Why does Couette flow have a linear velocity profile?
167 replies · 44K views
Red_CCF said:
I was able to get the x(t) equation but unable to get the form for the work equation. For the work equation, are we solving:
[tex]-W=\int{C(\frac{dx}{dt})^2dt}+\int{kx\frac{dx}{dt}dt}[/tex]
where we integrate t from 0 to infinity? If so I probably made some arithmatic errors during expanding/simplification.
Well, it's easier to integrate the following:
[tex]-W=A\int_0^∞{P_{ext}(t)\frac{dx}{dt}dt}[/tex]
You can get additional simplification by integrating by parts:
[tex]P_{ext}(t)\frac{dx}{dt}dt=d(xP_{ext})-x\frac{dP_{ext}}{dt}dt[/tex]
With regards to the work equation, is the area A supposed to be squared?
Ooops. You're right. I'm missing a factor of A. Thanks.
In discrete step, we integrated each step from t = 0 to infinity, essentially saying that each step takes infinite time. As we take the number of steps n to approach infinity, are we basically saying that the process will take ∞2 to complete?
In Post #146, I discussed the fact that the "effective" amount of time to complete a single discrete step is C/k. Please read over my post carefully. If you wait until t = 4C/k, the displacement will be 98% of the displacement you get at infinite time. It won't matter significantly if you start the next discrete step then, or wait an infinite amount of time. So the nominal time for a sequence of n discrete steps will be nC/k (or 4nC/k if you prefer).
What is τ physically?
τ is a constant we are using to parameterize how fast we vary the external pressure. A small value of τ means we are varying it very rapidly, and a large value of τ means we are varying it slowly. Physically, τ is the amount of time it takes for Pext to rise 63% of the way from PEi to PEf.
I see that it is synonymous with the number of steps (when pressure is increased in discrete steps), but how does one measure/control this variable?
As I said in several previous posts, we can control the applied external pressure variation Pext(t) to be any function of time we desire.
Chet
Does the number of discrete steps have any bearing on the time it takes to reach 98% displacement? Here it appears that regardless of step size the time to reach 98% displacement is constant at 4C/k, which I find a big strange since intuitively I thought that decreasing the step size would reduce the time to reach equilibrium per step.
Theoretically, if one desires to reach complete equilibrium before the proceeding to the next discrete step, then we must wait until t -> ∞, such that in essence a "perfect" quasistatic process using discrete steps must take t = ∞2?
Thank you
Actually, no. Taking a smaller step reduces the driving force for the change, such that, irrespective of the size of the step, each discrete step takes exactly the same amount of time to reach 98% displacement. You can validate this by considering your equation for x(t). See what you get when you substitute t = 4C/k into the equation.
I submit that if you wait only 4C/k in each discrete step before starting the next step (rather than waiting an infinite amount of time), you will get results for the total work and the work to overcome damper forces which are not significantly different from the results for waiting an infinite amount of time. If you don't believe me, try solving this case and see what you get. The point I'm making is that the "effective time" to complete each step is only on the order of C/k.
I'm running out of ideas on how to explain this any better.
Chet
Is this because x(t) and hence dx/dt is linearly proportional to the step size PEf - PEi, so the process is faster with larger step sizes?
Chet
What is the actual penalty of not doing the process to full completion (t = ∞)? The only one I can think of is that the final desired pressure at each step is not reached, so performing to 4C/k only get to 98% of Pef-Pei in each step. Does this affect the reversibility of the process? For instance if we perform the process with n = ∞ steps, does performing the process in t = 4nC/k create irreversibilities that wouldn't exist otherwise?
With regards to quasistatic processes in general, the model we had assumed an insulated system. Is it correct to say that an insulated system with internal irreversibilities cannot perform a thermodynamic cycle due to the fact that system entropy can never return to its original value?
Thank you
Yes. That's the driving force.
In the limit of n→∞, t = 4nC/k is also infinite. Anyhow, I meant to say that, in the very last discrete step, you let the system fully equilibrate.
