Why can't light be in black color?
  • Level: High School
  • Thread starter Thread starter Anithadhruvbud
    Color Light
67 replies · 13K views
Buckleymanor said:
Which brings me back to the main point that white light is invisible.
Again, you have said that "white light is invisible" when the word "white" is completely irrelevant. It is the presence of that irrelevancy that prompted both my previous response and this one.
Edit to add...
In the context of staring into a flashlight, I would have said that we see light that is "emitted" by the glowing filament and is "collimated" by the lens. The term "scattered" is not the best fit.
It appears that we do not disagree about the physics but only on the phrasing that is used to describe it.
I think there is still a fundamental misunderstanding here. There is no sense in which red light is visible but "white" light is not. The light emitted by a ruby laser is not white light that has been coloured by the crystal, the light emitted by the laser is of a single wavelength which our eyes perceive as red.
Edit to add...
I agree .Though the red laser explanation threw me.Does the light from the ruby laser have to be scattered by objects within it's path or is it a specific of a wavelength that can be seen in empty space.
Light travels in straight lines. If the laser is pointed towards your eye, you can see it (don't try this at home folks). If the laser is not pointed towards your eye, you can't see it (you might however see some particles of dust or vapour that are illuminated by the laser, particularly if it is a powerful one that you REALLY don't want to enter your eye directly).
The reason the space between stars in the night sky looks dark is not because light is invisible, it is because there is nothing in that direction from which light is traveling towards your eyes.
'Black light' is all the light outside the visible spectrum.
"The light that excites the human visual system is a very small portion of the electromagnetic spectrum."
"The electromagnetic spectrum is the range of all possible frequencies of electromagnetic radiation. The "electromagnetic spectrum" of an object has a different meaning, and is instead the characteristic distribution of electromagnetic radiation emitted or absorbed by that particular object.
https://en.wikipedia.org/wiki/Electromagnetic_spectrum#Visible_radiation_.28light.29
black light ?? ... doesn't exist
I'm surprised you would like one and not the other.
Anithadhruvbud said:
Why can't light be in black color? ... when I asked this question to my physics teacher she said I should ask the sun about it.
So, did you notice the sunspots on the Sun? They appear black, yet emit bright light. Even black and white are sometimes relative.
Could you be more specific about how that quote from Wikipedia contradicts my post, in your opinion? Do you perhaps mean the reduced surface temperature implies that sunspots do not emit light? Wikipedia says the surface of a sunspot is brighter than the full Moon.
not like the visible infrared light from the rest of the sun...
Sounds odd to me.
Just wanted to say that around here "black light" is a vernacular term for UV light. Eg. http://www.ukwholesale.info/products/black-light-bulb-es-75w-160011.html or Black Light WikiP.
I expect you knew that and were just pointing out that for sensible people, black means the absence of light or some such.
Of course in everyday usage we all use black to refer to objects which are reflecting some light (maybe quite a lot of light - at least, that is what I believe, but I can't support.)
But this is an amazing thread. Every time I get an alert for it, I know I can't believe a word of it, but I can't resist coming to see the latest oxymoron.
How about an eight-ball. Black and shiny.
Black body radiation at a few 1000 K, and even black hole radiation (though I think that's quite dim?)
Interesting that the OP hasn't come back.
That's because, like all colors, black is a subjective quality. What's black in one situation can be gray or even whitish in another (usually as a result of drastically changing background brightness). Similarly, what's red or green or yellow for me may not be the same for my Dad, who's partially colorblind. The color of an object can even appear to change just because of the surrounding illumination or the color of a room.
That's correct. See below.
The spectrum isn't the same since sunspots are cooler than the rest of the Sun, but they would still glow quite brightly. From here: http://csep10.phys.utk.edu/astr162/lect/sun/sunspots.html
Sunspots are regions on the solar surface that appear dark because they are cooler than the surrounding photosphere, typically by about 1500 K (thus, they are still at a temperature of about 4500 K, but this is cool compared to the rest of the photosphere). They are only dark in a relative sense; a sunspot removed from the bright background of the Sun would glow quite brightly.
Note that every single image you've ever seen of a sunspot and the surrounding areas is millions of times dimmer than the Sun actually is. While a sunspot may be thousands of times dimmer than the surrounding area, it is still glowing white-hot. At 3,000-4,500 kelvin, a sunspot glows at least as brightly as an incandescent light bulb, whose filament is around 2,500-3,000 kelvin, for the same surface area.
The amount of light reflected from the lunar surface is MUCH less than the amount of light that would be emitted if the surface of the moon was 3,000-4,500 kelvin.
These threads often turn out to be for the posters rather than the originator.
In a novel (Nebula award winner) the following question is asked: "If the speed of light is 3⋅108m/s, what is the speed of dark?"
same.
When you go into a room and turn on the light, the light reaches every corner of the room quite quickly. But the dark was there first.
When we pass light through a colloidal solution we can see the path of light which os called tyndall effect and we can say that in its path it vibrates the particles in its way providing considerable energy to the particles that is why we can see the light. The area where the light does not pass we can say that it is dark or it is same as when you pass light through a box with a hole on one of the sides.
