Why do things burn up in the atmosphere but not in the ocean?
  • Context: High School
  • Thread starter Thread starter Feynstein100
    Atmosphere Ocean
The discussion revolves around the phenomenon of objects burning up upon entering the atmosphere versus their behavior when entering the ocean. Participants explore the mechanisms behind these processes, including friction, heat absorption, and the role of water in extinguishing potential fires. The conversation touches on theoretical and conceptual aspects of atmospheric entry and oceanic impact.
  • Some participants suggest that water extinguishes fires before they can start, referencing the mechanisms by which water is used to put out fires.
  • Others argue that atmospheric burnup is primarily due to compressing gases in front of an object, which does not occur in water due to its incompressibility.
  • It is proposed that water can absorb heat generated by friction, making it difficult for objects to reach combustion temperatures.
  • A participant questions whether meteoroids impacting the ocean actually fail to vaporize, referencing the Eltanin impact as a point of inquiry.
  • Some contributions highlight that objects do not hit the ocean at the same speeds as they enter the atmosphere, suggesting different dynamics at play.
  • There is a discussion about the forces involved when a supersonic object collides with water, which may lead to shattering rather than burning.
  • One participant raises a hypothetical scenario about increasing the density of air to a point where it behaves similarly to water during re-entry.
  • Another participant notes that at high enough collision energies, the distinction between solid, liquid, and gas may become irrelevant, potentially leading to plasma or supercritical fluid states.
Participants express multiple competing views regarding the mechanisms of burnup in the atmosphere versus the ocean. The discussion remains unresolved, with no consensus reached on the specific reasons for the differing behaviors.
Limitations include assumptions about the conditions of entry, the definitions of burnup and combustion, and the specific dynamics of impacts in different fluids. The discussion does not resolve the complexities of these interactions.
Feynstein100
As the title suggests, it just occurred to me that things don't burn up when entering the ocean as opposed to when entering the atmosphere. This seems counterintuitive because the explanation behind atmospheric burnup is usually attributed to friction. In that case, water should provide even more friction and thus make the object burn up even faster and yet that doesn't happen. So why not? Could someone please help me out?
It seems to me that the water will put out the fire before it started. Have you ever given consideration to the mechanism(s) whereby water is used to put out fires?
First, an object has to penetrate the atmosphere.
Second, the atmosphere gets gradually denser. Whereas, an impact on a body of water would generate a large sudden impulse.
How insightful! I hadn't thought of that at all. Thank you for enlightening an ignoramus like myself with your profound grasp of physics. I am truly blessed to be in the company of such extraordinary minds.
Feynstein100 said:
....because the explanation behind atmospheric burnup is usually attributed to friction...
For things like meteors entering the atmosphere the heating comes mostly from compressing the gases in front of them:
https://en.wikipedia.org/wiki/Atmospheric_entry
Since liquids cannot be compressed much, that mechanism plays less of role there. The other mechanism is friction, which exist in water too, but since water can also absorb a lot of heat and transport it away, it's not that easy to get warm this way.
You are welcome. Your sincere appreciation of my efforts encourages me to state two observations to enrich your enlightenment.
(a) The ocean contains substantial amounts of coolant water which will carry away any heat generated by friction before the temperature of the object rises to the point of initiating combustion.
(b) Even if it were possible to initiate combustion, the ocean does not contain enough free molecular oxygen to sustain it.
Actually, your first statement held all this explanation in truncated form.
It's always good to have 2way communication
Well done I say.
Wait a bit. Do we actually know that meteoroids impacting the ocean fail to vaporize?
https://en.wikipedia.org/wiki/Eltanin_impact
Things don't hit the ocean at 17,000 mph. Or if they do it's a lot worse than just heating up.
The forces that result when a supersonic object collides with water are so great, that water enters every crack or fissure in the surface, which shatters the object, and vaporises water that is displaced.
Water is used for cooling the reaction when fighting small fires. The steam produced will also displace oxygen from the fuel. However, at great enough compression temperatures the water is disassociated, and so the hydrogen and oxygen do react chemically with the object. You will not see that happening because you cannot be there at the time.
https://www.cws.com/en/fire-safety/news/extinguishing-metal-fires-how
"The ignition temperatures of metals such as aluminum, lithium, titanium, sodium or magnesium are relatively high at more than 500°C. A metal fire is therefore rare, but if it does occur, fighting it is complex. Accordingly, a metal fire is one of the most challenging fires, as conventional extinguishing agents (e.g. water) are ineffective or even lead to dangerous oxyhydrogen explosions. The reason for this is that the temperatures are immensely high at more than 2,000 °C. As a result, water would split into hydrogen and oxygen in the course of firefighting.
Remember: Water must not be used as an extinguishing agent for a metal fire! Foam or CO2 extinguishers are also not recommended.
Metal fires should be extinguished with special metal fire extinguishers. They have been developed for fire class D, i.e. fires involving titanium, aluminum or magnesium, and contain a special extinguishing powder. This prevents the chemical reaction in the event of a metal fire."
Since you are so learned, I'd like to ask you a further question. On one end we have re-entry in air which causes objects to heat up and melt/vaporize. On the other hand we have re-entry in water which causes them to mostly just slow down. But both are fluids. The question is merely that of phase and density. So if we were to make air denser and denser without turning it into a liquid, it follows that at some density, objects entering it will no longer burn up but simply slow down, just as they do in water. I ask you at what density this tipping point lies and how it can be calculated. An enlightened one such as yourself shouldn't have any problems with a trivial scenario like this.
  • Sad
Hmm good point. I guess gases don't have "surfaces" to provide impact like liquids do. At that point, the liquid acts more like a solid than like a gas since vaporization upon impact is what happens when solids collide with other solids as far as I know. I'm using the Barringer Crater in Arizona as reference here.
But the original question was regarding motion through a liquid, not instant vaporization upon impact. So while interesting, I don't think it's strictly relevant?
Again, what makes you think that water just causes them to slow down with no other ill effects?
At sufficient collision energies, the distinction between solid, liquid and gas becomes irrelevant. Everything becomes a plasma or a supercritical fluid.
Our every day imagination thinks of rocks falling in water at modest rates, slowed by viscous friction and cooled gently by the water. Or of a bullet penetrating the water and leaving a cavitation wake a few meters long
An impact at 17 km/sec or more involves energies such that the energy required to melt or vaporize rock or the energy required to vaporize or chemically disassociate water are small in comparison. We should not expect our intuitions to be accurate guides to the resulting behavior.
Thank you so much! This is exactly the explanation I was looking for. Why can't everyone be like you?
  • Sad
  • · Replies 69 ·
9K
  • · Replies 22 ·
  • · Replies 21 ·
  • · Replies 34 ·
  • · Replies 17 ·
