Why can't Maple simplify this further?
  • Context: Maple
  • Thread starter Thread starter ztdep
    Maple Simplify
The discussion revolves around the inability of Maple software to simplify the expression (√π - √π) to zero. Participants explore the implications of how square roots are handled in Maple, particularly regarding the treatment of constants versus variables.
  • Technical explanation, Debate/contested
  • Some participants suggest that (√π - √π) might not be zero due to the possibility of selecting different branches of the square root function.
  • Others argue that since the square root of a positive number is conventionally the principal square root, (√π - √π) should indeed simplify to zero.
  • One participant mentions that Maple may treat each instance of π as a separate variable, which could lead to confusion in simplification.
  • Another participant proposes that using "Pi" instead of "pi" in Maple could resolve the issue, as the former is recognized as a constant.
  • Some participants express confusion about why Maple does not simplify the expression to zero, despite the conventions surrounding square roots.
  • A later reply questions the logic behind Maple's handling of expressions with common denominators, suggesting a potential inconsistency in its simplification process.
Participants express differing views on whether (√π - √π) should simplify to zero, with some supporting the idea that it should and others suggesting that Maple's treatment of the square root may lead to different interpretations. The discussion remains unresolved regarding the exact reason for Maple's behavior.
There are limitations regarding the assumptions made about the treatment of square roots in Maple and the definitions of constants versus variables, which are not fully explored in the discussion.
ztdep
I am evaluating this formula, it's real value is 0. but maple can't further simplify it?
Probably because (√π - √π ) isn't necessarily zero. It depends which of the two square roots you take. If you force it to take the positive square roots, then it will be zero.
  • Skeptical
How can (√π - √π) not be zero? We are not solving a quadratic equation here, so ##\sqrt{\pi} > 0##.
If you select a branch at random each time you write a \sqrt{}.
It may be that Maple thinks that each \pi is a separate variable, whose values are not necessarily equal.
DrClaude said:
How can (√π - √π) not be zero? We are not solving a quadratic equation here, so ##\sqrt π>0##.
To elaborate on @DrClaude's comment, the square root of a positive real number is by convention the principal square root of that number. i.e., the positive square root.
Although the equation ##x^2 - 4 = 0## has two solutions -- x = 2 or x = -2, it is an error to say that ##\sqrt 4 = \pm 2##.
Try entering Pi instead of pi.
For Maple, the first one is the famous mathematical constant, the second one is an undefined variable.
Conventions are one thing, but what's coded up in the Maple code is another. What's your explanation for why it didn't replace (√π - √π ) in equation 4 of the OP with 0?
##\sqrt \pi## in Maple must be a positive number. I'd be very surprised if something as basic as that was coded wrongly.
Maybe try to actually run it through Maple with reference to post #6.
It is a triviality, nothing else. And it certainly does not have anything to do with branches of square roots.
No idea, but I'm also puzzled why Maple added two expressions whose denominators were both ##\sqrt \pi x^2## to get a single expression with a denominator of ##\sqrt \pi x^2 \sqrt \pi##.
However, I think @S.G. Janssens has hit the nail on the head with his advice to use Pi rather than pi. The Maple documentation backs up this advice - https://www.maplesoft.com/support/help/maple/view.aspx?path=initialconstants.
