Why Does This Higher Order Derivative Equation Hold?
2 replies · 3K views · last reply
LauwranceGilbert
mod: moved from homework
Does anyone know why and when this equation holds? I have searched online but cannot find the reason or the rules for the higher order derivatives.
Equation: F^(4M+4)(x) = (F^(4M))^(4)(x) = (-4)^M F^(4)(x), with the fourth derivative of F^(4M) and a factor (-4) raised to the power M on the right.
  • Equation: F^(4M+4)(x) = (F^(4M))^(4)(x) = (-4)^M F^(4)(x), with the fourth derivative of F^(4M) and a factor (-4) raised to the power M on the right.
Can you provide some context of where you found this equation and what you were investigating?
It looks like ordinary power rules applied to derivatives ie derivative chain rule.
https://en.wikipedia.org/wiki/Chain_rule
There's a section further into the article talking about generalizations of the rule:
Higher derivatives[edit]
Faà di Bruno's formula generalizes the chain rule to higher derivatives. Assuming that y = f(u) and u = g(x), then the first few derivatives are:
\begin{aligned}{\frac {dy}{dx}}&={\frac {dy}{du}}{\frac {du}{dx}}\\[4pt]{\frac {d^{2}y}{dx^{2}}}&={\frac {d^{2}y}{du^{2}}}\left({\frac {du}{dx}}\right)^{2}+{\frac {dy}{du}}{\frac {d^{2}u}{dx^{2}}}\\[4pt]{\frac {d^{3}y}{dx^{3}}}&={\frac {d^{3}y}{du^{3}}}\left({\frac {du}{dx}}\right)^{3}+3\,{\frac {d^{2}y}{du^{2}}}{\frac {du}{dx}}{\frac {d^{2}u}{dx^{2}}}+{\frac {dy}{du}}{\frac {d^{3}u}{dx^{3}}}\\[4pt]{\frac {d^{4}y}{dx^{4}}}&={\frac {d^{4}y}{du^{4}}}\left({\frac {du}{dx}}\right)^{4}+6\,{\frac {d^{3}y}{du^{3}}}\left({\frac {du}{dx}}\right)^{2}{\frac {d^{2}u}{dx^{2}}}+{\frac {d^{2}y}{du^{2}}}\left(4\,{\frac {du}{dx}}{\frac {d^{3}u}{dx^{3}}}+3\,\left({\frac {d^{2}u}{dx^{2}}}\right)^{2}\right)+{\frac {dy}{du}}{\frac {d^{4}u}{dx^{4}}}.\end{aligned}
0058898334cbda9c51867b17ddeb752cca90ecc6
Here's a presentation where they use something like this for trig derivatives:
https://www.cs.drexel.edu/classes/Calculus/MATH121_Fall02/lecture14.pdf
The first equality is easy: the ##(4M+4)##th derivative of ##F## is just the 4th derivative of the ##(4M)##th derivative. The second equality is false, in general, because there are many counterexamples. The ##(4M+4)##th derivative is usually not a constant (##= (-4)^M## ) times the 4th derivative.
