Why doesn't the pressure inside a squeezed circle approach infinity?
7 replies · 4K views · last reply
dBrandon/dC
I was thinking about the pressure build up in a system that is squeezed equally from all sides (or at least in two dimensions, like squeezing a tube of toothpaste), and I ran into a conundrum. If the pressure increases as the area decreases, then the pressure inside a circle that's squeezed radially should approach infinity as we approach the center of the circle. I'm attaching a picture to illustrate this. View attachment Pressure Pic.bmp Consider the area as the circumference of the circle - the outside of the tube of toothpaste, for example. As I squeeze it with any force at all, doesn't the pressure (P = F/A) become greater and greater without limit as we consider smaller and smaller inner circles? When I squeeze the tube, why doesn't the lid burst off the toothpaste under billions of Pascals of pressure, or why doesn't a needle-thin stream of toothpaste spray out from the center when the lid's off? What's happening to prevent that? I understand that viscosity will try to limit this, but again, at the very center of the tube, shouldn't the pressure approach infinity?
How can you generate a pressure inside greater than the pressure at which you squeeze?
[edit] Err, wait, I see what you're saying and what the problem is: you've done 2d math on a 3d phenomena. If you cut the radius of a sphere in half, you decrease the volume and increase the pressure by a factor of 8, whereas the surface area decreases only by a factor of 4. So the force on the wall (and thus what you must apply to keep compressing it) has increased by a factor of two.
Multiplying pressure is nothing unusual. Pressure is equal to force divided by area. Reduce the area and you increase the pressure. Think of a hammer and nail. You apply, let's say, 10 pounds of force to the head of the nail, which has an area of, let's say, 1/10 of a square inch. That works out to a pressure of 100 pounds per square inch. The 10 pounds of force gets transferred to the tip of the nail, which has an area of, let's say, 1/1000 of a square inch. Thus, 10 pounds of force now generates a pressure of 10,000 pounds per square inch. The area was reduced by 100 times, which multiplied the pressure by 100 times. In this example, the pressure couldn't be multiplied by much more, because at a microscopic level, the tip of a nail is really quite blunt. It probably does end with a surface area of around 1/1000 inches squared. But in my original question, we could consider the area of the circle as it gets smaller and smaller without limit, and that's where I get confused.
pressure build up
Pressure is not something you can build up like money in the bank.
It disappears as soon as the applying agent is removed.
Nor does it increase just because you are considering a smaller area.
Pressure = Force/Area
One way to think of pressure is to think of it as a sort of distributed force, ie distributed over an area.
If you cut off (reduce) some of the area) you also remove the force that was distributed over it so the Force term in the equation is also reduced (in the same proportion) and the pressure remains constant.
Having said all that, your idea is worth something.
The rocks deep in the Earth are under tremendous pressure in three dimensions. This is called triaxial stress. It has great significance for the properties and physical behaviour of these rocks that geological science is just beginning to appreciate.
go well
If you cut off (reduce) some of the area) you also remove the force that was distrubuted over it so the Force term in the equation is also reduced (in the same proportion) and the pressure remains constant.
Force can change when you're applying a constant pressure. An example of this is the hydraulic lift. But you can also apply a constant force, which would mean pressure does change with the area. An example of this would be the pressure applied by your shoes as you stand on one foot or two - it's the same force (your mass times the gravitational acceleration), but half the area (one foot) results in twice the pressure. You can also focus a force onto a smaller area to multiply the pressure. The nail is a good example of this.
Mechanics just doesn't work like this.
You hit the nailhead with an impact of 10 lbs force.
It is this 10 lbs, not the force/area, that is transmitted to the point.
The timber offers a resistance of, say 9.5 lbs, so the resultant that move the nail forward is 0.5 lbs.
If this were not so the nail would not be driven in.
So the actual pressure at the point will be 0.5/point area.
Do not think that the pressure increases, just because the area decreases, you alwys have to consider the forces as well as the area.
If you have a tapered peg and hold the narrow end firmly against a solid plate and hit the wide end the pressure on the narrow end will indeed be greater than the impact pressure. If you hit it hard enough you will break either the plate or the peg.
That's what I said. "The 10 pounds of force gets transferred to the tip of the nail ..."
Sometimes it does. Again, consider your feet. If I weigh 75 kg, and gravity accelerates me at 9.8 m/s^2, I apply a force against the floor of 735 N. If each shoe has an area of 0.015 m^2, the pressure on the floor if I stand on two feet is 24,500 Pascals. If I sand on one foot, the force is the same, but since the area is cut in half, the pressure doubles to 49,000 Pascals.
So we're in agreement.
OK I finally understand your query and its resolution.
It is important to realize that the situation with the nail and my peg is not the same as the ever diminishing test circle you originally described.
The stress (pressure) in tapered peg as shown in my second sketch does indeed increase from section A to section B to section C.
This is because the whole of the applied force is transmitted across each section.
In the first sketch I have shown a limiting process taking ever smaller squares (squares are easier to work with than circles).
I have only shown two dimensions but the same principles apply in 3D.
The important point is that as we move from section A to B to C and select the smaller inner square, less force is transmitted across the section - or rather part section - which comprises the inner square.
I have shown this only on the y axis.
Fy is the total applied force to the outer square.
To calculate the stress we distribute it across the whole of section A, as shown by the line of small straight arrows.
At section B we select the middle square.
Fy is still distributed across the whole of section B, only part is now across our square.
I have shown the missing part as squiggly arrows and the active part as straight arrows as before.
At section C we are missing even more of the distribution of of Fy
At all sections the stress is the same.
Hope this helps
go well
  • Two-part diagram: a large square with downward arrows labelled F_y on top and sections A, B, C marked, nested smaller squares inside, and a tapered peg below with the same F_y and sections A, B, C.