Not in the limit of n→∞; then, you achieve the same value for the work (i.e., the reversible work).
Not in the limit of n→∞.
If the system is insulated, even if the process is carried out reversibly, you can't achieve a cycle. The most you can do is backtrack reversibly to the original state, with no net work done. In that case, you will regain the original value of the entropy. But, if there are irreversibilities, you won't even be able to get back to the initial state.
Chet
So if we perform n = finite cycles at t = 4C/k, we would not get the desired final pressure until the last step (which is on purposely made bigger?) but in the limit of n→∞, since we are performing ∞ steps at t = 4C/k the "loss" at each step is made up for?
With regards to C and k, in a real spring-damper system these are physical properties, but do their values depend on how the process is performed when using them to model a piston compression? I ask because I was wondering about the 4mk/C2 = small condition (assuming piston has mass) to prevent piston oscillation in each step.
Chet
How come reversible backtracking is not considered a cycle? I had thought that a cycle is just a series of processes that brings the system back to the initial state?
Thank you
You don't need to ask me to answer this question. This is something you can do for yourself. Redo the analysis for n=2, starting the second step at t = 4C/k rather than at ∞ and compare it with what you got when you let the first step go all the way to equilibrium. Doing this reanalysis should only take you about 5 minutes.
Before we throw the piston mass back into muddy the water, let's get the cases of zero piston mass straightened out.
I guess I would consider adiabatic reversible backtracking a degenerate cycle, since no work would be done and no heat would be transferred.
From previous results for n = 2 where both stages go from t = 0 to infinity
[itex]W_{spring} = \frac{P_{Ef}^2-P_{Ei}^2}{2k}[/itex]
[itex]W_{damper} = \frac{(P_{Ef}-P_{Ei})^2}{4k}[/itex]
For the new first step from t = 0 to 4C/k and second step for t = 0 to infinity (assuming we go to equilibrium in the second step and not to 4C/k)
First step:
[itex]W_{spring} = 0.982\frac{(P_{Ef}+P_{Ei})^2-4P_{Ei}^2}{8k}[/itex]
[itex]W_{damper} = 0.982\frac{(P_{Ef}-P_{Ei})^2}{8k}[/itex]
I'm assuming the second step starts at 0.982(P_{Ef}+P_{Ei})/2 where the first step left off to P_{Ef}
Second step:
[itex]W_{spring} = \frac{4P_{Ef}^2-0.982^2(P_{Ef}+P_{Ei})^2}{8k}[/itex]
[itex]W_{damper} = \frac{(0.509P_{Ef}-0.491P_{Ei})^2}{2k}[/itex]
Sum
[itex]W_{spring} = \frac{P_{Ef}^2-0.982P_{Ei}^2-0.00443(P_{Ef}+P_{Ei})}{2k}[/itex]
[itex]W_{damper} = \frac{1.01P_{Ef}^2+0.974P_{Ei}^2-1.9816P_{Ef}P_{Ei}}{4k}[/itex]
So it looks like the difference is:
[itex]W_{diff,spring} = \frac{-0.0177P_{Ei}^2+0.00443(P_{Ef}+P_{Ei})}{2k}[/itex]
[itex]W_{diff,damper} = \frac{0.01P_{Ef}^2+0.026P_{Ei}^2-0.0184P_{Ef}P_{Ei}}{4k}[/itex]
Numerically they do not appear to be too significant, since the coefficients are all < 0.03.
Thank you
As you pointed out in a recent post, we have been missing a factor of A2 in these equations for the work.
First step:
I'm proud of you for attacking this problem so aggressively, but this assumption is not correct. The second step starts out at (P_{Ef}+P_{Ei})/2 where the first step left off; it is the displacement x that starts the second step at a smaller value by 1.8%. In the second step, the displacement will be 1.8% larger than before.
