Why does air speed change in different sized tubes?
  • Thread starter Thread starter DeBruyn
    Air Speed Tube
The discussion centers around the equation of continuity, which explains that air moves faster through a smaller diameter tube compared to a larger one when maintaining a constant airflow. This principle is rooted in the conservation of mass, stating that the volume flow rate remains constant across an air stream. A pressure drop in a pipe can also affect air velocity, with larger diameters potentially resulting in higher speeds under certain conditions. The conversation shifts to the implications for singing, emphasizing the importance of relaxed throat muscles and sufficient airflow for producing desirable tones. The discussion concludes by exploring fluid dynamics concepts, such as Reynolds Number, in relation to maximizing the distance a liquid can be propelled from a straw.
DeBruyn
Hello,
I was looking for the name of the principle which governs the following-
given a constant air flow- air moves faster through a tube with a smaller diameter than a tube with a larger diameter.
Wouldn't you like to know what this has to do with singing?
Thank you
Debruyn
DeBruyn said:
Hello,
The name of the principle is the equation of continuity (or the principle of mass conservation).
The conservation of mass leads, for an incompressible fluid, to the equation of continuity: the volume flow rate must be constant at all points in an air stream. The volume flow rate is given by Volume/time = Area x Speed. Thus, for a given flow rate, air will flow faster through a tube with smaller diameter.
Sure!
DeBruyn - Air speed in a tube is generally looked at as a phenomenon which is caused by a difference in pressure. It is not forced by some volumetric flow rate, though I suspect that's what you had in mind.
In fact, if you have a pressure drop in a given length of pipe, say a 100 foot long section of pipe and a 5 psi drop, the larger diameter pipe will have a significantly higher velocity, even though the pressure drop and length of pipe are the same.
Sure!
One of the main aims in classical singing is to keep the muscles of the neck relaxed thereby keeping the throat open and relaxed as opposed to constricted and tense. If a singer is not providing sufficient airflow- the body will automatically try to help out in the process by constricting the throat- thus concentrating the airflow in order to make more out of the airflow which is provided. This does not create a desirable sound! Providing the correct airflow is imperative for the most efficient tone.
Thank you for your help!
Blowing through a straw
So you get a pop and straw, fill up your mouth with pop (ready to blow at someone), and blow hard. The pop spews out then it is all gone and air follows. Can you maximize the distance the pop flies out? In fluid mechanics there is a factor called a Reynolds Number. It basically talks about the size of pipe and pressure will cause the fluid to glide across fluid easily, or become turbulent and begin spiraling. Taking also into account the fact that pop is still stuck in the straw and not fixed in one point, air that follows will be interrupted. The interruption will always be changing its shape and position, so how can you maximize it? If you can get the pop to become turbulent for a while to help build up pressure, can you then increase the velocity at which it comes out of the straw, and therefore add to the distance it flies?
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
