Why cant thelectric field be in circumferential direction?
  • Level: Graduate
  • Thread starter garylau
    Direction Field
10 replies · 2K views · last reply
garylau
Sorry
in this question i have several things to ask
1.why can't the E field in the circumferential direction?
2.How can i find the direction of B field
3.according to the formula of curl E=-dB/dt and the curlB=u J
did they share the same property so that the direction of E is circumferential (just like B dl=u i which is ampere law so that the direction B is circumferential) and dB/dt is going straight(just the the current is going straight which is enclosed inside the boundary)?
thank
  • Textbook problem 1 on an alternating current I = I0 cos(wt) flowing along a straight wire and returning through a coaxial conducting tube of radius R, with parts a) through f) asking about the induced electric field and displacement current.
1. I don't know what you mean by "circumferential".
Clearly it is possible to set up an electric field that goes in a loop: it's called an electric circuit.
But you cannot have a circular field line because the line has to start and end at different potentials.
2. You use a small magnetised needle balanced on a pivot.
3. The similarity in the equations shows that there is a similarity in the equations ...
Note, they should be:
##\nabla\times\vec E = -\partial_t\vec B## and
##\nabla\times\vec B = \mu_0\left( \vec J +\epsilon_0\partial_t \vec E \right)##
... if ##\vec J = 0## the two equations look even more alike ;)
Check what "curl" means:
https://en.wikipedia.org/wiki/Curl_(mathematics)
you can see this picture clearly
the solution states:The magnetic field is “circumferential” in the quasistatic approximation."...but i don't know how did the solution concluded "Thus the direction of the electric field is longitudinal" from the simiarlty between the relation between the electric and magnetic fields?
What breaks the symmetry between the magnetic and the electric is the lack of magnetic monopoles: north and south magnetic charges that emanate magnetic field in the way positive and negative electric charges emanate electric field. If you had a magnetic wire carrying magnetic monopoles in a straight line they would generate a circumferential electric field in the same way an electric current generates a circumferential magnetic field.
But Why did the Electric field outside vanished in this case?
Simon Bridge said:
In what case? Please be specific.
See the statement inside the red circle.
  • Textbook page with a solution: text on the magnetic field being circumferential, then the electric field inside a cylinder computed via Stokes' theorem, with equations E = -(mu0/2pi) ln(R/rho) dI/dt z-hat and E = (mu0 I0 omega/2pi) sin(omega t) ln(R/rho) z-hat, and the circled statement 'The electric field outside vanishes.'
Oh so the question had nothing to do with the quoted text? Fine.
To see why the electric field vanishes, try doing the problem.
because the total current inside the object is 0?
That contributes to it, yes, but the main point is the absence of magnetic charges and the fact that the problem assumes a static situation.
