MHB Why Doesn't the Limit of \(xe^{-\frac{1}{x}}\) Exist as \(x \to 0\)?
  • Thread starter Thread starter Vali
    Limit
The limit \( \lim_{x\rightarrow 0}xe^{-\frac{1}{x}} \) does not exist because the limits from the positive and negative sides of zero are not equal. Specifically, \( \lim_{x \to 0^+} xe^{-1/x} = 0 \) while \( \lim_{x \to 0^-} xe^{-1/x} = -\infty \). This discrepancy indicates that the overall limit cannot be defined. The discussion clarifies that the non-existence of \( \frac{1}{x} \) as \( x \) approaches zero is not the primary reason for the limit's non-existence. Therefore, the limit does not exist due to the differing behaviors from either side of zero.
Vali
Why the following limit doesn't exists ?
$$\lim_{x\rightarrow 0}xe^{-\frac{1}{x}}$$
I think it's because of $\frac{1}{x}$ which doesn't exists, right ?
the limits from both sides of zero are not equal
$\lim_{x \to 0^+} x \cdot e^{-1/x} = 0$
$\lim_{x \to 0^-} x \cdot e^{-1/x} = -\infty$
No. As skeeter said, it is because the limits "from below" and "from above" are not the same. If the problem were $$\lim_{x\rightarrow 0^+}xe^{-\frac{1}{x}}$$ it would still be true that "the limit, as x goes to 0, of $\frac{1}{x}$ does not exist" but as $-\frac{1}{x}$ goes to negative infinit, $e^{-\frac{1}{x}}$ goes to 0. $$\lim_{x\rightarrow 0^+}xe^{-\frac{1}{x}}= 0$$.
  • · Replies 29 ·
