2025 Award
- 17,259
- 10,724
Some idea of the complexity of the subject can be gained from the contents of the book: Lötzsch, Detlef; Seeboth, Arno; Thermochromic and Thermotropic Materials - Pan Stanford (2013).
Contents.
1. Thermochromic Materials Based on Reflection 1
1.1 Light Reflection 1
1.2 Liquid Crystals 3
1.2.1 Cholesteric Liquid Crystals 3
1.2.1.1 Cholesteric phase of rod-like molecules 6
1.2.1.2 Discotic cholesteric phase 7
1.2.1.3 Induced cholesteric phases 8
1.2.1.4 Lyotropic cholesteric phases 13
1.2.1.5 Temperature dependence of the helical pitch 15
1.2.1.6 Cholesteric polymers 17
1.2.1.7 Cholesteric polymer networks 21
1.2.2 Smectic Liquid Crystals 23
1.2.3 Blue Phases and TGB Phases of Chiral Liquid Crystals 24
1.3 Crystalline Colloidal Arrays 27
1.3.1 Crystalline Colloidal Arrays Embedded in Gel Networks 27
1.4 Semiconductor to Metal Transition of Inorganic Materials 31
2. Thermochromic Materials Based on Light Absorption 39
2.1 Light Absorption 39
2.2 Inorganic Thermochromic Materials 41
2.2.1 Solid-State Thermochromism of Inorganic Materials 41
2.2.2 Thermochromism in Solution of Inorganic Materials 44
2.3 Metal Organic Thermochromic Material 45
2.3.1 Thermochromism of Metal Organic Compounds in Solid State or at the Melting Point 45
2.3.2 Thermochromism of Metal Organic Compounds in Solution 47
2.3.3 Thermochromism of Metal Organic Gel Networks 49
2.4 Spiroheterocyclic Compounds 51
2.5 Salicyl-Schiff Bases 55
2.6 Overcrowded Ethenes 56
2.7 Conjugated Polymers 58
2.7.1 Thermochromism in Polythiophenes 58
2.7.2 Thermochromism in Poly(Phenylene Vinylenes) 60
2.7.3 Thermochromism in Polydiacetylenes 61
2.7.3.1 Thermochromism of polydiacetylenes in solid state 61
2.7.3.2 Thermochromism of polydiacetylenes in liquid crystalline state 64
2.7.3.3 Thermochromism of polydiacetylenes in solution 65
2.7.3.4 Thermochromism of polydiacetylene gels 66
2.7.4 Thermochromism in Other Conjugated Polymers 66
2.8 Thermochromism by Leuco Dyes 67
2.8.1 Thermochromism by Leuco Dye–Developer Systems 69
2.8.2 Thermochromism by Leuco Dye–Developer–Solvent Systems 72
2.9 Thermochromism by Charge Transfer Complexes 77
2.9.1 Thermochromism of Charge Transfer Complexes in Solid State 77
2.9.2 Thermochromism of Multilayer Films Due to a Ligand to Metal Charge Transfer 79
2.9.3 Thermochromism of Charge Transfer Complexes in Solution 80
2.10 Indicator Dyes Incorporated into Hydrogel Networks 80
2.11 Thermochromism of Cyano-Substituted Oligo (p-Phenylene Vinylene) Dyes in Polymer Matrices 85
2.12 Thermochromism Based on Surface Plasmon Absorption 87
2.13 Miscellaneous Thermochromic Composites 94
2.13.1 Thermochromism on Silica Gel Based on pH Indicator Dyes 94
2.13.2 Thermochromism of pH Indicator Dyes Incorporated in Polymer Matrices 94
2.13.3 Thermochromic Sol–Gel Material 96
3. Thermochromic and Thermotropic Materials Based on Light Scattering 105
3.1 Light Scattering 105
3.2 Thermochromic Gel Networks Based on Light Scattering 109
3.3 Thermotropic Polymer Blends 111
3.4 Thermotropic Gel Networks 112
3.4.1 Thermotropic Gel Networks Based on the Appearance of Liquid Crystalline Phases 113
3.4.2 Thermotropic Gel Networks Based on Phase Separation 115
3.4.2.1 Phase separation in chemically cross-linked polymer networks 116
3.4.2.2 Phase separation in physically cross-linked polymer networks 116
3.4.3 Hybrid Thermotropic and Thermochromic Gel Networks 127
3.5 Aggregation in Aqueous Polymer Systems 131
3.6 Thermotropic Casting Resins 133
4. Application of Thermochromic and Thermotropic Materials 139
4.1 Thermometers and Temperature-Indicating Labels 140
4.1.1 Thermography 143
4.2 Thermo-Sensitive Paper 143
4.2.1 Thermochromic Inks 144
4.3 Thermochromic Thermoplastic Polymers 146
4.4 Thermochromic Thermosetting Polymers 159
4.5 Sun-Protecting Glazing 166
4.5.1 Sun-Protecting Glazing Based on Thermotropic Materials 167
4.5.1.1 Glazings containing a layer of a thermotropic hydrogel 168
4.5.1.2 Glazings containing a layer of a thermotropic polymer blend 171
4.5.1.3 Glazings containing a layer of a thermotropic casting resin 172
4.5.2 Sun-Protecting Glazing Based on Thermochromic Materials 183
5. Active Triggering and Energetic Characterization of Thermotropic and of Thermochromic Materials 193
5.1 Active Triggering of Thermotropic and of Thermochromic Materials 193
5.2 Energetic Characterization of Thermotropic and of Thermochromic Materials 199
6. Concluding Remarks 207
Index 209
Contents.
Index 209