Second step:
Sum
It is easier to do this analysis by determining the change in the total amount of work, rather than the individual contributions of spring and damper. During the first step, the pressure is constant at (P_{Ef}+P_{Ei})/2 , and during the second step, the pressure is constant at P_{Ei}. But the displacement is smaller in the first step, and larger in the second step. The total final displacement will be the same as before. The change in the total amount of work will be all added damper dissipation work. See what you can come up with by trying this simpler approach. It should be proportional ato (P_{Ef}-P_{Ei})^2.
Chet
In my previous reply, I meant to say that the pressure in the secomd step is PEf, rather than PEi.
Chet
I got the pressure terms mixed up and forgot that the pressure terms are applied pressure and not related to the cylinder gas pressure.
Chet
For total work I got:
[itex]W = \frac{A^2}{4k}[(e^{-4}-3)P_{Ef}^2-(e^{-4}-1)P_{Ei}^2+2P_{Ei}P_{Ef}][/itex]
and the extra damper work should be
[itex]e^{-4}P_{Ef}^2-e^{-4}P_{Ei}^2[/itex]
What is this extra work used to overcome?
Thank you
This is not what I got. I worked it this way:
W =A (P1Δx1 + P2Δx2)
where
[tex]P_1=\frac{(P_{Ef}+P_{Ei})}{2}[/tex]
[tex]P_2=P_{Ef}[/tex]
[tex]Δx_1=A\frac{(P_{Ef}-P_{Ei})}{2k}(1-e^{-4})[/tex]
[tex]Δx_2=A\frac{(P_{Ef}-P_{Ei})}{2k}(1+e^{-4})[/tex]
For the extra damper work, I got:
[tex]A^2\frac{(P_{Ef}-P_{Ei})^2}{4k}e^{-4}[/tex]
This extra work does not overcome anything. It is additional work that has to be done to deform the damper, which dissipates more mechanical energy because the velocity of the piston is higher throughout the second step (and the rate of dissipation of mechanical energy by the damper is proportional to its velocity squared).
Chet
where
Was the total work I calculated correct? I actually had a typo and the extra damper work should have been
[tex]\frac{A^2e^{-4}(P_{Ef}^2-P_{Ei}^2)}{4k}[/tex]
which is still different. The original total work when each step takes to t = infinity was:
[tex]\frac{3P_{Ef}^2-P_{Ei}^2-2P_{Ef}P_{Ei}}{4k}[/tex]
and I just found the difference between the two total work terms.
I computed this integral for total work. The first integral I did from 0 to 4C/k and the second from 0 to infinity.
[tex]W = ∫A(P_{Ef}+P_{Ei})/2dx + ∫AP_{Ef}dx[/tex]
[tex]dx = -\frac{A(P_{Ef} - P_{Ei})}{2C}e^{-kt/C}dt[/tex]
The e-4 term only shows up in the first integral for me from next to the product of the exerted pressure and pressure difference from dx/dt: (PEf - PEi)(PEf + PEi) = (PEf2 - PEi2) which is what I ended up with.
Another thing I found is that the total work in the second step was the same in this case as when the first step goes to completion, but it was not the case in your calculation.
Chet
The dx/dt equation in the second step doesn't appear to be different than that where the first step is performed to completion. How come the velocity of the piston is higher?
Thank you
You need to be very careful how you handle the differential equation for the second step. Don't forget that displacement from the first step is still continuing to occur when you raise the pressure in the second step. One way of getting the time-dependent displacement variation for the second step is to just treat it as a continuation of the first step. But the initial condition is not zero. Also, the differential equation during the time that the second step is occurring is:
[tex]\frac{dx}{dt}+\frac{k}{C}x=A\frac{(P_{Ef}-P_{Ei})}{C}[/tex]
Note that there is no factor of 2 in the denominator on the right hand side because we are continuing the solution from the first step, and, during the second step of the deformation, the driving force has jumped up to ##(P_{Ef}-P_{Ei})##. The initial condition for the second step is:
[tex]x\left(t=\frac{4k}{C}\right)=A\frac{(P_{Ef}-P_{Ei})}{2k}(1-e^{-4})[/tex]
When you get the solution to this set of equations for x, you subtract the solution for x(4k/C) to get Δx2(t).
