based on limits.
  • There is a discussion about the sequential definition of limits, with participants questioning how to apply it to show that sin(x^-1) is not continuous.
  • One participant claims that for sin(x^-1), no matter how small delta is, the function oscillates between -1 and 1, making it impossible to satisfy the condition for continuity.
  • In contrast, xsin(x^-1) is described as having a removable discontinuity, with some arguing that defining it as f(0)=0 makes it continuous at x=0.
  • Some participants highlight that xsin(x^-1) approaches 0 as x approaches 0, while sin(x^-1) does not settle at any limit.
  • There are claims that both functions exhibit different behaviors as x approaches 0, with sin(x^-1) having multiple subsequential limits, which contributes to its discontinuity.
  • One participant emphasizes that defining xsin(x^-1) with f(0)=0 changes its continuity status, suggesting that it is not the same function as originally defined.
Participants express disagreement regarding the continuity of sin(x^-1) and xsin(x^-1) at x=0. While some argue that neither function is continuous, others assert that xsin(x^-1) can be made continuous through a specific definition, indicating a lack of consensus.
Participants reference the definitions of continuity and limits, but there are unresolved aspects regarding the application of these definitions to the functions in question, particularly concerning the behavior of sin(x^-1) as x approaches 0.
coverband
How come sin(x^-1) is not continuous and xsin(x^-1) is?
Calling something a function, and saying it is continuous, all require you to specify what the domains are that you're talking about. Any domain that I can reasonably use to make sin(1/x) a function mean it is continuous.
I suspect that you want to define it as sin(1/x) for x=/=0 and 0 when x=0, as a function from R to R.
It isn't then continuous because it fails to satisfy the definition of continuous.
If you want to prove this, then use the sequential definition of limit - it should be an easy and illuminating exercise.
In the sequential definition of a limit, n approaches infinity and we show there exists a natural number, say p, such that n>=p implies |f(n)-L| < epsilon
Do you mean to prove sin(x^-1) is not continuous we show we cannot find a real number r, such that x<=r implies
|sin(x^-1) -0|< epsilon ?
That is NOT a definition of "continuous". For one thing a function is defined to be continuous at specific points. That would be, if n is not constrained to be an integer, the definition of "limit as x goes to infinity". Since functions are not defined "at infinity" what you give is not even a definition of "continuous at infinity" (since no such thing exists).
A function is continuous at x= a if [itex]\lim_{x\rightarrow a} f(x)[/itex], f(a) exists, and [itex]\lim_{x\rightarrow a} f(x)= f(a)[/itex]. A function is not continuous at x= a if anyone of those is not true. A function is said to be "continuous" if it is continuous at every value of x.
At what value of x is sin(x-1) not continuous?
Yeah. I think when proving continuity its similar to the proof of a limit. In the case of sin (x^-1) our epsilon will always be smaller than our delta rather than the other way around which is what is required to prove the existence of a limit/continuity. Is this correct !?
?? There is nothing said about "epsilon" or "delta" being smaller in the definition of a limit. We only require that "given epsilon" there exist delta with such that if
|x- a|< delta, then |f(x)-f(a)|< epsilon. You need to go back and check the definitions of both "limit" and "continuous".
so in the case of sin(x^-1)
|x| < delta must imply |sin(x^-1)| < epsilon which is impossible because...?
First, as has been said before, just "sin(x-1)" is not continuous at x= 0 because it is not DEFINED there. The more important point is that that is not a "removable discontinuity"- it cannot be defined at x= 0 in any way that will make it continuous. And that is because no matter how small delta is, between 0 and delta, sin(1/x) will take on all the values sin(y) does for y between 1/delta and infinity. (You have 0< x< delta so 1/delta< 1/x< infinity and you can take y= 1/x.)
At some points larger than 1/delta, you will have values of y such that sin(y)= 1 and some at which sin(y)= -1. That means that for 0< x< delta, you will have some values of x so that sin(1/x)= 1 and some for which sin(1/x)= -1. As soon as you take epsilon< 1/2, you can't have |sin(1/x)-L|< epsilon for any delta. If |1- L|< 1/2, |-1- L|= |1+ L| can't be less than 1/2.
Now, f(x)= xsin(1/x) is also no continuous at x= 0 because it is not defined there. However, that is now a "removable discontinuity". While sin(1/x) takes on all possible values between -1 and 1 because it does stay between them, we now have -x<= x sin(1/x)<= x. And x itself goes to 0. [itex]\lim_{x\rightarrow 0} x sin(1/x)= \lim_{x\rightarrow 0} x= 0. Defining f(0)= 0, f(x)= x sin(1/x) if x is not 0, makes it a continuous function at 0 and so for all x.[/itex]
Yeah like there's no value of x (say p) such that
|x|<p implies |sin(x^-1)|<1/2
Let us look at the graphs of these functions.
sin(x^-1) OSCILLATES between -1 and +1 on the y axis
it takes the value 1 at x = 0.67, 0.22, 0.133...
Therefore if we have a restriction like you mentioned say epsilon < 1/2 there is no RANGE of values of x < p as every so often the corresponding y value (sin(x^-1)) will jump to 1
However looking at xsin(x^-1) this is like the standard sine graph DAMPED approaching zero. In this case we can set up a range of values for delta, limited by a restriction on epsilon
so in short, sin(1/x) is NOT continuous even if it is defined by f(x)=0 when x=0? and xsin(1/x) IS continuous if defined by f(x)=0 when x=0? am I right or wrong...sorry I have the same problem understanding this
sin(1/x) is no continuous because of you let x_n = 1/2npi
sin(1/x_n) =0
If x_n = 1/ (pi/2 +2npi)
sin(1/x_n) = 1.
A slightly naive explanation of this is that...
Basically your function has two different subsequencial limits although x_n -> 0. So depending on the way zero is approached you have different limits which means your function cannot possible be continous.
In case the point hasn't been made clearly, NEITHER of these functions is continuous at x= 0. x sin(x^-1) has a removable discontinuity at x= 0. The function defined by "f(x)= x sin(x^-1) if x is not 0: and "f(0)= 0" is continuous for all x but that is no longer the same function.
  • · Replies 85 ·
10K
14K
