Why does having 8 valence electrons make an element inert?
The discussion revolves around the concept of the Octet Rule and its implications for the reactivity of elements, particularly focusing on why having 8 valence electrons or a full p orbital is associated with inertness. Participants explore theoretical aspects, examples from the periodic table, and the underlying quantum chemistry principles.
  • Some participants question why a full p orbital or 8 valence electrons leads to inertness, using Calcium as an example of a reactive element despite having filled outer orbitals.
  • Others clarify that Calcium does not have a filled outer shell in the context of the Octet Rule, as it has 2 electrons in the 4s orbital and is reactive because it seeks to achieve a full octet by losing these electrons.
  • A participant suggests that the stability associated with a full valence shell arises from the pairing of electrons, which minimizes repulsion and energy, making the atom less likely to gain or lose electrons.
  • Some contributions mention that the Octet Rule serves as a useful guide for main group elements, where atoms tend to seek configurations similar to noble gases to achieve stability.
  • There are references to quantum chemistry principles, suggesting that the Octet Rule emerges from solutions to Schrödinger's equation and relates to stable, low-energy configurations.
  • Participants note exceptions to the Octet Rule, such as Helium, and discuss the behavior of noble gases and their electron configurations.
  • Some participants challenge traditional views of ionic bonding, suggesting a need for more modern quantum chemistry interpretations rather than relying on classical ideas.
  • Links to external resources and papers are shared, indicating ongoing exploration of the topic and differing interpretations of bonding and electron behavior.
Participants express a range of views regarding the Octet Rule and its implications, with no clear consensus on the reasons behind the inertness of elements with full valence shells. The discussion includes both supportive and critical perspectives on traditional explanations and modern interpretations.
Some discussions highlight limitations in understanding the Octet Rule, including the dependence on definitions and the complexity of electron interactions in different atomic contexts. Unresolved mathematical steps and assumptions about electron behavior are also noted.
Redriq1
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert?
What is so special with a full p orbital?
Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive.
Can someone explain it to me?
Thanks!!
Chemistry news on Phys.org
Strictly speaking, Ca does not have a filled outer shell in the sense you are referring to. It has 2 e in the 4s orbital. Elemental Ca is also very reactive since losing these two electrons yields a full octet shell (3s
2 3p6). In the same row. If you go a few elements back, the noble gas Argon (Ar) has the 3s2 3p6 octet in its elemental state, why you would consider it an inert element.
Thanks!!
Don't know how good your Chemistry is so I'll give the simplest explanation possible (also, my chemistry isn't very good, but the fact that our teacher would not tell us why full valence shell = stable was irritating me a lot so I did look into it about a year ago)
When you have orbitals that are full, the electrons are arranged like this: ##|\;\uparrow\downarrow|\;\uparrow\downarrow|\;\uparrow\downarrow\;|##
(The alternating up then down comes from the Pauli Exclusion Principle, which dictates how orbitals can be filled)
In this configuration all of the electrons are paired which means that the repulsion between them is at a minimum. Thus, so is the energy.
It would take a lot of energy to add a new electron to this, and getting rid of electrons will also push the atom into a higher energy state (and thus need to have added energy). Thus, the atom usually does not gain or lose electrons and we call it stable :)
I don't know if this is true all the time, but a useful guide for the octet rule for the main group elements.
In bonding, the atom will 'seek' to have its valence shell that of a configuration of a noble element. One may have to go then on to ask and contemplate why the noble elements are considered inert.
Na loses an electron becoming Na+. Na+ has an electron configuration of Ne.
Cl accepts an electron becoming Cl-. The Cl- electron configuration is that of Argon.
Similar reasoning fo CaO bonding, except 2 electrons are lost or gained in the valence shell(s).
Once you know the basics of the quantum chemistry - how electrons behave in atom, how and why they are organized in "groups" (orbitals, shells) - answer becomes more or less obvious. Octet is one of these numbers that come naturally from the solution of Schroedinger's equation and relate to the very stable, low energy configuration. Other explanations are just conclusions, or echoes of this underlying scheme.
  • Agree
Helium (Z=2) is obviously an exception to the octet rule. Neon (Z=8) has a full p-shell and it is the first element with an octet. For noble gases, in addition to a full outer shell, the number of electrons equals the number of protons.
The group 1 (IA) elements prefer to give up an electron, or share 1 electron with group 17 (VIIA) elements, e.g., HF, HCl, NaCl, . . . . Group 2 (IIA) share 2 electrons with 2 group 17 elements, or complex anions with a valence of -1 (meaning the anion will attract 1 electron). Group 16 (VIA) prefer to attract 2 electrons, and one finds compounds such as Li2O, or CaO, or CaF2. Getting into other groups, it becomes more complicated with multiple valence states.
In some cases, the heaviest noble gases, e.g, Xe, can form compounds, e.g., XeF6.
https://en.wikipedia.org/wiki/Xenon_hexafluoride
That's true for every atom.
as opposed to ions, for which number of electrons exceeds number of protons for a negative ion, or number of electrons is less than the number of protons for positive ions. For example, Cl-, the outer shell is filled like that of Ar, but Cl has 1 electron more than the number protons (17) for net atomic charge of -1 e.
The point is that electrons in the same shell are not as efficient in screening other electrons from the nuclear charge as electrons in lower shells. This means that, despite the total atom being electrically neutral, the electrons in the valence shell see a the higher nuclear charge the further right in the period is the element. This leads to a continuous stabilization of the electrons in the valence shell in the course of going from the left (alkali metals) to the right (noble gasses). This is reflected in a continuous increase of ionization energy and electron affinity. A semiempirical method to find the effective nuclear charges are given by the so-called Slater rules: https://en.wikipedia.org/wiki/Slater's_rules
From this perspective it is advantageous for metals to give their electrons to non-metals as there they are more tightly bound. The process is limited by the atoms giving either away all their valence electrons or completing the valence shell, which gives naturally rise to the octet rule, at least in elements of the first period.
This "give electrons" idea is so 1916, yet we are in 2025. So, can one show me quantum chemistry calculations (valence bond, LCAO, orbital molecular, density functional, whatever) in which the natural interpretation of a NaCl molecule is with the "outer electron" from the Na atom being very probable to be found within the Cl orbital probability cloud? I always complain that the high-school idea of "ionic bonding" is only founded on pre-quantum ideas. It's like people never moved passed this book: Lewis, G. N. (1926). Valence and the Nature of the Chemical Bond. Chemical Catalog Company.
For me it works fine. For legal reasons I find it problematic to upload papers I do not own.
10K
9K
