Why Do TV Cables Use 75 Ohm Impedance?
  • Thread starter Thread starter freydawg56
    Cables Ohms
2 replies · 3K views
freydawg56
we learned it could be a trade off between loss and flexibility. Because if it was around 50 ohms or so it would be too thick of a wire.
and the we learned the minimum loss is around about 77 ohms.
What do you guys think.
Many years ago I recall calculating the optimum impedance and found ~77 ohms to be lowest attenuation for a fixed coax OD and dielectric type (solid, foam, etc.). The minimum attenuation impedance may depend on the propagation velocity (i.e., dielectric type). As I recall, at other impedances the skin effect losses on the center conductor were higher. Foam polyethylene dielectric is better than solid. See
http://www.dxzone.com/cgi-bin/dir/jump2.cgi?ID=14693
Bob S
The real reason is that 75 ohms is closer to the real part of the impedance of a dipole at around 73 ohms.
