Why do forces make an object move?
  • Context: High School
  • Thread starter Thread starter sameeralord
    Forces
79 replies · 29K views
sameeralord said:
However I still have the question why Newton's third law occur, is it because of change of momentum or not.
I don't know what you mean by "change of momentum" in this context. You push on a wall; the wall pushes back on you. That's an example of Newton's 3rd law. Where do you see any change in momentum?
You push on the wall, you lose energy to the wall and hence slow down(which can also be considered as the wall acting on you). If that is not the explanation, why does every reaction have an equal and opposite reaction? Is their any form of energy transfer occurring here.
No you don't. Why do you think this?
When I'm pushing the wall, I'm not moving.
Not only are your statements not an explanation, they are not even true!
russ_watters said:
The question isn't philosophical, it is just a misunderstanding of what energy is: you're looking at the issue backwards. Energy is the biproduct of the movement, not the cause. The force is the cause of the motion.
I don't know. In the Lagrangian formalism you certainly can look at it the other way. The energy is the cause of the motion and the force is simply the change in the energy wrt some coordinate.
sameeralord, are you familiar with Lagrangian mechanics? If not, perhaps you should look into it. At least for conservative forces it provides an approach where forces play a very secondary role and energy is the primary thing.
A moving object doesn't have or need a force. You only need a force to accelerate or decelerate an object.
It's never just a force acting on an object. Whenever a force acts upon an object the object will in turn always react with a force in the opposite direction. A reactive force. An object will only accelerate or decelerate when the active force is stronger than the reactive force from the object be it due to inertia, friction, mass, structural integrity or whatever. There's always an active force AND a reactive force. And of course if there's any type of friction and you want to have a constant speed you need to constantly apply a force equal to the frictional force. But if there isn't it will continue forever without any forces.
So I think there might be some kind of misunderstanding that a moving object has a force or need a force to keep going. It doesn't. It has energy, it has momentum, and sure it can impact something with a force. But for there to be a force there must also be a reactive force, in other words it must hit/act on something.
If object A exerts a force on object B, then object B will exert an equal and opposite force on object A. Is this the 'reactive force' you are describing? Note that those two forces act on different bodies.
This is confusing. Per my comment above, the reactive force is always equal to the active force. (And, more importantly, they act on different bodies.) Or do you mean something else by 'reactive force'?
Why am I not moving when the wall is pushing back on me? Then what is your explanation to why does every reaction has an equal and opposite reaction? Change in momentum= Ft. Is this force not related to Newton's third law anyway. If I push a stationary box and the box moves, that means the box must have gained some energy when I pushed it. Where does this energy come from, haven't I lost it meaning change of momentum?
Hey thanks for the reply Dalespam :smile: I'll surely look into it but for now I think I have overthought and got confused with basic physics concepts. If you can help me, post in my other thread. My question is related to why Newton's third law occur and is change of momentum related to Newton's third law.
Because other forces are acting on you to give a net force on you of zero.
Sure. If you push something and it moves, you are transfering energy to it. (And momentum.)
You did the work on the box so the energy comes from you. If you imagine that you and the box are on a frictionless surface (to avoid having to deal with other forces), and you give the box a shove (and it shoves you back) then the box gains some energy and momentum. The amount of momentum the box gains is equal and opposite to the amount of momentum that you gain. (That is related to Newton's third law, since the forces you and the box exert on each other must be equal.)
sameeralord said:
How is a normal reaction force generated. I thought it was due to momentum, the box pushes on the table, the table pushes on the box, like a momentum collision.
A solid object is just like a spring, only much stiffer. Instead of a table, take a simpler example of a concrete footing. If you put a few tons on top, you can measure how much it is squeezed with a dial gauge. The shortening of the footing (leg) causes a force upwards trying to restore it.
What you normally consider a "spring" is just a solid that's weakened to the point where such changes in length become obvious. But it's always like that.
--John
Every action has an equal and opposite reaction, so really nothing is happening in this universe, its all just an illusion :)
people who say that when you push on a box and it doesn't change position you arent giving it energy are wrong. An example of the energy you give to the box is in the form of body heat (if the box is colder than your body). The atoms of your hand have more kinetic energy than the atoms of the box so when they collide when you push the box, the atoms of the box gain kinetic energy. So the box gets energy in the form of heat (which is just kinetic energy, vibrating atoms). Also the box deforms, so in that way there is energy transferred aswell. Also your body heats up etc. energy gets lost in that waytooo.
It's true that if you and the box are not in thermal equilibrium, there will be a transfer of heat. But we were talking about mechanical energy transfer, not thermal.
It's also true that the box will deform a bit when pushes (as mentioned by JDługosz). And there will be an associated (small) amount of work done by you as the box deforms. But once the deformation is complete, no additional work is done.
The wall is attached to the ground, so it doesn't move and if it doesn't move, it can't make you move!
There isn't anything to explain: you're making up your own definition here that just isn't correct. Newton's third law says: "Third Law: Whenever a first body exerts a force F on a second body, the second body exerts a force −F on the first body. F and −F are equal in magnitude and opposite in direction." The word "move" does not appear in the definition. It isn't necessary/relevant.
We're going in circles, repeating ourselves. As said before:
1. Yes, in some cases an exchange of forces involves an exchange of energy and momentum.
2. In other cases, an exchange of forces does not involve an exchange of energy and momentum.
This has been explained several times. I think the issue here is that you aren't paying enough attention/reading carefully, and thinking about what you are reading.
