Why do we need Newton's First law? And how the First law works?
33 replies · 10K views
DrStupid said:
Can you give me an example that violates the first law?
When the particle begins to change its rectilinear motion at some instant ##t_1## while the acceleration at this instant vanishes.
For example, according to the 2nd law, particle put at rest on top of a sphere at instant ##t_0## may begin to change its velocity at any subsequent time ##t_1##. The 2nd law does not determine ##t_1##.
According to the 1st law, the particle will stay put.
To my knowledge the first law and the original wording of the second law differ in a single special case only: In contrast to the first law
[itex]F = \dot p = m \cdot \dot v + v \cdot \dot m[/itex]
allows accelerations without force for
[itex]\dot v = - v \cdot \frac{{\dot m}}{m} \ne 0[/itex]
I don't know if this was intended by Newton but this means that the use of forces for open systems might be problematic.
The second law is not
F = \dot{m}v + m\dot v.
It is
F = m\dot{v}.
In the last form, the 2nd law applies also to systems with variable mass.
The form ##F=\frac{dp}{dt}## is correct only if in addition, ##m## is assumed constant.
DrStupid said:
Show me your calculation.
I made a mistake above, the particle has to be put on a dome with special shape,not sphere. Check out John Norton's calculation:
http://www.pitt.edu/~jdnorton/Goodies/Dome/
Norton argues that actually the first law is valid even here, but he uses different "1st law" than the one Newton wrote. I only say that Newton's first law predicts something that Newton's 2nd law does not: that the particle will stay at the top. But it shows that Newton's first law is different kind of law: it is not a mathematical equation, but causality statement. Unfortunately, it is impossible to check this distinction experimentally.
According to the original wording of the second law
http://cudl.lib.cam.ac.uk/view/PR-ADV-B-00039-00001/46
and the definition of momentum
http://cudl.lib.cam.ac.uk/view/PR-ADV-B-00039-00001/26
it is.
Yes, if you are making logical conclusions based on these two statements only.
But Newton wrote a whole book on this. In the section on definitions you cited, he deals with "body", which most of the time means that mass is assumed constant.
I did not read whole of Newton's book, but I am sure he did not meant actually to include the term ##\dot{m}v## from the derivative of momentum as a part of the equation of motion. That would lead him to incorrect results and I'm sure he would check before publishing them.
His 2nd law is thus correct only if in addition mass of the body is assumed to be constant, something he forgot/did not care to say or he said it elsewhere.
It seems he missed the initial condition ##r_0=0##. I get the additional solution
[itex]r = \frac{{t{}^4}}{{144}}[/itex]
Edit: Now I got it. He mixed the time-dependent solution for the initial condition ##r(T) = 0## with the trivial solution ##r(t) = 0## and spliced them at ##t = T##. The resulting hybrid is still a solution of the differential equation and meets the initial condition ##r(0) = 0##.
There is either no force and no acceleration (for ##r=0##) or both force and acceleration (for ##r \ne 0##). Whether this is a violation of the first law or not seems to be a matter of interpretation.
Yes, the first law says that force is the only cause of changes in motion. This is the qualitative definition of force. As bcrowell already mentioned this was important to distinguish Newton's force from Aristoteles' force. According to Aristoteles force was required to keep the state of motion. According to Newton force is required to change the state of motion. That's what the first law is about.
The second law does not care about causality but gives a quantitative definition of force.
The second law is not limited to bodies. Even if the quantity of matter (we better do not use the term "mass" here in order to avoid possible confusions with rest mass) of a body is constant, a system consisting of a variable number of bodies may have a variable quantity of matter. As the second law is not limited to bodies it is not forbidden to apply it to such systems. But as already mentioned it might be problematic to use the second law this way. It only works if you do not mix forces for constant and variable quantity of matter.
To my knowledge Newton didn't refer to this topic. I guess he started from conservation of momentum and stopped with the conclusion that the sum of all alterations of momentum need to be zero (that's what the second and third law say). In that sense his laws of motion are universal and also work for open systems or even for different transformations. Thus is wasn't necessary to go into further details at this point. Everything else can be derived from his definitions for particular conditions.
That's the result for closed systems and Galilean transformation. That's the usual situation in classical mechanics (that's why it is so popular). But other condition may return other results.
