Why do we multiply probabilities for AND events?
  • Context: High School
  • Thread starter Thread starter adjacent
    Probability
19 replies · 3K views
adjacent
Probability, The "AND"
Two coins are tossed.Find the probability of obtaining a hear OR a tail
Ans:P(head)+P(tail)
=1
I understand this
Again he tosses the coins.This time,what is the probability of obtaining a Head AND a tail?
This time we multiply, P(head) X P(tail)
=1/4
But why do we multiply?What's the logic?
P.S I understand the difference between AND and OR.
hi adjacent! :smile:
the logic is that if the two events A and B are independent then we multiply the probabilities for AND:
P(A and B) = P(A)*P(B)​
if the two events A and B are mutually exclusive (non-everlapping), we add the probabilities for OR:
P(A or B) = P(A) + P(B)​
if the problem doesn't easily split into mutually exclusive events, then you may have to divide it up first
for example, with two coins each tossed once, there are four mutually exclusive events:
HH HT TH and TT​
P(head AND tail) = P(HT OR TH) = P(HT) + P(TH) = 1/4 + 1/4 = 1/2
P(head on the first die AND tail on the second die) =P(head on the first die)*P(tail on the second die) = 1/2*1/2 = 1/4
(and P(head OR tail) = P(everything), so that's easy!
P(head on the first die OR tail on the second die) =P(HT OR HH OR TT) = 1/4 + 1/4 + 1/4 = 3/4)
You are interpreting the phrase "a head or a tail" to refer to a sample space where an outcome is a single flip of a coin. You are interpreting the phrase "a head and a tail" to refer to a sample space where an outcome is 2 flips of a coin. So you are dealing with two different sample spaces.
I suggest you try to phrase your question using an example where the "And" and "Or" of events uses events that are in the same sample space.
What do you mean by Sample space?
I am using the same 2 coins over and over again.
And @tiny-tim
Thank you,but..
If the possible outcomes are HH HT TH TT,
then the probability of A head AND a tail should be 1/2
Then how is it 1/4? (1/2*1/2)
it isn't!
(i assume you mean the probability that, looking at the two coins, you see one head and one tail)
are you confusing it with the different problem of the probability of a head on the first coin and a tail on the second coin (which are independent)? :wink:
it isn't!
Is specifically mentioning the head on the first coin and the second coin important?
If so,What can be the answer for the question:What is the probability of obtaining a head and a tail?
(No coins mentioned)
there are only two faces showing
so "a head and a tail" must mean one head and one tail
that's either HT or TH
(if there were three coins, "obtaining a head and a tail" would mean at least one head and at least one tail, ie HHT HTH THH HTT THT or TTH)
yes, that would be only HT instead of HT or TH
But according to AND rule,
Probabilities of H and T is 1/4 since
P(H) =1/2 .
P(T) =1/2
1/2*1/2=1/4
tiny-tim said:
i don't understand what your H and T are :confused:
(since there are two coins)
H is head and T is tail.So Probability of H and T means Either HT or TH.
So that's 2/4=1/2 :confused:
yes, P of one head and one tail = P(HT OR TH)
so that's P(HT) + P(TH) = 1/4 + 1/4 = 1/2, as you say
but i don't understand what you meant by the following …
P(H) =1/2 .
P(T) =1/2
1/2*1/2=1/4
tiny-tim said:
but i don't understand what you meant by the following …...
___________________
I was just thinking of applying the AND rule without OR rule.
Like this:
Q-Find the probability of obtaining a Head AND a Tail.
A coin has two sides of which one side is Head ,So:1/2 is the probability of obtaining a Head.
A coin has two sides of which one side is Tail ,So:1/2 is the probability of obtaining a Tail.
So The probability of obtaining a Head AND a Tail is 1/2*1/2
=1/4
I know I am wrong somewhere. :frown:
but if you talk about one coin, you must always say which coin you mean
on which coin? :confused:
(yes, i know it's the same on either coin, but you have to specify which coin or you can't go onto the next step)
let's try this …
there are four events each of which has probability 1/2 …
P(1=H) = P(1=T) = P(2=H) = P(2=T) = 1/2 …
which of those four events were you trying to combine to find "the probability of obtaining a Head AND a Tail"? :smile:
Let's go to the first Question in the OP.
"He tosses the coins.What is the probability of obtaining a Head AND a tail?"
So that means no coin is specified.
The question in the OP was ambiguous. Does it mean
  • What is the probability of obtaining heads on the first flip and tails on the second or
  • What is the probability of obtaining one heads and one tails on the two flips?
With the first interpretation, the answer is 1/4. With the second, it's 1/2.
Your use of the "and rule" is incorrect. What is true is that if P and Q are independent events, then the probability that P and Q happen in that order is P(P)P(Q). The probability that Q and P happen in that order is P(Q)P(P). The probability that P and Q happen in either order is P(P)P(Q)+ P(Q)P(P)= 2P(P)P(Q)
Thank you so much everyone,I have got the answer now.I was just starting with probability.
