Why don't we "fly up" in an accelerating elevator?
  • Context: Undergrad
  • Thread starter Thread starter ago01
    Accelerating Elevator
The discussion revolves around the physical concepts related to the forces experienced by a person in an accelerating elevator, particularly focusing on the normal force, perceived weight, and the implications of acceleration on motion. Participants explore the relationship between normal force and gravitational force in various scenarios, including the effects of sudden stops and the dynamics of objects in non-inertial frames of reference.
  • One participant notes that when an elevator accelerates upwards, the normal force exceeds gravitational force, leading to a perceived increase in weight.
  • Another participant suggests that if the elevator were to suddenly stop, the person would continue moving upwards due to inertia, akin to projectile motion.
  • Some participants argue that the normal force is responsible for providing acceleration, and that if the elevator accelerates at a rate greater than gravity, objects would indeed "fly up" towards the ceiling.
  • There is a discussion about the implications of normal force and gravitational force, with one participant asserting that an imbalance would lead to falling through or bouncing off a surface, while others challenge this view.
  • One participant introduces the concept of fictitious forces in non-inertial frames, stating that in the elevator's frame, the normal force can be expressed as N=mg', where g' includes the elevator's acceleration.
  • Another example is provided regarding the "vomit comet," illustrating similar principles in a different context.
Participants express differing views on the implications of normal force and gravitational force, particularly regarding scenarios of acceleration and sudden stops. There is no consensus on the interpretation of these forces and their effects on motion.
Some discussions involve assumptions about the nature of forces and the conditions under which they apply, such as the role of elasticity and the effects of acceleration exceeding gravitational force. These assumptions remain unresolved within the discussion.
ago01
Earlier I was doing a sample problem for class that involved the work done by an elevator, and the problem gave us the normal force experienced by the person in the elevator (to calculate the acceleration of the elevator-person system).
I had done this wrong because I had wrongly assumed because the person isn't leaving the floor of the elevator that the net force from N and gravity must balance. After doing the calculations, it was clear N > mg, so there is an acceleration.
Mathematically I can work this out and if I had to regurgitate something on an exam I could do it just from the force diagrams. But I am wondering what the physical manifestation is.
What (I think) I do understand is the concept of the perceived weight of the person. If we stand them on a scale while the elevator is accelerating upwards, they feel heavier. If we do the same as the elevator is slowing down (or going down) they feel lighter. This is also consistent with my experiences. I suppose the problem I'm having is that if there is an imbalance between a surface and the normal force I had this idea that the object would simply fall through that surface (if N < mg) or "bounce" off the surface (if N > mg) and the only reason an object is ever held stationary on a surface is because the normal force exactly balances the gravitational force. This was reinforced by problems that, for example, drop a ball off a cliff. There's no normal force, so the downward acceleration is provided entirely by the gravitational force and the object falls. Or alternatively, a sliding block where it's not leaving the surface because N = mg.
In this elevator though the person isn't being "launched" up as the elevator accelerates. At least this hasn't been my personal experience and I've survived many elevator rides. Also, N > mg. So it seems to me that when moving vertically with a surface the normal force is the force providing the acceleration and no extra forces are required. Then, it would also seem that if I hit a ball with a paddle it's the normal force of the paddle's surface providing the acceleration to the ball at the time of impact (even though we would likely just simply treat this as another force). Is this the right idea?
We could "fly up" if the elevator accelerates our bodies and then slow down or stop, just like the paddle does respect to the ball.
We could "sink through the floor" if the elevator allows us to fall and then slow down or stop, if that floor were not a solid surface.
So I suppose then as long as the surface is moving at the same acceleration relative to us we will move with that surface and the normal force provides the acceleration. Your explanation also makes sense, if the elevator suddenly stopped the person in the elevator would keep going due to the larger normal force that was imposed on it the instant before it stopped.
If the elevator suddenly stopped, the person would keep moving by Newton's first law. They would be in projectile motion under gravity until they hit the ceiling of the elevator.
I don't understand your ideas about normal forces. A bat hitting a ball projects the ball because the bat accelerated to a significant non-zero velocity before impact. An elevator starts accelerating those inside it as soon as it starts moving, so there is no sudden impact, but a common acceleration.
It is exactly the opposite:
  • If ##N > mg##, and ##m## doesn't move, either the surface is breaking apart and ##m## is going through it (feeling like "falling" through it), or ##m## is deforming or breaking apart;
  • IF ##N < mg##, and ##m## doesn't move, it feels the same as if the surface didn't move and ##m## was "bouncing" upward.
Then Newton's second law is being violated.
Not if elasticity is involved, or something breaks.
If net force is non-zero and acceleration is zero, that's a problem.
If the elevator's acceleration exceeds ##g## then indeed objects inside will fly up towards the ceiling, however below ##g## objects inside are still bound to the floor of the elevator by gravity.
In the stationary ground frame of reference, both the elevator and the man have the same acceleration, and there is no relative acceleration between them. In the non-inertail frame of reference of the elevator, neither the man nor the elevator appears to be accelerating, but there is an additional fictitious gravitational acceleration (and force) on both of them, but again no relative acceleration. So, in the non-inertail frame of reference of the elevator, the total normal force on the man is N=mg', where g' = g + a.
Another example would be the vomit comet:
  • · Replies 22 ·
  • · Replies 25 ·
  • · Replies 38 ·
  • · Replies 51 ·
  • · Replies 29 ·
