Why do things bond in chemistry?
  • Thread starter Thread starter barthayn
    Bond Chemistry
Chemistry involves the bonding of elements, primarily driven by the interactions of electrons surrounding atomic nuclei. Atoms seek stability by filling or emptying their electron shells, with oxygen needing two additional electrons to complete its outer shell, which it acquires from hydrogen atoms. Bond formation occurs to create stable compounds, either through the transfer or sharing of electrons, leading to covalent or ionic bonds. The strength of these bonds is influenced by the electronegativity of the participating atoms. Understanding these fundamental concepts is crucial for success in chemistry.
barthayn
Hey, I will be taking a high school course in chemistry next week and I am wondering why things in chemistry work. No one taught me the reasons why it work, and therefore, never got good marks in it. Can someone tell me why certain elements bond in certain ways. For example, why does 2 H2 + O2 --> 2 H2O
Chemistry news on Phys.org
Much of what occurs in chemistry is the result of interactions between electrons. Electrons form shells around the nucleus. These shells have certain constant numbers of spaces available for electrons. Once the innermost shell is filled (2 spaces) the next shell begins to fill (8 spaces). In general, the most stable configuration is for the shells to either be filled or empty, not partially filled. If the shell is partially filled, the atom will tend to want to lose or gain electrons until it has either filled or emptied that shell. Oxygen has 6 electrons in its outermost shell, but wants to have 8. Hydrogen each have 1 and so oxygen can borrow two hydrogen atoms' electrons to complete its outer shell.
This is very general and simplified overview. If you want more details, you can start here:
http://en.wikipedia.org/wiki/Covalent_bond"
http://en.wikipedia.org/wiki/Chemical_bond"
In addition, this is a great site to learn more about science and math in general:
http://www.khanacademy.org/video/ionic--covalent--and-metallic-bonds?playlist=Chemistry"
Simplified, there are three types of bonds in chemistry: Ionic bonds, covalent bonds and metallic bonds.
Metallic bonds are bonds that metal-atoms form with each other.
If a covalent or ionic bond forms, this is dependant on the electro-negativity of the participants. The greater the difference between the two participants electro-negativity, ie their ability to attract each other due to charge, the stronger the bond is.
Thank you for all you help. It was all very useful.
The most basic process that is involved in chemistry is the bonding of chemical elements. Bonding can take place either as non-covalent bond or covalent bond.
Putting primary focus on covalent bonding, covalent bonds are basically chemical compounds formed by the sharing of pairs of electrons among involved atoms.
Simply the bond formation occurs to form a stable compound or we can say for stablization. Now further a question arise, Why stablization occurs ? Answer is that to complete their octet in Chemistry or to acquire stable configuration and this process may complete via complete transferring of electrons or via sharing of electrons or via donation of electrons that's why the bond formation takes place in chemical reactions.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
