Why does the resultant Fy have opposite values in my calculations?
  • Thread starter Thread starter tomtomtom1
    Forces Resultant
The discussion revolves around the confusion regarding the signs of the resultant vertical force component (Fy) in a free-body diagram. Participants explore the implications of different sign conventions and how they affect the calculation of Fy, particularly in the context of resolving forces at an angle.
  • Some participants note that the sign of Fy depends on the chosen sign convention, with one participant stating that a downward pointing arrow is negative and an upward pointing arrow is positive.
  • Others argue that if Fy is sketched pointing downward in the free-body diagram, a positive value indicates that the force component is indeed directed downward, while a negative value would suggest an upward direction.
  • One participant provides a calculation approach, indicating that the vertical component of a force at an angle should be resolved into positive and negative components based on the orientation of the force.
  • Another participant expresses confusion about why their calculations yield a negative value for Fy, despite their understanding of the force's direction.
  • Some participants suggest that the issue may stem from differing interpretations of the positive direction for the axes in the free-body diagram.
  • A later reply suggests that redrawing the sketch with Fy pointing in the defined positive direction could clarify the situation.
  • One participant mentions that for the system to be in equilibrium, one of the components must have a negative direction, which aligns with their calculations.
Participants generally do not reach a consensus on the correct interpretation of the sign convention, as multiple competing views remain regarding the directionality of Fy and how it should be represented in calculations.
There are limitations in the discussion regarding the assumptions made about the sign convention and the lack of clarity on the positive direction for the axes in the free-body diagram. Some participants express uncertainty about the implications of their chosen conventions on their calculations.
tomtomtom1
TL;DR
Resolving Resultant Forces
Hello all
I was hoping someone could explain why the resultant Fy has a value of +40kN but I get a value of -40kN.
Whether Fy is positive or negative depends on your sign convention. In the free-body diagram, the component Fy is sketched directed downward, so a positive result indicates that the force component does, in fact, point downward.
A negative result would indicate that the component Fy is directed upward. From the orientation of F, we know this is not the case.
Fsub x=cos 30 X F
Fsub y=-(sin 30 X F)
SCP
Thank you for the reply - I have to be honest, I am still struggling.
My sign convection is such that a downward pointing arrow is negative and an upward pointing arrow is positive.
In the Free Body Diagram the Fy arrow is point downwards so it would be negative.
This doesn't make sense to me?
tomtomtom1 said:
Summary: Resolving Resultant Forces
Hello all
Hi there,
First, see how the arrow is pointing and it's given as 80KN which is positive, and it makes an angle 30 deg with horizontal, so horizontal will become 80 Cos 30 Deg aligning to +Fx and vertical becomes 80 Sin 30 Deg. Basically aligning to the co-ordinate making it +Ve.
Try solving more problems or refer few examples you will understand the crux
tomtomtom1 said:
SCP
Your brief makes sense.
The figure does not show any direction for the positive direction of the x-axis, nor the y-axis, and one would normally consider your interpretation.
Perhaps the question is asking only for the magnitude of the forces Fx and Fy.
Adding the - ( minus ) sign gives a direction to the vector Fy down in compliance with your choice of positive x and y axis.
I really am baffled.
I have tried again but with a different question and still got it wrong:-
Why on Earth would Fy be -ve 21.21 WHY WHY WHY?
View attachment 252323Why on Earth would Fy be -ve 21.21 WHY WHY WHY?
I see why you're getting confused. You're thinking in terms of an external sign convention that defines the positive y-direction as up. However, the Fy vector is drawn pointing down. The vertical component of F is up. Your sign convention defines that as positive. However, the Fy vector is sketched pointing down. So the vertical component of F is opposite in direction to the sketched force Fy. In other words, using Fy to express the vertical component of F requires a negative result.
You could also re-draw your sketch with Fy pointing in your defined positive direction (i.e. - up). In this case, your positive answer would be correct.
The particle is not in equilibrium, since all the components add in the same +ve and -ve direction , if the system to be in equilibrium one of the component has to have a negative direction that's what you get.
I think I now have it thanks you all.
