Why Do Line and Surface Integrals Yield the Same Result for a Triangle Path?
The discussion revolves around evaluating line and surface integrals of an electric field defined by E = c(2bxy, x^2 + ay^2) over a triangular path and its corresponding area. Participants are exploring the relationships between these integrals and the conditions under which they yield the same results.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss breaking the line integral into segments corresponding to the triangle's vertices and evaluating each segment separately. There are questions about the limits of integration and the setup of the integrals.
  • Some participants question the need to compute the curl of E and its relationship to the surface integral, while others explore the implications of the results being the same for both integrals.
  • There is a discussion about determining constants a and b under specific conditions, with some participants suggesting the use of assumptions about the triangle's geometry.
The discussion is active, with participants providing insights and guidance on evaluating the integrals. There is a recognition of the relationship between the line and surface integrals, and some participants are beginning to connect their findings to broader theorems in vector calculus.
Participants are working under the constraints of a homework assignment, which may limit the information available and the approaches they can take. There are ongoing questions about the assumptions made in the problem setup and the implications of the results obtained.
galipop
Hi All,
I have the following electric field E = c(2bxy, x^2+ay^2) where a,b and c are constants
1. I need to find the line integral \oint E \cdot dl where the close integration path is defined by the triangle (0,0) (1,0) (1,1)
2. compute the surface integral \int\nabla \times E \cdot dA where the surface is defined by the area of the triangle.
3. determine the constants a and b such that \nabla \times E=0 and \nabla \cdot E=0. Compute the potential in this case.
can anyone get me started. thanks!
Do you have any thoughts at all on the problem?
Part A)
I guess this needs to be split up into 3 integrals. \int partialx.dx + \int partialx.dy + \int partialx.dx+partial.dy
i guess the limits are 0->1 , 0->1 and 0->1 for each integral. Is this right?
Part B) and C) I'm not sure at all what is being asked.
For your first integral just evaluate
\int E_x dx + \int E_y dy
around the closed path paying close attention to the signs of both dx and dy and the values of x and y!
Oh, for part (2) you'll need to work out the curl vector whose only vector component will be perpendicular to the x-y plane which also happens to be in the same direction as the normal to the surface. Then just evaluate the integral
\int f(x, y) dx dy
where f(x, y) will be the function you get from taking the curl.
I think I understand part a now. Taking mulitple paths to the same point result in the same line integral?
As for the calculation I get:
=c * (\int 2by dx + \int 2ay dy)
both have limits 0 to 1.
How does that look?
Good start but not quite!
Let's break it down into parts.
On the line segment from (0, 0) to (1, 0) dy is 0 so you'll only have an integral over x. However, y is also 0 on that line segment so E_x = 0 so this portion contributes nothing!
On the line segment from (1, 0) to (1, 1) dx is 0 so you'll only have an integral over y. Also, x = 1 on this line segment so E_y = c(1+a y^2) which you can easily integrate from 0 to 1.
The last segment from (1, 1) back to the origin (0, 0) is a little more tricky. First note that dx = dy but since dl = \sqrt {dx^2+dy^2} you will use, e.g. \sqrt {2} dx in your integration. Also, your integrand will be c \left( 2 b x^2 + x^2 + a x^2\right) since x = y along this segment and your limits of integration will go from \sqrt 2 to 0.
man that math looks hard, i hope i don't have to take it. what math is that?
It's for Galipop's Electricity and Magnetism course - he's basically trying to show that the electrical force is a conservative one.
Hi again...
I found an example on the net somewhere showing a similar example for a circle. After looking and that and these notes I think I sort of understand now.
Ok so evaluating the integrals:
(0,0) -> (0,1) = 0
(0,1) -> (1,1) = c ( 1 + (a/3) )
(1,1) -> (0,0) = c * sqrt(2)^3 / 3 ( a + b + 1)
so do I just add up all of the component results now?
On the first leg, from (0,0) to (1,0), we can take x= t, y= 0 as parametric equation. Then dx= dt and dy= 0. E.dl= c(2b(t)(0), t^2+a0^2) .(dt, 0)= 0. Integrating from t= 0 to t= 1 gives 0 just as you say.
On the second leg, from (1,0) to (1,1), we can take x= 1, y= t so that dx= 1, dy= dt.
Now E.dl= c(2b(1)(t),1^2+at^2).(0,dt)= c(1+ at^2)dt. Integrating that from 0 to 1,
we get c(1+a/3), again just what you have.
On the third leg, from (1,1) to (0,0), we can take x= t, y= t with t decreasing from 1 to 0. Now dx= dt, dy= dt and E.dl= c(2b(t)(t),t^2+at^2).(dt,dt)= 2bct^2dt+ (1+a)t^2dt= (2b+1+a)t^2 dt. Integrating from 1 down to 0, this gives -(2b+1+a)/3.
I suspect you put in the \sqrt{2} to "normalize" t- make the length 1. But if you do that, \sqrt{2} should appear both in E and dl and will "cancel".
Yes, once you have integrated on each leg, add them to find the full path integral.
To finish the problem take the curl of E and integrate it over the area of the triangle.
Why do you need to take the curl of E and integrate it over the area?
Because that's what you asked for in your second question?
oh. I thought HallsOfIvy was still talking about the 1st part :)
Curl of E is:
c<0,0,2x-2bx>
normal to the area is <0,0,1>
how do I integrate this over the area of the triangle?
Thanks...
\int\int{2(1-b)x dA} over the triangle of course.
Since the hypotenuse of this triangle is the line y= x, that will be
2(1-b)\int_{x=0}^{1}\int_{y=0}^{x}xdydx.
ah...i was integrating from 0->1 and 0->1...that's why I wasn't getting the expected answer.
So now I've done both parts, the results are the same. This is due to the relationship between Gauss and Stokes theroems correct?
Now for part 3...
Determine the constants a and b such that \nabla \times E = 0 and
\nabla \cdot E = 0. Compute the potential in this case.
The curl = 0+0+cx(2-b) = 0
and the divergence = 2cy(b+a) = 0
to solve for a and b can I say that x=y as we are dealing with a triangle?
Okay
I managed to Answer all questions,
But I still have one question I need answered
Why does one obtain the same result in (b) as in (a)?
