Why buy new model rocket engines?
6 replies · 4K views
BonesSheppard
Hi I was wondering why are model rocket engines disposable after one use? Is it because it is more economically feasible to buy a new model rocket engine than to repair a used one because the process of using a model rocket engine always ruins it? Also, if it is the case that model rocket engines are ruined after one use, is it also the case with larger rockets? For example Falcon 9 or the Atlas-V, does this require companies and agencies such as SpaceX and NASA to rebuild or construct new rocket engines after each launch similar to model rockets? And if the previous answer is yes, are rocket engine rebuilds or reconstructions a primary cost factor for why rocket launches are so expensive?
Sorry for the questions and I appreciate anyone answering them, I was just curious :)
Welcome to pf,
the damage to the engines means that it cannot safely be reused if repared.
i.e. you could, technically refuel a sky-rocket tube, and reuse it. Why is that not routinely done?
The two Solid Rocket Boosters (SRB) attached to each Space Shuttle mission were designed to separate after their fuel was exhausted, after which a parachute was deployed from each booster so that the boosters could be recovered from the Atlantic by a specially equipped vessel. The boosters were then returned to shore and refueled and re-furbished for use on future missions.
http://en.wikipedia.org/wiki/Space_Shuttle#Solid_rocket_boosters
In order to be reused, things like model rocket engines or Solid Rocket Boosters must be designed for multiple uses, which usually means that each unit is heavier than a single-use item.
The next best thing we have to get into space is either hypersonic propulsion (very far from practical) or RAM accelerators/rail guns. Neither technology is mature enough to launch anythign appreciable into space. So, we are stuck with inefficient rockets in the sense that they are very heavy and have a small capacity.
Model rocket motors were always intended to be low-cost, disposable, safely manufactured for one use by the Estes corporation. The model rocket itself is intended to be a recoverable and reusable item, made from paper and balsa. I have launched, successfully recovered and reused a 4-stage model rocket (4 'A' motors). The first 3 stages were "tumble" recovery, and the 4th by streamer. All my rockets and launches were governed by the safety code of the National Association of Rocketry, of which I was a member.
Rocket fuel is closely related to explosives. You don't want kids experimenting with it.
Model engines are made very carefully.
See "October Sky" , it's about home made rockets. And it is a darn good movie.
http://en.wikipedia.org/wiki/October_Sky