I regard most of the foregoing as missing the original point and I reckon that that physics teacher would agree with me, bearing in mind his broad hint about the sun.
OK, some of us speak of "black light" as UV, but even as a schoolkid I always thought that a stupid and misleading term, and that was before I even had heard of black body radiation. I am sure that the teacher was NOT speaking of anything of the type.
What is colour? Most of us seem to agree on that, not counting a bit of a red herring about whether light is visible or not. Ignoring another (subjective) red herring about our eyes and brains, it (objectively) amounts to the relative intensities of relevant frequencies of light, together with the absolute intensity of the ambient light relative to the detection apparatus.
In particular, consider "white light".
In everyday experience, and in the absence of certain classes of gross subjective distortion (such as recently having lived in green light for a few weeks on end) this amounts to black body radiation within a given spectral range (for humans, between roughly 400 and 800 nm), and intensity ranges within a very few orders of magnitude of those typical of clear-air desert sunshine.
Now, let us take our source, diffuse the light and progressively reduce its gross intensity without altering any other objective attributes.
Still white light, right?
Well yes, but keep dimming it and you will find yourself in blackness; dark if you like. It still is radiation from the same black body at the same temperature, only there is less of it. It still is there, as you can confirm with starlight cameras etc.) And long before the light has vanished you would say it is black (or grey, which is simply an intermediate degree).
Talking rubbish am I? Try harder!
Set up a white light as described hereintofore, to shine on a suitable screen. Say a nice wide circle of roughly even intensity.
Now interpose a few filters of various intensities, but all of neutral grey (otherwise known as "dark white" in colour) . They will cast shadows of which colour?
Errrr... grey, except where it is dead black. Right?
But then, the only objective difference between black, grey, and white is the intensity.
Black light is white light of a sufficiently low range of intensities, as originally emitted by a black body of a sufficiently high temperature. such as the ... sun?
Much as any other colour effect can be seen as a range of intensities of a given frequency mix.
Yes?
Quibbling, am I?
Then try to make sense of this well-known, (brilliant, though not white) illusion, that includes white, grey, and (in some versions) black light:
https://en.wikipedia.org/wiki/Checker_shadow_illusion
Instead of debating physical color vs. perceptual color, why not agree that both things exist and are separate concepts.
Physical color can be thought of as a point in a (portion of) an infinite-dimensional Hilbert space of arbitrary combinations of frequencies having finite total energy.
Perceptual colors are points in a (portion of) a 3-dimensional Euclidean space that was discovered using color matching experiments: CIE 1931 XYZ space, and its later refinements.
The process of perceiving light is the phenomenon whereby physical light enters the eye and after stimulating cells in the retina is interpreted as a color in perceptual space. This determines a mapping from physical color space to perceptual color space.
So, the study of color perception is the study of this mapping. (Of course we are glossing over niceties like the fact that people have two eyes and that everyone perceives color a bit different from everyone else.)
alw34 said:
not really.
"Sunspots
are temporary phenomenaon the photosphere of the Sun that appear visibly as dark spots compared to surrounding regions. They correspond to concentrations of magnetic field flux that inhibit convection and result in reduced surface temperature compared to the surrounding photosphere..."
https://en.wikipedia.org/wiki/Sunspot
yes really ! They are around 4000K, they only appear dark compared/ in contrast to the 5700K photosphere around them
alw34 said:
same.
no, it doesn't exist, therefore it doesn't have a speed
Again black isn't a "colour" it isn't in the spectrum of visible light, it doesn't have a wavelength, it IS the ABSENCE of lightDave
Get real Dave! Read a book called The Shadow Club by Roberto Casato. It should make you more careful with such assertions.
A hint: before claiming that an entity exists or not, you should analyse its nature.
Would you say that a hole in the ground does not exist? Or a hole in a semiconductor?
You can say a hole in the ground is absence of any solid matter in the same sense that 'black' is an absence of any electromagnetism.
Both do exist, but both are defined as being an absence of something.
Jon Richfield said:
Get real Dave!
Jon, now play nice.
Dave is from 'down under'.
Everything there is 'upside down'.
But they do outrank North America in infra red light all year round.
I would agree with Dave. Defining something to be the absence of something else doesn't mean it exists as a real physical object with properties such as velocity, charge, etc. However, for convenience and simplicity we usually talk about such things as if they actually exist. It's easier to say, "Hey Jim, watch out for that hole" instead of, "Hey Jim, watch out for that spot where we removed all the dirt". It's also easier to make models and do calculations if we model holes as being real objects, but again, that doesn't mean they are 'real' in the sense I described above. A hole in a semiconductor material can be modeled as if it is a positive charge moving the opposite direction to the flow of electrons, but in reality there's simply no electron at that location.
Trying to assign a speed to darkness makes no sense. For example, a shadow can move across the ground at any speed you want. Even superluminal.
I vote this the craziest discussion yet.
Someone award the OP a prize!
Oh, if only you could see some of the threads us mods have had to remove...
