Why Do People Say That 1 and .999 Are Equal? - Comments
  • Context: Insights
  • Thread starter Thread starter Multiple_Authors
The discussion centers around the question of whether the repeating decimal 0.999... is equal to the integer 1. Participants explore various arguments, proofs, and counterarguments related to this mathematical concept, touching on topics such as geometric series, assumptions in proofs, and the implications of different number systems.
  • Some participants argue that many proofs claiming 0.999... equals 1 rely on unstated assumptions and are therefore non-rigorous.
  • One participant suggests that a rigorous proof can be constructed using geometric series, asserting that the sum of the series representing 0.999... converges to 1.
  • Others challenge the validity of accepting that 0.333... equals 1/3 in the context of the debate, questioning the consistency of such assumptions.
  • Several participants express skepticism about the proofs that conclude 0.999... equals 1, suggesting that they may be flawed or based on incorrect assumptions, particularly regarding surreal numbers.
  • There is a repeated inquiry about how different 0.999... and 1 might be, with some arguing that as more nines are added, the difference approaches zero.
  • One participant emphasizes the need to be cautious about labeling other proofs as incorrect without fully understanding their arguments.
  • Some participants assert that if a proof can be applied to surreal numbers and still concludes that 0.999... equals 1, it must be incorrect.
Participants generally disagree on the equality of 0.999... and 1, with multiple competing views presented. Some argue for their equality based on mathematical reasoning, while others firmly believe they are not equal, citing various assumptions and interpretations.
The discussion highlights limitations in the proofs presented, including reliance on specific definitions and assumptions that may not be universally accepted. There is also an ongoing debate about the implications of different number systems, such as surreal numbers, on the validity of the proofs.
  • #91
WWGD said:
Yes, maybe it is not the best example, but the point I wanted to make is that two things don't need to be strictly equal in order to be considered the same. It is more a " to the effects of what we are doing, these two expressions are equal" EDIT: Maybe non-trivial, i.e., non-identity isomorphisms would be a better example.
I was going to write that one could consider the distinction between numerals or formulas on the one hand and numbers on the other. It seems that the distinction you want to make is between exemplars of an equivalence class and the class itself.
6 of one, ##\frac{dozen}{2}## of the other.
Mathematics news on Phys.org
  • #92
MrAnchovy said:
To be fair, Isaac didn't say it was not a number. He just suggested that it might be easier to see that 0.9999... is the limit of the sequence 0.9, 0.99, 0.999, ..., and that the limit of that sequence is also equal to 1, than it is to make the jump from the recurring decimal to 1 directly.
That was the point. I understand it is a number, but the value of the number can be thought of the limit of that sequence. IMO, this is easier to comprehend, but as you said, it's a mater of opinion.
  • #93
Isaac0427 said:
Instead of thinking of .999... as a number, think of it as the limit of the sequence (.9,.99,.999,.9999,...) as n approaches infinity. That is what the 3 dots mean. The limit of that sequence as n approaches infinity is 1.
Here's another example: (1/0!)+(1/1!)+(1/2!)...=e, however if you stop the sequence at any value of n, the answer will not be e. Does this make sense?
yeah that does make more sense so what you saying is that .999... to infinity approaches the number 1 so close it is consideribly the same number is that what you are saying ?
  • #94
WWGD said:
@Kegan It is not .999 , it is .9999... with an infinite string of 9s.
yeah I Know i just forgot the...
  • #95
No, .999... doesn't approach 1 -- it is exactly equal to 1.
The limit of the sequence {.9, .99, .999, ...} is 1, which means the farther you go in the sequence, the closer a number in the sequence is to 1.
BTW, it's redundant to write "to infinity" after .999... The dots (an ellipsis) already means that the 9 digits repeat endlessly.
  • #96
Ok that makes sense the more 9's you have the closer it is to the number 1 ,and I'm only eleven and language arts is not my best subject
  • #97
No, .999... is NOT a sequence. It is a number. The ... means that the value of the number is equal to the limit of the sequence (.9, .99, .999, ...). If it helps, you can think of it as the term of the sequence in which n=infinity. The value of this term, by definition, will be the limit of the sequence as n approaches infinity. If you do not understand this, look up limits.
  • · Replies 27 ·
  • · Replies 26 ·
  • · Replies 105 ·
14K
