Why Does Looking at Bright Light Cause Pain and Reflexive Eye Closure?
  • Thread starter Thread starter Drakkith
The discussion centers on the physiological response to bright light, specifically why it causes pain and reflexive eye closure. Participants agree that the pain is not due to damage to the eye but rather a psychosomatic response triggered by the overload of signals from the rods and cones in the retina. The visual cortex misinterprets this flood of information as pain, while infrared light does not elicit the same response due to the insensitivity of rods and cones to that wavelength. The conversation also touches on the role of cranial nerves and the brainstem in mediating these reflexes.
  • Understanding of human anatomy, particularly the eye and visual pathways.
  • Knowledge of the roles of rods and cones in vision.
  • Familiarity with the concepts of psychosomatic responses and nociceptive neurons.
  • Basic comprehension of brain structure, including the visual cortex and cranial nerves.
  • Research the mechanisms of psychosomatic pain responses in sensory systems.
  • Study the anatomy and function of the retina, focusing on rods and cones.
  • Explore the differences between visible light and infrared light in terms of sensory response.
  • Investigate the role of cranial nerves in reflex actions related to vision.
This discussion is beneficial for neuroscientists, ophthalmologists, psychologists studying sensory perception, and anyone interested in the physiological responses to light exposure.
Drakkith
Mentor
When you look at a very bright source of light, such as the Sun, what causes the pain reflex and makes you close your eyes? I ask because I've read that IR light, typically from lasers, will not trigger this response, so I assume that the reflex isn't caused by your eye being damaged, but by something else.
Also, if someone were to be blind due to a defect in their brain, and their eyes were completely functional, would they experience pain when they looked at a bright source of light?
Biology news on Phys.org
I'm not sure, a quick search turned up essentially nothing.
Depends on which part of the brain. If you're talking about the visual cortex, my guess is that a defect or damage there would not affect the squint reflex or the experience of pain, because these are most likely mediated by the cranial nerves at the level of the brainstem.
You don't actually feel pain when this happens, as the rear of the eye contains relatively few pain neurons. The pain felt is a psychosomatic response. What you sense as pain from a bright flash is the flood of signals sent from over excited rods and cones in one big rush of information delivered via the optic nerve. The overwhelmed visual cortex mistranslates this input rush as pain. The same reason is also why after a bright light is viewed, you will continue to see ghost images of the flash even with your eyes closed (over excited rods & cones still transmitting after the stimulus has been removed).
As an aside, this phenomenon is also why loud noises are painful and your ears ring afterwards. Same psychosomatic response mechanism.
Your rods and cones are optimized for visible light as they are stimulated by it. They are insensitive to other wavelengths, so this will not happen (even if the source is to be so powerful as damaging). You don't feel your eyes being damaged by UV light for the same reason. The real pain comes afterwards once the injured tissue becomes inflamed. Many a newbie metal welder learn this the hard way by thinking he/she can peek at their ongoing welding without the annoying dark glass protection blocking most of what can be seen when the welding arc is not struck.
<edit> To add, you can achieve a similar psychosomatic response with your sense of touch. Place your hand in very warm water for a few. Then stick it in ice water. It will hurt. The dramatic signal shift from very warm to very cold will trigger a similar overload in your cortex even though the very warm or cold water are inherently not painful alone.
As an aside, this phenomenon is also why loud noises are painful and your ears ring afterwards. Same psychosomatic response mechanism. <edit> To add, you can achieve a similar psychosomatic response with your sense of touch. Place your hand in very warm water for a few. Then stick it in ice water. It will hurt. The dramatic signal shift from very warm to very cold will trigger a similar overload in your cortex even though the very warm or cold water are inherently not painful alone.
Do you have valid references for these "psychosomatic" responses/mechanisms and "cortical overload"?
I quick looked on line for a convenient link and found a dearth of material on the topic in general. There's a bunch of material about how autistic people have a much lower threshold concerning this across their sensory spectrum as a pathology of this response mechanism though.
My principle source is this:
Human Anatomy and Physiology, 8th Ed.
ISBN 978-0-8053-9569-3
The topic was covered extensively during several related courses too. While the pain felt is very real (hey, you felt it), the route is not via the innerved pathways that transmits pain and related sensations (such as when you step on a nail in a board or strain your back, etc). This is why the OP is correct in assessing that bright IR light will not cause pain, but bright visible light will. The sensors (rods & cones) cannot transmit the overwhelming signal strength since they do not respond to that light spectrum.
I guess there is a similar pathway for smell too, but I have never heard of it. It definitely exists for sight, sound and touch (where pain separately exists as a sensory element too).
There are specific receptors and neural pathways for pain and I'm not sure "cortical overload" is a scientifically meaningful concept and why, in any case, it should be perceived as pain. In these forums you are required to provide links to sources that can be viewed except in cases where it is generally accepted and well known science. Any pain with your example of plunging a finger into cold and then warm water is likely to be the result of stimulating vascular pain receptors as a result of the sudden narrowing followed by dilatation of blood vessels (vasomotor instability). There is also referred pain which is conveyed by the usual mechanism, but is interpreted at the cortical level as being in a different location than the true source of the stimulus. I'm not saying that psychosomatic pain does not exist, but you must provide evidence that it is relevant in this case. It's too easy to dismiss an undiagnosed pain source as "psychosomatic".
SW VandeCarr said:
There are specific receptors and neural pathways for pain and I'm not sure "cortical overload" is a scientifically meaningful concept and why, in any case, it should be perceived as pain. In these forums you are required to provide links to sources that can be viewed except in cases where it is generally accepted and well known science. Any pain with your example of plunging a finger into cold and then warm water is likely to be the result of stimulating vascular pain receptors as a result of the sudden narrowing followed by dilatation of blood vessels (vasomotor instability). There is also referred pain which is conveyed by the usual mechanism, but is interpreted at the cortical level as being in a different location than the true source of the stimulus. Also, I'm not saying that psychosomatic pain does not exist, but you must provide evidence that it is relevant in this case. It's too easy to dismiss an undiagnosed pain source as "psychosomatic".
I agree with Vande on this point. The term and concept of "psychosomatic" doesn't hold a lot of water at PF unless perhaps it is well researched and referenced and given to one specific instance. I think you (Leeboy) are right by saying that the pain and the wince involved with a sudden blast of light is due to a sudden assault on the rods and cones of light in the visible spectrum, but I think your assessment that it is a psychosomatic result at the level of the visual cortex is misplaced. The sudden assault most likely triggers nociceptive neurons in the retina and/or related subcortical cranial nerve pathways. The reason IR radiation does not trigger this pain response suggests that it is indeed the rush of activity on the rods and cones that is responsible.
However, I have no (ready) evidence to support that hypothesis, which is why I said I'm not sure in my initial post. That's how we roll at PF :-p
Oh my, I've stirred the hornets.
  • · Replies 19 ·
34K
12K
  • · Replies 39 ·
  • · Replies 19 ·
20K
9K
