Why Does the Derivative Change for Different Values of X?
  • Context: Undergrad
  • Thread starter Thread starter racer
    Derivatives
The discussion revolves around the concept of derivatives and their relationship to the average rate of change of functions, particularly focusing on linear and non-linear functions. Participants explore the differences between the derivative at a point and the average rate of change over an interval, using specific examples such as linear functions and quadratic functions.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • One participant notes that for the function Y=3x, the derivative is constant, while for Y=x^2, the derivative varies, leading to confusion about the rate of change.
  • Another participant clarifies that the derivative represents the instantaneous rate of change, while the average rate of change between two points is an approximation.
  • Some participants emphasize that the average rate of change depends on the interval chosen, especially for non-linear functions, and that it differs from the derivative at a specific point.
  • A participant expresses a desire for realistic examples that illustrate the concept of derivatives, particularly for higher-degree functions.
  • There is a mention of a misunderstanding regarding the relationship between the derivative and the tangent of the angle between the function and the x-axis.
  • One participant highlights that knowing the average rate of change between two points does not guarantee that the derivative at those points is equal to that average rate.
Participants generally agree on the distinction between the derivative and the average rate of change, but there remains some confusion regarding their applications and implications, particularly in non-linear cases. The discussion reflects multiple viewpoints and interpretations without a clear consensus.
Some participants express uncertainty about the application of derivatives to realistic scenarios, indicating a need for further exploration of examples that demonstrate these concepts effectively.
racer
Hello guys
I've been recently thinking about derivative and it's applications.
Let's say Y=3x
When X = 1, Y=3
wHEN X = 2, Y = 6
When X = 3, Y = 9
Dy/Dx is the rate of change in Y with respect X, it is 6-3/2-1 =3/1 = 3
and the derivative is 3.
Let's Y = (X)^2
When X = 1, Y=1
When X = 2, Y = 4
When X = 3 , Y=9
When X = 4 , Y = 16
Dy/dx = 4-1/2-1 = 3/1 = 3
Dy/dx = 9-4/3-2 =5/1 = 5
Dy Dx = 16-9/4-3=7/1 = 7
So the rate of Change is not constant.
When you derive you get 2x
When you plug values in the function, you get different values from the the rate of change, Where is my mistake?
Thanks.
The function is different than its derivative. Of course, the values at any given x can be different.
Hi racer! :smile:
You have to choose the half-way value …
3 5 and 7 correspond to 1,2 2,3 and 3,4.
half-way is 1.5 2.5 and 3.5, and 2x of that is 3 5 and 7 !
Happier? :smile:
You should expect dy/dx to be different than (y(x2)-y(x1)) / (x2-x1). The former is exactly the rate of change, while the latter is just an approximation to the rate of change.
Much what the others are saying but:
[f(x1)- f(x0)]/(x1- x0) is the average rate of change of f between x0 and x1. The derivative of f (at a point x= a) is the instantaneous rate of change at x= a. If a function is linear (as your example f(x)= 3x) then the average rate of change over interval, starting at any point is a constant (the slope of the line) so the two are exactly the same. If a function is not linear (as f(x)= x2), the average rate of change depends upon both the starting point and the interval and the "average rate of change" and derivative are different.
Happier?
That was amazing, I'll see if this applies to other functions.
Is there a realistic proof or example that contains releastic things?
It is logical, I would like to see a realistic example and I know that it is hard to find a realistic example that proves derivatives but there has to be an example proves derivatives realistically specially of functions that are second degree and above.
Yeah, I made a mistake because I read somewhere that the tan of the angle between the line that a function makes and the x Axis is the first derivative.
Thanks guys.
Please note the difference:
The slope formula will give you the rate of change between two points.
The derivative function will give you the rate of change at one particular point.
That's a big difference! Hopefully you will take some time to think that through.
So say you have any function f(x). Pick two points (x_1, y_1) and (x_2, y_2)
Now from what I have said above, you should know tha the slope formula will allow you to calculate the rate of change between these two points. Where as the derivative, f'(x), give you the rate of change at one particular point.
One interesting result, if you know the rate of change between two points (call it m), you are not guaranteed that the rate of change at either of those points is m! However, you are guaranteed that there is a point between those two points where the rate of change is m! In the example of f(x) = x^2, it just so happens that the point where this occurs is half way between any two points. For other functions it probably won't be exactly halfway.
  • · Replies 17 ·
  • · Replies 20 ·