I hope this mathematics makes sense to you. If not, I'll try to show you how to get the results in a different way.
Chet
There were a couple of errors in my previous post that I want to correct. The text and equations should have read:
[tex]x\left(t=\frac{4C}{k}\right)=A\frac{(P_{Ef}-P_{Ei})}{2k}(1-e^{-4})[/tex]
When you get the solution to this set of equations for x, you subtract the solution for x(4C/k) to get Δx2(t).
Note that the corrections involved changing 4k/C to 4C/k in two places.
Chet
I'm confused about why the RHS of the ODE is not divided by 2 since the initial pressure is (PEi + PEf )/2 and the final pressure is PEf. Also, is x(t) and Δx(t) equivalent?
Chet
Is initial condition equal to x1 (4C/k)? What I am confused by is why the initial position has a (1 - e-4) term as opposed to just e-4 such that [itex]x_2(0) = A\frac{(P_{Ef}-P_{Ei})}{2k}e^{-4}[/itex]. Intuitively I thought that in the limit where the first step is performed to completion, the initial position of the second step should approach 0 but in the above case it looks to approach [itex]A\frac{(P_{Ef}-P_{Ei})}{2k}[/itex] ?
I also noticed that the initial position of the piston for the second step is positive, is this to be consistent with the sign notation that x(t) is increasingly negative with compression and we are starting "above" zero?
After I obtain a general expression for x2(t), I substitute the above expression as x2(0) and integrate ∫PEfdx from 0 to infinity to obtain the work for the second step?
Thank you
I'm afraid I've gotten you very confused, hopefully not beyond recovery. In the previous two posts, I was trying to show how to do the integration to determine x in one fell swoop, starting from x = 0, so the second part of the deformation is just a continuation of the deformation in the first part. Even though the analysis is correct and leads to the correct result, it was not worth the confusion it has caused. So please disregard what I did in the previous two posts.
If this is the approach that works best for you (I like it better than my approach in the previous two posts), then let's continue with that. Regarding the sign, I'm using x positive if it is in the compression direction. So, the initial condition on x2, according to your approach, would be [itex]x_2(0) = -A\frac{(P_{Ef}-P_{Ei})}{2k}e^{-4}[/itex], and, in the differential equation for x2, you would include the factor of 2 in the denominator of the right hand side. So, if you solve the differential equation subject to this initial condition, what do you get?
Yes, but making sure that you make proper use of the initial condition that [itex]x_2(0) = -A\frac{(P_{Ef}-P_{Ei})}{2k}e^{-4}[/itex].
Sorry for all the confusion I caused.
Chet
Chet
The ODE looked like it was setup for the combined process but I wasn't 100% sure. So if I am isolating for the second step as below:
[tex]\frac{dx}{dt}+\frac{k}{C}x=A\frac{(P_{Ef}-P_{Ei})}{2C}[/tex]
After substituting [itex]x_2(0) = -A\frac{(P_{Ef}-P_{Ei})}{2k}e^{-4}[/itex] the x2(t) I get is:
[tex]x_2(t) = A\frac{(P_{Ef}-P_{Ei})}{k}[1-(e^{-4}/2+1)e^{\frac{-kt}{C}})][/tex]
After integrating the work I get for the second stage is:
[tex]W_2 = \frac{A^2(P_{Ef}^2-P_{Ef}P_{Ei})}{k}(e^{-4}/2+1)[/tex]
The work above is positive, which I'm guessing is due to the fact that compression is considered positive work? Also the x_2(t) equation is not divided by 2k as I had expected. I included the initial pressure as (PEi+PEf)/2 in the ODE and didn't find any calculation errors.
The extra damper work I got was positive and equal to the one you computed using the much simpler method:
Thank you
