Why don't two double pendulum apparatus follow the same paths? / Chaos
  • Context: High School
  • Thread starter Thread starter John Mcrain
    Pendulum
39 replies · 5K views
John Mcrain
All double pendulum have same inital position, start from same height at same time, this softwear must have some equations from which calculate their path, so if both use same eqution and same inital position, why they have different paths(this is mathematicaly impossible)?
One question about chaos, if we know all inital positions is chaos indeed predictible repeater system?
In other words does chaos exist or this is just consequence of unknown intial position and not good enough math?
I think you have it right. The equations are completely deterministic. If all starting conditions and parameters are mathematically identical then the paths would be identical. They must be putting some subtle perturbation between the different trials.
Ah, if you read the description, they start the trials off at slightly different positions.
However, it wouldn’t take much of a difference to make the paths diverge. Chaotic systems are very sensitive to initial conditions and parameters. A tiny difference now causes two nearly identical scenarios to diverge some time in the future. The closer to identical, the longer it takes to diverge.
If you are predicting the path, you may know the exact equations, but your prediction is limited by how well you know the current state. The more complete and precise your information, the further into the future you can predict. That’s why weather forecasts are so much more reliable and predict so much further into the future than they used to: way more data, and much more precise data (well, that and better models made possible by faster computers)
John Mcrain said:
All double pendulum have same inital position, start from same height at same time, [...]
If you had read the caption on the video you posted, you would have seen that the initial conditions were only similar, not identical.
https://youtu.be/pEjZd-AvPco said:
This is a simulation of three double pendulums with massless rods and equally weighted ends, positioned horizontally to the right and with deviations from that by + and - 0.5 degrees.
Yes, it is well known that computer simulations run on ordinary deterministic computers will yield identical results every time they are run from identical input.
If I release double pendulum from 100% same haight and angle hunderd times, every single time path must be the same?
If this is case, than chaos dont exist in nature ,it is just consequence that we dont know well enough all inital conditions?
Because if we can predict something than this is not chaos...
No. Chaos can occur when solutions with arbitrarily close initial conditions diverge strongly. This is not a formal definition.
But chaos in not random, it is deterministic, it just appear to be random because we dont know initial conditons well enough?
That is not what defines a chaotic system.
It is not possible to prepare this situation (or pretty much any situation) with 100% accuracy. So this experiment can never be run.
Science is pretty much "don't care" on the results of experiments that can never be run.
Certainly the mathematical models, if run again with the same parameters, will produce the same results. In reality, who knows? As @jbriggs444 notes, we can't do that.
The point about chaotic versus non-chaotic systems is whether small changes in conditions (both initial conditions and environmental conditions through the run) produce only small changes in subsequent states or not.
Is chaos random or deterministic?
Is "random physics" just show that some information we are missing?
I think einstein dont believe something happen random
Neither. Chaos is the study of systems that show exponential divergence upon a change in the initial conditions or parameters.
In the classical sense, it is just a lack of information and computing power (we could never build a computer with infinite precision). However, since as far as we can tell nature has a fundamental randomness at the quantum level. Therefore, we will never be able to predict the future exactly.
I would be willing to bet that if Einstein lived today, with the advances that have taken place in quantum mechanics, he would recant that "God does not play dice."
DrClaude said:
Neither. Chaos is the study of systems that show exponential divergence upon a change in the initial conditions or parameters.In the classical sense, it is just a lack of information and computing power (we could never build a computer with infinite precision). However, since as far as we can tell nature has a fundamental randomness at the quantum level. Therefore, we will never be able to predict the future exactly.I would be willing to bet that if Einstein lived today, with the advances that have taken place in quantum mechanics, he would recant that "God does not play dice."
If random exist than free will must exist.
Not if you don't get to choose the random outcome :smile:
I would advise against taking this discussion into the realm of free will, because it will result in it being locked.
In deterministic world you cant get off from train that you are travel...from big bang to the future you are allways in this train.
