Why does the answer key sometimes have a different form compared to my solution?
  • Context: Undergrad
  • Thread starter Thread starter NODARman
    Book Form
68 replies · 7K views
NODARman
TL;DR
When I solve the equation sometimes the answer in the answer keys is different but the same. Why do they do that?
For example:
After solving the equation I got 1/√2 which is the same as √2/2 because we multiplied it by √2/√2. Is there any good explanation why the book writer mathematicians like to do that thing?
NODARman said:
TL;DR Summary: .
For example:
Usually the standard way to write a fraction that has roots in it is to "rationalize" the denominator to remove any roots from the denominator. It's just the standard way of writing it.
-Dan
NODARman said:
TL;DR Summary: .
For example:
You may already understand. No matter - the answer key is to help you to know if you handled the problem solving properly or not. The actual form of the answer in the key is usually far less important.
-Dan
I would write ##\sin \frac \pi 4 = \frac 1 {\sqrt 2}##. I don't think I've seen it written as ##\frac {\sqrt 2} 2##.
PS now I have!
NODARman said:
TL;DR Summary: .
For example:
There is no good reason that I can see.
That value for sine has USUALLY been written in the rationalized form, both in the textbooks and in lecture instruction. ( ##\frac {\sqrt 2} 2## ) Some occasions happened, best I can recall, that drawing some right triangles were done using the non-rationalized form because doing so was more convenient at that time.
PeroK said:
I don't think I've seen it written as 22.
https://en.wikipedia.org/wiki/Sine_and_cosine#Special_values
I mean, I don’t see any point in quibbling over this. I could write it ##3\sqrt 2/ 2\sqrt 9## if I wanted to and it would still be correct. There is no one unique way of representing this.
I genuinely thought I'd never seen that before.
To the best of my knowledge, no one writes ##\frac{\sqrt \pi}{\pi}## instead of ##\frac 1 {\sqrt \pi}##.
Square roots appear in the denominator all over statistics, quantum mechanics, and the gamma factor in SR!
I'm not quibbling about one being right or wrong. But, I am disputing the claim that square roots should not appear in the denominator.
PS now I have!
I'm not saying that I understand why the convention is what it is. It makes no sense to me. I completely agree that ##\frac{1}{\sqrt{2}}## or ##\dfrac{1}{i}## are more natural answers in this case.
-Dan
I can recall some of my classmates losing marks because they didn't rationalize their denominators. If it was specified to do so I would agree, but it wasn't at all in this case. I thought it was absurd.
That’s not absurd, it is idiotic imho.
high school algebra text are based of Euler's Elements of Algebra. Where Euler does not rationalize the denominator. Who are we to argue wit Euler.
Possibly the marker could not recognise that the answers were equivalent, or the mark scheme was poorly drafted and said "[itex]\sqrt{2}/2[/itex]" rather than "[itex]\sqrt{2}/2[/itex] or equivalent".
Someone not able to recognise that ##1/\sqrt 2## is equivalent to ##\sqrt 2 / 2## should not be teaching math.
Topic drift? Student checking his answer in the book answer key should realize the book might or might not be using unrationalized form and think accordingly. Work assessor checking students' answers may apply standard instructions to accept final answers in only rationalized form, but depending on steps needed and shown, should be permitted to give partial credit.
I obviously am not in the class but when I was in both High School and College my Math instructors always required that we rationalize the denominator. If that's the case here then we should expect that points will be lost. (My Physics instructors didn't care so much.)
-Dan
Such ”standard” instructions should be avoided. It is like deducting points in a history exam for writing that the father of Elizabeth II was George VI instead of writing that Elisabeth II was the daughter of George VI.
To recognize equivalent answers should be imperative to students, but even more so for teachers and people correcting standardized exams.
Realize that students are still learning their subjects and students are supposed to learn to follow instructions.
  • Sad
… which puts even more impetus on instructions being reasonable, which I would argue that they are not if they require rationalization of the denominator.
Most algebra or precalculus textbooks I've seen spend a fair amount of time on exercises related to simplifying rational expressions. I believe that the preference for, say ##\frac {\sqrt 2} 2## over ##\frac 1 {\sqrt 2}## goes back to the time before calculators and such.
It's a lot easier to divide an approximation to ##\sqrt 2## by 2, than to divide 1 by an approximation to ##\sqrt 2##.
For example, try long division (on paper) of each of these:
$$\frac {1.41421356} 2$$
versus
$$\frac 1 {1.41421356}$$
Yes. That is the truth, and students do lose credit for not following instructions. I am not lying.
PeroK said:
If you look up any page on the normal distribution you'll find the normalisation factor of ##\frac 1 {\sqrt{2\pi}}##. What would these maths instructors say about that?
I was not referring to Statistics instruction or to practices there. I was referring to instruction in Trigonometry.
Not within my control. The practices are the practices. If instructor expects final answer in a certain form, either follow instructions of receive less credit.
I never said you can control particular instructors. That practices are practices is a cheap argument. If the practice is bad then one has to be able to say so. There is no particular reason to require rationalizing the denominator here. It does not add anything of value.
Still the practices as they may be conducted or expected is the truth. Try arguing about this with your professors and see how much progress you make.
  • Sad
I have not called anyone ”my professor” in decades. As a university professor I’d happily argue with the people making such bad standards.
  • Sad
