Why do laptop transformer sizes vary so much?
  • Thread starter Thread starter Charles123
    Laptop Transformer
Laptop transformer sizes vary primarily due to differences in current capabilities, with larger transformers required for higher output, such as 5A compared to 3-4A. Most laptop power supplies (PSUs) are switch-mode types, which have minimal size variation, but design and manufacturing skills significantly influence the final dimensions. The ferrite core cylinder near the cable connector serves dual purposes: filtering high-frequency noise from the power supply and preventing the laptop from acting as an antenna for RF signals generated by its circuitry. Variations in transformer size can also be attributed to ongoing advancements in electronic design aimed at packing more power into smaller volumes.
  • Understanding of switch-mode power supplies (SMPS)
  • Knowledge of electrical current ratings (voltage and amperage)
  • Familiarity with ferrite core applications in electronics
  • Basic principles of electromagnetic interference (EMI) and filtering
  • Research the design principles of switch-mode power supplies (SMPS)
  • Explore the role of ferrite beads in reducing electromagnetic interference
  • Learn about thermal management techniques in electronic device design
  • Investigate advancements in compact power supply technologies
Electronics engineers, product designers, and anyone involved in the development or optimization of laptop power supplies and electronic devices.
Charles123
Why laptops transformer size varies so much?
Also, the little cylinder right next to the cable connector to the laptop is there to avoid that the laptop works as an antenna? How does that work?
Thank you
Regards
Hi Charles
Most laptop PSU's these days are switchmode type. There isn't too much variation in physical size. any variation in size is mainly related to the variation in current capabilities of the supply. a 5A or so supply is going to need a physically larger transformer than one that only requires 3 or 4 Amps.
That little cylinder is an encapsulated ferrite core that the DC supply cable passes through before getting to the laptop.
It has 2 purposes ...
1) to filter any hi frequency generated by the SMPS from getting into the electronics of the laptop and causing instability problems
2) it also has the reverse filtering effect. the microprocessor circuitry etc of the laptop produces lots of RF at many frequencies. That ferrite core filters much of that out so that the DC power cable doesn't act like an antenna and radiate those signals
Dave
Thank you for your answer. But actually, and just as an example my Toshiba Qosmio x770, has a transformer twice as big and tree times heavier that my ASUS… none of them is more than 2 years old.
What wattage does each output? How big are the laptops?
yeah that was going to be my next question
what is the voltage and current ratings of the large one compared to the small one ?
I still stand by what I stated its all to do with the current the unit needs to supply that determines its overall size
D
I understood your explanation, I was just comenting the diference in sized because you wrote - "There isn't too much variation in physical size.".
Thank you again
Regards
@ OP:
each is labelled with its output volts and amps. Look carefully at the small print on nametag.
If you read electronic design magazines there is a continual push to pack more power into smaller volume
so your observation is right - there is a LOT of variation even among swichers.it comes down to the skill of the design and manufacturing teams, can they find small parts and can they arrange to get rid of the waste heat
there have been plenty of overheating failures from "design oops'es", believe me.
  • · Replies 24 ·
