Why does a stationary magnet cause plasma to spin ?
The discussion centers on the phenomenon of plasma spinning in response to a strong Neodymium magnet, specifically a four-inch long magnet, placed above a plasma beer jug. Participants clarify that the spinning is due to the Lorentz force, which acts on charged particles in a magnetic field, causing them to move in circular paths. The Lorentz force equation, F = q(E + vxB), describes this interaction, emphasizing that the force is perpendicular to the particle's velocity, resulting in circular motion. The conversation also touches on the application of the Lorentz force in CRT displays and NASA's pulsed plasma drive.
  • Understanding of the Lorentz force and its equation F = q(E + vxB)
  • Basic knowledge of plasma physics and charged particles
  • Familiarity with magnetic fields and their effects on charged particles
  • Awareness of applications of the Lorentz force in technologies like CRT displays
  • Research the principles of plasma physics and its behavior in magnetic fields
  • Study the Lorentz force in detail, including its mathematical derivation and applications
  • Explore the concept of gyroscopic motion and how it differs from the effects of the Lorentz force
  • Investigate NASA's pulsed plasma drive and its operational principles
Students of physics, educators, and anyone interested in the interaction between magnetic fields and charged particles, particularly in the context of plasma behavior and applications in technology.
CyanGrinMonk
Hello, this is my first post, i only have what we call an O Level Physics here in the UK, but i have a strong layperson's interest in the subject, so I'm looking forward to picking the brains of the more educated people here.
My friend's professor showed him something very interesting, all to do with a plasma beer jug and a strong magnet.
The professor showed the student that, when he held a very large and strong (probably four inches long and most of an inch in diameter, judging by the scale in the video) Neodymium magnet above the jug, the plasma started spinning.
My question is, does the plasma spin because the magnetic field is spinning, or is it due to some interaction between the magnet and the charged base plate ?
Here are two videos showing the effect (there is a third in slow motion but i can't find it right now) :
All the best,
Gary.
Welcome to the PF.
Check out the Lorentz Force at wikipedia or HyperPhysics. :smile:
Ahh, Lorentz force, as in the pulsed plasma drive NASA tested in 2000 ?
Blimey i didn't realize my photo would be my avatar, kind of throws a spanner in the works of my anagram user-name ;+}
Beats me. The Lorenz Force is F = q(E + vxB)
https://en.wikipedia.org/wiki/Lorentz_force
Your username is an anagram? I guess I need to look that word up again... :smile:
I don't understand how the Lorentz force could introduce spin, i thought it was like a vectored thrust ?
Unfortunately i haven't learned enough maths to fully understand the description of the Lorentz force in wikipedia or hyperphysics, though hyperphysics does a better job of explaining it to the layperson!
Fair enough. The key part of the Lorentz Force is that the force on a charged particle flying through a region of uniform magnetic field is at right angles to the velocity of the particle. So that makes the particle circulate around the lines of magnetic field -- kind of like swinging a mass around on a string. As long as the force is at a right angle to the velocity of the mass/particle, you get circular motion.
Does that make sense? The Lorentz Force equation is just a simple mathematical way of describing now the force is acting at a right angle to the velocity of the particle, which makes it a force toward the center of the circle that the charges are circulating around. :smile:
Thanks berkeman, so it's kind of gyroscopic in nature ?
That explains it very well now i think about it, it's a uniform magnetic field, so when it's inserted vertically into the jar then the plasma constantly spins because the field is at right angles to all of the plasma around it?
Re: anagrams :
http://wordsmith.org
Great site for some wordplay :)
No, a gyroscope is a whole different thing. You can read about gyroscopes at wikipedia.
The most common use of the Lorentz force is in CRT TV displays. There is a varying magnetic field in the neck of the CRT that deflects the electron beam to paint the surface of the display with the varying intensity beam to form the 2-D picture. The Lorentz Force is what deflects the charged e-beam at right angles to the magnetic field to cause the deflection. :smile:
Thanks for the clarification, i never knew it was the Lorentz force that deflected the beams.
I'm wondering now why his professor didn't propose Lorentz force as the cause, it seems to expain it completely, i suppose the plasma only spins due to it's containment?
The guy says the magnetic field is spinning. They is just plain wrong. Weird video.
  • · Replies 18 ·
  • · Replies 42 ·
  • · Replies 22 ·
  • · Replies 17 ·
13K
