Why can two truss members at a joint both be zero force?
ktw
Whoops.. accidentally wrote everything in the solution box! Please see below.
Fx=0, Fy=0
Hi, I am a civil engineering student currently taking Statics. We are doing truss analysis in the class right now; and I know that this joint is marked as correct.
Handwritten truss joint diagram: a horizontal top chord with a downward load P(1/b) at the joint, diagonal members labelled √5P(T)/b and P(T)/b, and a vertical member below.
Hand-drawn plane truss with bottom chord nodes 1 to 5, top chord nodes 6 to 10, a load P applied downward at node 8 and a downward 2P load at node 4, supports at A and B, and bays of length a.
However, I don't see how this is even possible. I begin by considering this a concurrent 2D force system, Fy = 0 & Fx = 0. The equilibrium equation for Fy is -P + (1/√5)√5 * P + (1/√5)T = 0 ; where sin(θ) = (1/√5) and T is the diagonal that is following the line 8->5. I do not understand how the value of T can equal zero and then the member connecting joint 8 to joint 9 can also be zero; considering this would imply that (2/√5)√5P + 0 = 0 using the equilibrium equation Fx = 0. I understand zero force members and I do not think member 8->9 can be visually determined to be zero. Could anyone shed some light on this for me?
Thanks, Kyle
Looking at this closely.. there's no way that the solution is correct. My TA must have been mistaken. Thanks for looking at my question
