Moon Bee
- Messages
- 5
- Reaction score
- 0
Why do people turn on several computers then leave them there ?
I think one/4-5 comps
-Moon Honey Bee
-Moon Honey Bee
cyrusabdollahi said:Computer that turns itself off.
Ditto that. I don't even shut off this iBook, but it will do it on its own if left for more than a week or so (LIon battery, which will be destroyed if it gets completely drained).Mallignamius said:I leave mine on 24/7 to avoid thermal shock.
russ_watters said:Thermal shock? That simply isn't an issue. Thermal shock is what happens when you get a rapid temperature change, like the cracking of an ice cube in a glass of water. Besides most of the components of your computer not being all that sensitive to it (you can quench red-hot metal and it won't break...), taking 30 seconds to warm up does not consitute "thermal shock".
Moon Bee said:Why do people turn on several computers then leave them there ?![]()
Maybe that's another advantage of a Mac. If this thing is just resting, touching anything or opening the clamshell wakes it up. If it's hibernating, hitting the 'shift' key does it. Only when it has shut itself off do I need to restart it. Since I don't leave it alone long enough for that to happen, it's a minor issue.robphy said:and hopefully soon, "Instant On" [e.g., resume from hibernating to solid state drives].
Danger said:Maybe that's another advantage of a Mac. If this thing is just resting, touching anything or opening the clamshell wakes it up. If it's hibernating, hitting the 'shift' key does it. Only when it has shut itself off do I need to restart it. Since I don't leave it alone long enough for that to happen, it's a minor issue.
I didn't realize that 'Windows-burners' don't do that.
Umm, Russ is right. The term 'shock' normally implies a transient phenomenon, which is usually 'rapid'.cyrusabdollahi said:Thermal shock does not mean rapid. You get thermal shock when you have a large temperature gradient and associated mechanical stresses.
robphy said:Did Macs always have the features you describe? Or is this a feature of the newer now-Intel-based Macs?
Astronuc said:Umm, Russ is right. The term 'shock' normally implies a transient phenomenon, which is usually 'rapid'.
Yes, they do: time is the key part of heat transfer rate, which is where the large gradient comes from.cyrus said:None of these equations have time as a variable.
The theory presented by others was that the thermal shock happens at startup, where the gradient is caused by the rapid heating of a cold chip - exactly the situation of an ice cube in water (if they were correct about it being a large transient gradient...).Thermal shock does not mean rapid. You get thermal shock when you have a large temperature gradient and associated mechanical stresses.
Now that is a bad idea - I've bought components in winter before and I have to resist even taking them out of the package before they warm up. Besides the moving components issue with hard drives, in winter you have a condensation issue too. I think condensation from going straight from the cold outside (using my telescope at night, in winter) to a humidified bedroom multiple times contributed to the death of my last laptop.Astronuc said:Thermal fatigue and wear and tear on HD's are a reason to leave them on. Similar experience to that of Mallignamius, I started a computer cold one time (I stupidly left in the car on a cold night), and the HD got damaged.
There are plenty of people out there who overlcock the crap out of their computers and use either water or phase-change cooling. The thermal gradients and heat transfer rate, and associated shock are much higher than what you would have seen.Mallignamius said:I lost a computer last winter to it. It's specifically my circumstances here where I don't bother with the furnace much. 50° F and I'm happy.
But when I plugged mine in one cold winter day, it booted up on its own. Poof! No more computer. I had intended to wait for room temp to go up before booting.
That tells me you lost your computer to static electricity, which is a big problem in winter when the humidity is low. When you plugged-it in, the static discharge was enough to jump the on/off switch and fry the motherboard at the same time.But when I plugged mine in one cold winter day, it booted up on its own. Poof! No more computer.
Moonbear said:Yes, those features have been around a long time on Macs. I didn't realize they didn't exist on PCs. Surely PCs are the same way, aren't they? Isn't that the whole point of a sleep mode, to be able to quickly wake it back up? If you had to wait for a full re-boot, you might as well turn it off.
To be more specific, a 200w desktop computer costs about $20 a month to run (not including HVAC issues). People can decide or themselves if that is worth doing...DaveC426913 said:1] Computers are fairly low energy consumers these days. It's not hard on the bill.
While technically true, that really isn't a big issue. I've never had a computer die due to wear and tear - only those who might keep one for 10+ years could run into that.2] Most of the wear and tear on a computer occurs in booting up. It is easier on the computer to leave it running than to be constantly turning it on and off.
robphy said:I never said that features like standby and hibernate didn't exist on PCs.
My earliest statements are implicitly making reference to very old PCs.
The first time I used hibernate was with Windows 2000. Windows 98 already had that feature http://www.microsoft.com/windows98/usingwindows/work/articles/908Aug/hibernation.asp.
Macs probably got that feature about the same time as PCs then. The first time I remember using it was when those horrid fruit-flavor-colored iMacs came out which was somewhat contemporaneous with the Win 98 to 2000 switch. The Power Macs out just before that might have had the feature too, but I wasn't regularly using Macs before then so am not totally sure. I couldn't recall if Win 98 had a hard-drive sleep feature, or just a monitor display sleep. I also can't recall if the Macs before the iMac had anything other than a display sleep.russ_watters said:I tend to leave mine on in the winter because it doesn't hurt my electric bill any to have it on, but I shut them off in the summer when I'm not using them because it costs a lot to leave them on.
Russ said:Yes, they do: time is the key part of heat transfer rate, which is where the large gradient comes from.
What are the units of k? W/m-K, and W = J/s.cyrusabdollahi said:Take the rate equation:
q=-k(dT/dx)
time is not a variable in this equation, anywhere. The rate is a function of spatial and mechanical properties only.
What are the units of k? W/m-K W = J/s.
True - for steady-state.cyrusabdollahi said:But k is a property of the material and is (more or less) constant for a limited temperature range. For this reason, the rate of heat transfer, q, is not a function of time, but a function of the material (k), and the spatial gradient (dT/dx).
Yes, [tex]\Delta T[/tex] is a key factor.cyrusabdollahi said:Ah, yeah...here we go. Time is a factor in the temperature distribution for semi-infinite solids.
I was thinking of lumped capacitance which ignores spatial distributions within the material.
Still though, these equations http://www.hexoloy.com/hexoloy_data-sheets/technical-data/1006-6.pdf/attachment_view/file depend on the temperature difference [tex]\Delta T[/tex], no? It does not care how long it takes to get to some temperature difference. What matters is that you have a maximum allowable temperature difference.
Moonbear said:I also can't recall if the Macs before the iMac had anything other than a display sleep.
Astronuc said:Yes, [tex]\Delta T[/tex] is a key factor.
