Why does ice have no friction?
  • Context: High School
  • Thread starter Thread starter sameeralord
    Friction Ice
The discussion clarifies that ice does not have "no friction" but rather exhibits relatively low friction due to the melting of ice at the interface with an object. When weight is applied, such as during sliding, the pressure causes a thin layer of water to form, reducing friction. This phenomenon is essential for activities like skiing and skating, where a small water film aids in movement. The melting point of ice can decrease slightly under pressure, further contributing to this effect, as detailed in S. C. Colbeck's study from the American Journal of Physics.
  • Understanding of basic physics concepts related to friction
  • Knowledge of the properties of ice and water
  • Familiarity with pressure effects on materials
  • Awareness of ice sports dynamics (e.g., skiing, skating)
  • Research "Pressure melting and ice skating" by S. C. Colbeck for in-depth analysis
  • Explore the effects of pressure on melting points in various materials
  • Study the physics of friction in different states of matter
  • Investigate the role of water films in reducing friction in sports
Physicists, sports scientists, ice sports enthusiasts, and anyone interested in the mechanics of friction and motion on ice.
sameeralord
If you come in contact with any object, it is not going to resist your movement right, why doesn't ice do this much. What chemical property is responsible for this?When I slide in ice, am I coming into less contact with ice, I don't understand. Thanks :smile:
when you slide on ice, you push with your weight. So it melts at the interface (ice and you). Therefore you slide. (sliding on thin layer of water..)
be careful when you say "why does ice have no friction" this is misleading compared to what you are asking since Ice doesn't have no friction but relatively little as you have identified.
like rajini has said, ice melts as you slide against it.
take into consideration the water formed as ice melts, it would decrease the friction between the ice and the object.
there would still be friction between ice and an object or you would be able to slide indefinitly
This is a common myth. The weight of a guy of 70 kg would cause a decrease of the melting point of ice which is on the order of 0.2 degrees. For skiing, sledging, and skating, friction causes a water film to build up which allows efficient skating. Apart from that a small water film of only a few nanometres thickness is always present due to pressure-independent surface effects.
See for example:
S. C. Colbeck, "Pressure melting and ice skating", American Journal of Physics, October 1995, Volume 63, Issue 10, pp. 888-890
for details.
  • · Replies 25 ·
