Gravitron
- 21
- 0
Why does a magnetic field remain stationary when rotated around its polar axis?
The discussion centers on the behavior of magnetic fields, particularly whether a magnetic field remains stationary when a magnet is rotated around its polar axis. Participants explore theoretical implications, experimental setups, and historical context related to this question.
Participants do not reach a consensus on whether a magnetic field rotates with a magnet. Multiple competing views remain, with some arguing for the rigidity of magnetic fields while others challenge this notion.
Participants note that the definitions of magnetic fields and their behavior are complex and may depend on specific experimental conditions. There is also mention of unresolved mathematical steps and the historical context of the debate.
Gravitron said:Why does a magnetic field remain stationary when rotated around its polar axis?
Relay said:In response to pallidin's message #7, the iron disk does not rotate. Now what?
bjacoby said:If you mean "does a magnetic field rotate with a magnet that is rotated about it's axis" (as in say a Faraday unipolar generator with the magnets glued to the to rotating disk), the answer is that as far as I know it has never been established by experiment one way or the other which is true (rotates or not). In the case of a Faraday generator both cases give the same answer (for different reasons). However the question has been debated since the days of Faraday. A number of experiments have been proposed to make a determination (through the use of electrostatic measurements) but I've never seen a report where they were actually performed.
pallidin said:Then it is experimentally shown that the polar magnetic axis of a magnet does not rotate with a rotating magnet, else the iron disk would rotate.
Relay said:Why do you assume that a magnetic field is rigid and must rotate the iron disk?.
Look up Aharonov Bohm effect. See the figure with the electron beam and two slits inRelay said:It seems to me that nothing of any real importance about magnetism has been discovered in the last 100 years. The creation of Neodium magnets only gives us a stronger magnet but no new understanding of magnetism. If there are new facts, I wasn't able to find them on the internet.
Relay said:Bob S thanks for that link. (message #14) It was an excellent read, not that I fully understand it. It does however bring up Young's double slit experiment for more scrutiny. I've always believed that the results of Young's double slit experiment were interpreted incorrectly. I thought that the slits themselves caused the photons or electrons to deflect and show an interference pattern. When I say interference pattern I'm talking about what is observed on the view screen. The interference pattern might be a direct result of the particles interacting with the slit wall atoms. The solenoid in the Aharonov Bohm effect might be affecting the electrons in the slit walls and thereby affecting the interference pattern. The Aharonov Bohm effect could be detecting a new property of magnetism not previously observed. Or mabe the magnetic fields within the solenoid do spin and affect nutrinos which in turn affect the slit atoms.
Anyhow to get back on topic; I believe that a magnetic field is not stationary. Therefore rotating a magnet around its polar axis will have no effect.
Relay said:... I believe that a magnetic field is not stationary. Therefore rotating a magnet around its polar axis will have no effect.
Vanadium 50 said:A field is a number (or set of numbers) defined for each point in space. As such, it's difficult to even define what it means for a field to move.
