- 1,073
I have once again come across a smoke detector which requires not only a specific type of battery (9V alkaline) but also a specific model (in this case Duracell MN1604) to be used.
I had a similar problem with a CO detector about a year ago (which came with a list of about 10 models that should work; must of which were no longer available) and I then tried some "unauthorized" batteries just to discover that the detector simply did not work with the "wrong" model; the "battery low" indicator (and beep) would turn on if the wrong model was used.
This time I am just going to order a new battery online (MN1604 is not available in the shops near where I live)
I presume that the detectors are designed so that they only work with a very specific EMF and/or internal resistance(?) since this (presumably) the only way to tell the difference between different 9V batteries, but does anyone know why this is the case?
Most well-designed electronic devices will work wide a fairly wide range of EMF and this is even true for most smoke detectors.
My theory is that it is the battery monitoring part of the circuit (the part that makes the detector beep when the battery runs low) that requires a very specif battery model to work; but that is just a guess.
Does anyone know for sure?
