High School Why does the radius of a unit circle need to be 1?
sunny79
Why is it that the radius of the unit circle is 1?
Mathematics news on Phys.org
By definition? What do you think the "unit" in "unit circle" stands for?
  • Haha
Likes Abhishek11235, sysprog, berkeman and 1 other person
Of course, the follow on question would be why do mathematicians define it that way?
The benefits are that it provides a simplification when teaching students about the trig functions and radians. Using a 1 means the circle perimeter is now ##2\pi## radians.
Right triangles drawn inside the circle with their hypotenuses being the radius have sides that sin and cos measurements their acute angles.
Im sure there’s other benefits as well. Can you spot any?
https://en.wikipedia.org/wiki/Unit_circle
Likes Abhishek11235, Frigus, sysprog and 2 others
Unit with radius 1
Likes Abhishek11235, sysprog, jedishrfu and 1 other person
Another related advantage is that the length of an arc is equal to the angle it subtends (measured in radians).
Likes Abhishek11235, sysprog, symbolipoint and 1 other person
I think you are misunderstanding what people are saying when they talk about unit circles. This is a definition, there is no inherent reason for it. It's just a different way of saying r=1 (because it's so common, it has a name).
I think this is the same as asking why does a circle with radius =13 have radius =13? They've just used different words for r=1.
Likes Abhishek11235, Vanadium 50, sysprog and 2 others
Excellent responses given so far, but the question is silly.
Further Thought: My hasty thinking to say, "silly". One can look at a few measurable parts of a circle. circumference, diameter, radius, area. To pick RADIUS of unit 1 allows for some ease in handling some Trigonometry.
Likes Abhishek11235 and sysprog
Likes symbolipoint and sysprog
While using a circle of radius 1 provides a simplification, introducing a constant that is just half of its perimeter, makes it unnecessarily complicated again.
Likes symbolipoint
Can you please elaborate further on why you think that the ##2\pi## radians is an unnecessary complication?
He’s a ##(\tau)## Tau-ist.
  • Haha
Likes vela, tworitdash, xAxis and 1 other person
Beacause of the unnecessary factor 2. It's like using a circle with radius 1/2 instead of the unit circle.
What if you want to write the area of the circle?
Are you saying π should have been defined as circumference/radius (π=6.283...)?
Likes jedishrfu
Sciam did a nice article on the pros and cons:
https://www.scientificamerican.com/article/let-s-use-tau-it-s-easier-than-pi/#:~:text=At its heart, pi refers,now a proponent of tau.
I am fearful though that it will become another political football as the definition of pi=3 almost did many years ago in Indiana:
https://en.wikipedia.org/wiki/Indiana_Pi_Bill
Something like this happened with the change of notation between physics and math over the spherical coordinate system.
I was taught in the early 1970s ##R \theta \phi## (##\phi## for the angle with the z-axis) whereas the physics usage at work was ##R \phi \theta## (##\theta## with the z-axis) . At first, I thought my brain was losing it until I did some research and discovered I was taught the math convention.
You can imagine the confusion that results in trying to understand any spherically symmetric physical systems.
Something like this happened with the change of notation between physics and math over the spherical coordinate system. I was taught in the early 1970s ##R \theta \phi## (##\phi## for the angle with the z-axis)whereas physics usage at work was ##R \phi \theta## (##\theta## with the z-axis) . You can imagine the confusion that results in trying to understand any spherically symmetric physical systems.
I think that this is a nice article on the topic: https://tauday.com/tau-manifesto
Likes etotheipi and jedishrfu
True, they mention it in the Sciam article.
Likes sysprog
My only argument in favor of ##\pi## is that two pies are better than one.
  • Haha
Likes tworitdash, rbelli1 and DaveE
That's a really fun page; I noticed that they justified ##A = \frac{1}{2} \tau r^2## by analogy for other quadratic forms that arise in Physics. The stuff about Gaussian distributions and polar coordinates is a nice touch. Perhaps we can agree on:
  • Haha
Likes tworitdash, Mark44, sysprog and 1 other person
In that case what would you think about letting PF member @etotheipi have a second membership as @etothetau? 🤔
  • Haha
  • Love
Likes tworitdash and etotheipi
Maybe two half memberships?
Likes hutchphd and etotheipi
But required to post everything twice.
  • Wow
Likes etotheipi
How do you write the area of a triangle? The circle area can be derived from that, so it makes sense for them to have a similar form.
Likes etotheipi
Based on his post, @etothei1.5pi would be more appropriate. :oldbiggrin:
Likes etotheipi
##-## otherwise rendered as @etothepau ##-## why not let him have 3 memberships? :cool:
  • Haha
Likes tworitdash
I didn't read the links. But it seems to me the question is, is a circle defined by its radius, or by its diameter? There is no definitive answer. If you are drawing a circle (say with a compass) then you think, "radius." If you are measuring a circle (with a ruler or calipers) then you think, "diameter."
  • Skeptical
Likes symbolipoint
Isn't it true that if we are to measure the circle by use of progressive caliper measurements whereby to determine whether our diametrical measurement is maximal then we have to do that with at least two different pairs of circumferential points in order to by the intersection of the line segments between the thereby determined pairs of points find the center?
Others have already pointed out that this is just a matter of convenience. I'll just add that early trigonometry (and spherical trigonometry) used a radius of 60 (see Ptolemy's Almagest). That was a convention left over from the Babylonian astronomers. I'm not sure when the unit circle was first popularized. It didn't come up readily in after one minute of searching online. If I had to guess, I'd put my money on Euler having something to do with it.
Likes weirdoguy and dextercioby
I'm not sure what you're getting at here. I meant calipers like this (with parallel jaws). Squeeze and read the diameter. Much easier than measuring the radius of a given circle.
I believe the OP has, quite reasonably, fled in terror...
Likes jim mcnamara, symbolipoint and gmax137
  • · Replies 19 ·
  • · Replies 59 ·
62K
  • · Replies 19 ·