And why are you bringing Einstein to all of this?
Because he is an attractor for physics conversations
John Mcrain said:
If I release double pendulum from 100% same haight and angle….
But you can’t. 99% the same, yes. Work on improving your technique and you might get it to 99.9% or 99.99% or 99.999%, or 99.9999% but you will never get to 100%.
So we should expect that in all such experiments we will eventually find divergence. How much will depend on how long we watch, how sensitive to initial conditions the setup is, and how good we are at coming close to recreating the same initial conditions.
The ordinary differential equations of classical dynamic systems have solutions and they are unique (setting aside the formal requirements on the ODEs). Chaos is a feature of dynamical systems that describes the relative behavior of two solutions to the equations that are close to each other. That's the end of the (simplified) story. The finite precision of computers is just a side issue that tells us even when we think we are solving differential equation for a time interval with the same initial conditions we end up solving for solutions that are close to each other at some time. Ergodic is something more than chaotic, and random has so many meanings that it is almost pointless to discuss in general.
EDIT: I see this thread is marked "B," so I think my response probably isn't helpful.
So is it ok to say that chaos is not random?
Random in nature is only at atomic level(quantum physics)?
Any answer to these questions is mostly going to be about what you mean by "random".
You are looking for a meaningful distinction between "If we could do this impossible thing we could calculate the result in advance" and "Nothing we can possibly do will allow us to calculate the result in advance".
The former is the randomness of classical chaos where the impossible thing is the 100% specification of the initial state, the latter is the randomness of quantum mechanics where even 100% knowledge of the state leaves us with random outcomes.
I'm not sure there is a meaningful distinction.
Chaos is the behaviour of many deterministic systems. The Maths does not 'fail' give it the same initial conditions and you will always get the same answer. A chaotic model maps nearby input states into a wide range of output states with no apparent relation to the input, in some ranges of the input states and often has ranges of input states that regularly map output states for other ranges.
If you take the double pendulum and calculate future displacements for small initial displacements, the future states map regularly and there is a smooth graph connecting the two. When the initial amplitude takes an element 'over the top', the output amplitude 'goes wild'.
Absolutely.
Deterministic
Yes
Here is the old Foxes and Rabbits chaotic behaviour.
A chaotic system (sensitivity to initial conditions, plus two other characteristics) is completely deterministic in the classical sense, yet generally unpredictable over time in the sense that no matter how precise you measure the initial condition, at some point the actual and predicted state of the system will diverge to be of the order of the phase space. This is so even if you calculate the predicted state with infinite precision after you measure it with finite precision.
So, while its not random it can be described to have some degree of unpredictability.
sophiecentaur said:
Cool demo.
You can have a population of negative rabbits, a population of negative foxes and even both! :oldbiggrin:
(But it stops being chaotic and degenerates to runaway growth of negative rabbits.)
Absolutely.
Deterministic
Yes
Thanks for strict answers...
It's the non-linearity showing itself. Inject a low level of noise into a linear system, the randomness you get out is just determined by the 'gain' of the system. Any level of noise, injected into chaotic systems will produce what I could call 'total unpredictability'. That's the practical view from an Engineer.
If we anylize fluid turbulence deep enough, atoms/molecules moves random so fluid turbulence must be also random system?
Indeed, non-linearity is a necessary (but not sufficient) condition for chaos since linear systems cannot exhibit sensitivity on initial conditions, topological mixing and dense periodic orbits all at the same time. However, system non-linearity in itself do not guarantee presence of any of the three characteristics, let alone all three. It can be non-trivial to determine if a non-linear system is chaotic or not, especially for systems that have simple period attractors for some parameter regions and strange attractors for other.
Thing about Chaotic variation is that it often has specific form with recognisable general patterns so there is often some predictability about future behaviour. So the randomness can be 'coloured' - not just white noise.
Atoms and molecules do no actually move randomly; they move quite deterministically, it only seems random to us.
