Why does current flow when circuits with different reference potentials are connected?
fog37
TL;DR
Understanding the issue with ground loops
Hello,
When connecting different circuits together, the reference electric potential ##V_{ref}## (the ##0 Volt##) for each circuit should be the same electric potential so the potential at all other points is the same.
If circuit 1 has reference ##V_{ref1}## and circuit 2 has ##V_{ref2}## with ##V_{ref1}\neq V_{ref2}##, when the two reference potentials are connected, a current will flow along that connection...What is the problem with that? Does a return current always flow anyway along the ground/reference conductor?
thanks for any clarifications
Maybe this figure helps:
Diagram titled GROUND LOOP: two boxed devices joined by a signal wire, each grounded to earth at separate points, with a voltage source in one loop and an arrow labelled EXTRANEOUS CURRENT FLOW running through the earth connections.
The two Earth connection points are there solely for protection. However, if their electric potential is different, then it is like adding an extra circuit with an extraneous current in parallel to the main circuit (lower portion of the figure)...
DC source current is simply divided between wire and ground in proportion Rground/Rwire. In a well designed DC network this isn't an issue since allowed voltage drop is small and Rground>>Rwire. If local ground currents are sufficiently strong that may cause unwanted DC corrosion effects.
Situation is more complicated in AC large networks due to induced EMF in the loop and self-inductance of the "return wire". Good example is an AC monophase railway network where rails must be solidly grounded as often as possible and special attention is paid to such issues.
Let's say you have a ground plane in a high speed, low voltage digital design. For example, just a CPU and a RAM.
Let's say you have a ground loop across that plane (by any reason).
What will that current do with the signal to/from the RAM? What will the devices 'see'?