No, change of momentum is related to Newton's 2nd law. Newton's 3rd law is related to conservation of momentum.
--John
First of all thanks a lot for all the answers especially this one :smile: This actually finally explains the Newton's third law, only if someone can explain why every object has elasticity, what property of atoms make them spring. If I use your analogy to answer about pushing the wall and why it doesn't push me, I think it is because you when you push the wall you can't compress it much, due to the inertia of the particles inside the wall when the force is transmitted, so the opposite force is quite less. I don't understand why Doc Al said net forces acting on you is zero, isn't their still a small force however. I still don't understand negative force or work
Let's say a box was moving forward at constant speed, it must have some energy, then a force in opposite direction acts on it to make the object stop, how has the negative force removed energy from the object, has it been transferred to heat? Also if I keep applying this force, the object would eventually accelerate the opposite side, how come now the negative force is giving energy to object and before it was taking away.
Also more about the spring. If I push a spring on a stationary wall and release, the spring would fly in the opposite direction right? I understand that there is elastic potential energy stored and this causes the movement but when I normally compress a spring it springs back to its orginal shape, how does it fly away in other direction. For example when I compress a spring against a wall, why doesn't it regain its original shape and fall down, why does it fly away instead. I'm thinking the elastic potential energy is used to make the spring go back to its orginal shape. Thanks
I'm trying to understand Newton's third law using this. If I push a book, it will push back on me. How does this occur using spring example. When I push the book does my hand compress a bit and then I move back in the other direction, ok but isn't the book compressed a little bit as well, wouldn't the make the book spring back and move back. How does the book move foward, if I compress it, shouldn't it spring back.
Thanks :smile:
But it does push you, just as hard as you push it.
The net force is the vector sum of all forces acting on an object. Just because the net force is zero, doesn't mean there are no forces acting. Imagine yourself sitting quietly in a chair. The chair pushes up on you; gravity pulls down. Forces act on you, yet the net force is zero.
I recommend that you contemplate Newton's 2nd law. If there's a net force on an object, then the acceleration of the object will be in the direction of that net force. Toss a ball straight up in the air. Why does it lose energy on the way up, then gain it on the way down? The simplest thing to realize is that its acceleration is always downward.
It "flies away" because there is an unbalanced force on it. Squeeze a ball between both of your hands, hard. Then quickly remove one hand. Since the other hand is still pushing, the ball goes flying.
When you push on something, it compresses a bit. The resulting motion of the object depends on all the forces acting on it. You push the book, it compresses; if that's the only force on the book, it accelerates forward.
Ok thanks for all the replied Doc Al :smile: I think I'll try to learn this step by step. When I throw a ball up in the air initially I lose energy. Where does this energy go to, which form is it converted to?
Are you talking about the ball losing kinetic energy as it rises?
Yes slowing down first and then accelerating in the other direction. I'm thinking that slowing down at the start is due to loss of energy, where is this energy going to?
As the ball goes up, gravitational potential energy increases while kinetic energy decreases. Once it reaches maximum height, the process reverses and it gains kinetic energy while losing potential. The total energy never changes.
But at all points the force on the ball is downward, thus the acceleration acts accordingly.
Thanks again Doc Al. Newton's third law then seems to be coming from potential energy I get the feeling. When I compress a spring, it stores elastic potential energy and this gives the reaction force. It seems it is trying to restore its previous energy state all the time, it has to act in opposite direction to restore the energy, it doesn't matter which way the object is traveling as long as the previous energy state is restored. This is starting to make sense I think. Let me reread your posts again, and ask the other questions I have.
Hello Doc Al,
It seems I peaked too early and I don't understand this much yet.
Now in this picture if I find change in momentum of full back it is.
400-640= -240
Now if the full back lost 240 momentum,then the lineman should have gained it. So line man's change of momentum must also be 240 in opposite direction. When I do the equation it is.
400+240=620
Why is it not equal?
400-640= -240
Nope. 400 kg-m/s is not the final momentum of the full back, but the combined momentum of both players. (+640 -240 = 400)
If you new the masses and initial velocities of the players, you could determine their final speed and the change in their momenta.
If you want to talk about Newton's 3rd law coming from energy then you will need to learn Lagrangian mechanics and Noether's theorem. Newton's 3rd law can be derived as a consequence of the spatial symmetry of the Lagrangian.
Ok thanks for all the replies. Now let's say there was an object with initial momentum of 1 (m=1 v=1)and final momentum of -1(v=-1). That means change of momentum is -1-1= -2. Now if I consider the change in kinetic energy of the object 1-1 is zero. This is my biggest question, how come there is a change of momentum without a change in energy.
The people will provide energy to the box only if the box is compressed slightly for example the energy will result in heat on a molecular level.
For one thing, momentum is a vector while energy is a scalar. The momentum can change direction, which is what happened here. Note that the magnitude of the momentum--and the speed of the object--has not changed. In other words, momentum depends on velocity while kinetic energy depends on speed. The velocity changed but the speed remained the same.
Ok the object was traveling at 1m/s at the start. Then a force must have acted on it to make it travel at -1m/s. So first the force would have made the object lose some energy and make it travel at 0m/s and then add some energy making it -1m/s. Now my question is when the force has made the object lose energy, what is this energy transferred to, there is no gravity in this.
