Why Does Cyclotron Frequency Depend Only on Magnetic Field Strength?
The discussion revolves around the cyclotron frequency and its dependence on magnetic field strength, exploring the underlying physics concepts related to charged particles in magnetic fields. Participants are examining the relationship between frequency, magnetic field strength, charge, and mass.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are attempting to understand why cyclotron frequency is influenced solely by magnetic field strength and not by other factors such as speed or radius. Some draw analogies to simple harmonic motion (SHM) to explore the concept further.
The discussion includes various interpretations of the relationship between magnetic fields and frequency. Some participants have offered insights into the dynamics of charged particles and the forces involved, while others have sought clarification on specific terms and concepts, indicating an ongoing exploration of the topic.
There are mentions of specific terms like 'dees' and discussions about the role of electric fields in the context of cyclotron motion, suggesting that some foundational knowledge may be assumed or unclear among participants.
Davidmb19
Member warned about not posting with homework template
According to the equation F=BQ/2pieM the frequency depends on the magnetic field and not the speed or radius of the particle. Can someone please explain why?
B= Magnetic field strength Q=Charge M=Mass
I think it's because of the force felt due to magnetic field so the time it reaches the dees depends on how large the force is eventhough, there's an electric field that accelerates the particle.
It's an example of SHM. The frequency of SHM does not depend on the amplitude.
So why does it depend on the magnetic field strength? Is the reason similar to I said?
I didn't understand that part. What are 'dees' here?
Interesting video, but there is one serious error in it. Where it says va is the voltage, it means va is the frequency of the voltage.
Davidmb19 said:
I think it's because of the force felt due to magnetic field so the time it reaches the dees depends on how large the force is, even though there's an electric field that accelerates the particle.
So your question here is why does the natural frequency depend on the magnetic field strength but not on the electric field strength.
Again, by SHM analogy, the magnetic field supplies the 'restoring force', like the modulus of a spring. But you need to be careful with the analogy because the perturbation being restored is the particle's velocity, not its position.
The reversing electric field is not required to produce the SHM. Once circulating, a charged particle would tend to cycle around perpendicularly to the magnetic field at constant speed and frequency. The electric field only serves to raise the amplitude each cycle, and, as discussed, the amplitude does not change the period.
Alternatively, we can throw the analogies away as potentially misleading and just look at the dynamics. If the particle is circling with speed v at radius r then the centripetal force required is mv2/r. The radial force supplied is qBv. Equating these gives v/r = qB/m. Since the path length is 2 pi r, the period is 2 pi r/v = 2 pi m/(qB).
Sorry for the long response. Now that I think of that way it does make sense. Thanks.
  • · Replies 25 ·
