Why does synchro signal voltage drop to 30V at System A terminal block?
2 replies · 2K views
grasscut
Hi, I am currently having an issue and hope someone can help me out! I have a Digital to Synchro card on my server that will transmit the synchro signal voltage to various component. For this issue in facing, System A takes in 4 sets of data. Thus, there will be 4 sets of S1 S2 S3. At System A, my cable from my server are connected to the terminal block of System A. I took my measurement at System A and realized my 2 sets of the voltage signal at loss.
Assuming at 0 degree for pitch and roll, i have an output of S1S2 = 79V S2S3 = 79V S1S3 = ~0V
However, when i measured the voltage at System A terminal, the 2 sets of data that has loss has about S1S2 = ~30V S2S3 = ~30V S1S3 = ~4V, and this happened even when the System A is not on. Another weird thing is that when i measured the voltage with the cable NOT connected System A terminal block, my voltage signal are fine but it changes once its connected to System A terminal block. Then i did so some troubleshooting and found that the resistance on the 2 sets of data that were wrong have about 1.2kohm, whereas the other 2 sets that is working fine and receiving the correct voltage from my server has abt 7k ohm. Does this affect the in the voltage loss?
Another thing is System A supplier used their own simulator, solely used to out synchro voltage at 0 degree is working fine when connected to their system.
I am running out of idea how to solve this issue and hope some one who is experienced in synchro signal or anyone can help me out!
Thank you!
I am assuming that you also have the rotors wired - and that there is no problem there.
So the next questions are:
1) What Digital Synchro driver are you using?
2) What is its rated drive current?
3) How much current does System A draw?
4) Are the synchro outputs used by System A also tied to other systems?
Also:
5) What is System A doing with this synchro output? Is it actually trying to move something? Or is it just re-digitizing the data?
6) If it is moving something: What is the mechanical load? What is the rated load? What is the current draw expected at that load?
7) If the synchro outputs are going to other systems, repeat questions 5 and 6 for each of them.
Finally:
8) How is the system performing? Are the synchros actually turning properly? Do they go to the correct position? Do they move fast enough for your application?
Its a North Atlantic S/D board pci-76cs1
In the data sheet, if i not wrong, the reference current is 1ma max /channel
I don't know how information on System A draw
The S/D card have many channels, but the synchro outputs to System A is not tied to other system
Also:
Yes, Its moving something. System A is like a glide slope indicator.
Apologies but i do not have the information on System A. The synchro output loss happened even when System A is switched off.
Finally:
My S/D card have no issue with other systems such as gyro repeaters etc. Only to this particular output to System A
Hope you can help me out! thanks!
