1. The materials of your typical crate and typical drywall are vastly different. Thus, both are able to withstand different amounts of force.
2. The typical crate, when being acted on by a force, has only one obstacle to overcome before it moves position: frictional force. Typically, a crate's materials are strong enough to withstand an outside force, which allows the crate to overcome the frictional force before breaking, deforming, etc. (frictional force is the force occurs when two objects are in direct contact with one another [EX: a cube of steel on concreate has a downward force "W" which is it's mass*gravity and the concrete is exhibiting a normal force "N" on the cube of steel. this is Newton's 1st Law. Frictional force always opposes the motion of the force. So if I apply a force on the steel block parralel to the surface of the concrete that is great enough, I will overcome the friction between the two objects.)
3. A typical drywall is anchored/fixed at the top and bottom. It is not constructed to withstand large forces. Therefore, when a force is applied to it, it will not be able to overcome a frictional force before breaking, deforming, etc.
I'm no expert, but I think that It really comes down to the design, strength of materials, and whether or not it is fixed.
