Why are they called hyperbolic trig functions?
Hyperbolic trigonometric functions, defined as x = cosh(θ) and y = sinh(θ), create a hyperbolic curve represented by the equation x² - y² = 1. Unlike circular trigonometric functions, the angle formed by the line from a point (x, y) to the origin does not correspond directly to θ, which raises questions about the naming conventions of these functions. The point P = (cosh a, sinh a) reveals a relationship between the signed area bounded by the hyperbola and the horizontal axis, similar to the area relationship in circular functions. The discussion suggests that visualizing angles in the hyperbolic context might be enhanced by considering imaginary numbers. Overall, the complexities of hyperbolic angles and their geometric interpretations invite further exploration.
snoopies622
I know if we set
x = \cosh \theta , y = \sinh \theta
and graph for all \theta's, we get a hyperbolic curve since then
<br /> x^2 - y^2 = 1.<br />
But — unlike the case of making a circle by setting
x = \cos \theta , y = \sin \theta
and graphing all the \theta's — in the hyperbolic graph the angle formed by the line connecting a point (x,y) to the origin and the positive x-axis is not the corresponding angle \theta, making the original designations
seem rather arbitrary, no?
Mathematics news on Phys.org
The point P = (cosh a, sinh a) on the unit hyperbola gives you an interesting relationship between the signed area bounded by the hyperbola, the horizontal axis, and a line connecting P to the origin. Check out the Wikipedia article on it.
Interesting indeed. In that sense they are like the circular trig functions, since increasing the angle \theta in the unit circle at a constant rate also increases the corresponding enclosed area. Thanks, GFauxPas!
Too bad the argument "angle" in the hyperbolic case still doesn't match the (visual) angle it makes in the plane. Perhaps it will if one makes the horizontal axis imaginary numbers and makes the angles imaginary too? Need to work on this a little...
Likes GFauxPas
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
