- 30,594
- 7,548
chemisttree said:
But is it Persil White?
chemisttree said:
sophiecentaur said:But is it Persil White?
It's not contentious. The Sun's COLOR is white. But since color is purely perceptive, we don't use it for accurate measurements. Instead, we measure the spectrum and plot the output per wavelength using a spectrograph.
Also, we don't base distances off of color. We have a cosmic distance ladder that involves several different techniques, none of which are based on color.
Not in orbit, but...Solon said:I've never seen a colour calibration card used out in orbit, or a white balance reference card.
Yes, which is a misnomer.davenn said:OK ... regardless of how it looks visually or photographically via the Earth's atmosphere,
The Sun is deemed a yellow class star...![]()
Solon said:@Drakkith.I've never seen a colour calibration card used out in orbit, or a white balance reference card. Maybe it's because colour being perceptive they don't bother?. SOLSPEC has 1 nm sampling, but calibration is needed regularly, and I don't see any charts showing how the spectrum changes, if it does, over time. Is ours a variable star?
I though they used light and colour curves when examining the Cephid variables? Maybe not.
cheers
Dave
sophiecentaur said:Have you never come across false colour before? It's used all over the place to 'model' variables with different colours. Why do you take such a picture so literally? You would never make the same mistake with a thermograph.
This thread has really got out of hand. Stars have a range of surface temperatures and that produces different 'whites', which can be described in terms of yellow, blue, white etc. Those names are only used 'colloquially'. Anyone who wants to be precise will talk in terms of temperature.
The atmosphere changes the colour of anything viewed through it because it is not a neutral density filter. Is there any doubt about that? Any 'experiment' to demonstrate this needs to be quantitative and properly carried out. And it has been done many times. Random photographs do not constitute evidence of anything.
sophiecentaur said:This thread has really got out of hand. Stars have a range of surface temperatures and that produces different 'whites', which can be described in terms of yellow, blue, white etc. Those names are only used 'colloquially'. Anyone who wants to be precise will talk in terms of temperature.
cjl said:I think you might be taking this a little too seriously...
sophiecentaur said:Which 'white' did you have in mind? Look at the controls on your computer monitor and you'll find a lot of options even on that. Are you certain that, if someone altered the 'white' on your screen whilst you were away, you'd necessarily notice?
Drakkith said:The kind of white the Sun looks like near zenith?
CIE D65. That is as white as white can get, and it's the color of the Sun at noon. Note that correlated color temperature is not quite the same blackbody temperature. CIE D65 is *the* standard definition of white. http://en.wikipedia.org/wiki/Illuminant_D65sophiecentaur said:Which 'white' did you have in mind?
Drakkith said:I don't know what you're getting at Sophie.
sophiecentaur said:If we're trying to be scientific about this, we have to be precise and have a possible measurement system - not just to say what it 'looks like'.
Drakkith said:I thought we were being pretty precise when we said the Sun radiates like a blackbody at about 5800 kelvin and looking at the Sun through a small portion of the atmosphere overwhelms your color receptors, making the Sun look about as white as you can get even though some of the light is scattered out.
sophiecentaur said:So:
Sun + Blue sky = D65 standard filament lamp (when reflected by a totally reflecting matt surface)
Therefore
Sun = D65 lamp - blue sky
sophiecentaur said:Can they both be your 'perfect white' then?.
voko said:This is unobservable from the surface of the Earth, while I think the subject question was in the terrestrial setup.
Drakkith said:I don't know and I don't care. Per the OP's original question, the Sun is white, it looks about as close to white as you can get when high in the sky, turning to yellow-orange as it approaches the horizon thanks to scattering.
sophiecentaur said:?
I am describing exactly what you see from Earth here. You 'see' the familiar old Sun ( through the atmosphere of course) and you see the blue sky up there. Are you not following this?
voko said:This: "Sun = D65 lamp - blue sky" is what you do not see. Because you see the Sun through the blue sky.
sophiecentaur said:You see the Sun - yes. but illuminant D65 is what falls on a matt surface and what you see from that surface is direct Sunlight plus what comes from a hemisphere of blue sky. l'm afraid I can't see what there is not to understand here.
