Why Does Hot Water Freeze Faster Than Cold?
The discussion revolves around the Mpemba effect, which suggests that hot water can freeze faster than cold water under certain conditions. Participants explore various theories and personal experiences related to this phenomenon, including the role of kinetic energy, thermal shock, and environmental factors affecting freezing rates.
  • Experimental/applied
  • Bruno proposes that the kinetic energy of water molecules at different temperatures affects their freezing rates, suggesting that hot water experiences a "temperature shock" when placed in a cold environment.
  • Another participant challenges the concept of "temperature shock," arguing that it does not create more kinetic energy and questions the relevance of Bruno's volcanic analogy to the freezing process.
  • Some participants mention the existence of numerous threads on the topic, indicating that it has been discussed extensively in the forum.
  • There is a suggestion that impurities in the water or the type of container used may influence the freezing rates, with specific materials like metal potentially affecting the process differently than plastic.
  • A participant shares a link to a paper discussing possible causes of the Mpemba effect, contributing to the technical aspect of the discussion.
  • Another participant recounts their own attempts to replicate the effect, noting that they did not observe the expected results.
  • Concerns are raised about the experimental setup, particularly regarding the simultaneous freezing of multiple cups and its potential impact on the results.
Participants express differing views on the mechanisms behind the Mpemba effect, with no consensus reached on the validity of the proposed theories or the outcomes of personal experiments. The discussion remains unresolved with multiple competing perspectives.
Participants mention various factors that could influence the freezing process, such as container material and water impurities, but do not reach a definitive conclusion on their effects. The discussion highlights the complexity and variability of the Mpemba effect without resolving the underlying scientific questions.
EatUrShorts
Hi my name is Bruno, I'm 19, I'm currently finishing my 12nd grade on arts.
I'm annoyed because no one I know can properly discuss the Mpemba effect with me.
So, I'll go as fast as I can on this.
The scenario.
We have a cup of water let's say for example at 80 degrees Celsius .
We have another cup of water let's say for example at 20 degrees Celsius.
And then we have a for example freezer, with a room temperature of let's say -40 degrees Celsius.
You put both cups in the freezer at the same time and done voila, the cup that was at 80 degrees Celsius freezes faster than the one that was at 20 degrees Celsius.
Now why? Nobody knowns.
What I think?
Kinetic energy.
The water has different stages , and those stages have different molecular behavor and kinetic energy.
Now at 0 or under degrees there is no kinetic energy, there are only crystals, over 0 degrees and below 100 the molecules are stable altough they start moving a bit more as the temperature rises, over 100 they just go ballistics nearly breaking their molecular links
So we have the cup with water at 80 degrees, it comes in contact with a colder environment and they react, causing a temperature shock, which creates more kinetic energy, causing the 80 degree water molecules to go nuts and almost break their links, (even making some of the water to go from liquid to gas) thus making it easier to cool than the 20 degrees celsius that goes down gradualy because the molecules are stable.
I tought of this theory based on behaviour I saw on video of a vulcano. Where the ash cloud coming from the vent reacted with the cold air creating a mini thunderstorm.
I have no more patience to keep writing xD I hope you read this and take a quick look, I already think I'm wrong since, I don't know if this theory is actually possible in a such small scale .
See you. Hugs and good night.
Science news on Phys.org
I don't know what a "temperature shock" is. But I can tell you that it most certainly does not 'create' more kinetic energy. I see no reason why hot water coming into contact with cold air would cause the water molecules to suddenly start breaking their bonds. It should have the opposite effect.
Now, I have heard of warm water freezing faster than cold water before, and I've seen a few threads on it here on PF. If you do a search you should find some that have possible answers.
Yes, but you have to ask yourself, "What does this have to do with how fast cold and hot water freeze". Of which the answer is, "Nothing". The two effects are completely different.
There are already at least 32 threads on this subject. You can find out a lot by using the Search box.
Thank you for awnsering :3 I'm sorry I'm new to the forum, I just wanted to share my quick vision xD
Yeah not temperature shock - Thermal shock xD sorry I'm portuguese I don't know the therms in english. You musn't forget the glass cup! I said almost breaking, not breaking :P which makes it easier for the water to cool, because it's less dense , we can't ignore the fact that cold water is denser than hot water and ice. and yes the its opposite effect, but it doesn't happen right away, some molecules that are going nuts escape, thus creating gas which has more kinetic energy than the previous form.
Thank you! :3
Have you tried to replicate the effect? I have, and it didn't happen. One of those threads has details of my test...
Could you link it please russ? Well I've been reading some experiences and it could have to do with impurity on the water it self, or the actual fridge. And the material you use to put the water on has to have some kind of influence for sure, where did you put the water? If you have like a cup of glass or a cup of metal or something that heats with the water, it has that initial thermal shock which helps out a lot the process. Plastic for example isn't as good.
Hum ty :3 One small thingh tough... Shouldn't you have done it one at a time? Or get a fridge for each. Because by putting all of them together it kind of takes away the point since you're altering the temperature of the fridge...
The cups of water are pretty small compared to the capacity of the fridge, plus if the logic is that you are raising the temp of the fridge it will have a bigger adverse effect on the cooler water anyway.
In any case, I hadn't heard of that as a constraint of the setup and you are more than welcome to try such a test.
  • · Replies 16 ·
  • · Replies 18 ·
11K
  • · Replies 102 ·
