Why don't we heat homes using air conditioners?
  • Context: Undergrad
  • Thread starter Thread starter Jocko Homo
    Air Heat
72 replies · 9K views
russ_watters said:
Exactly!
[...although actually it does move an "object": the refrigerant. It's just that we don't care about the mechanical work being done to move the refrigerant.]
"It's just that we don't care about the mechanical work being done to move the refrigerant"
Really? Why not.
on Phys.org
pallidin said:
Turtle, I'm losing something here{not from you}
An electrical space heater is FAR MORE EFFECTIVE than a reverse air-conditoner.
If the reverse air-conditioner has a COP of 3.5, then the reverse air-conditioner is far more effective. 3.5 times more effective, in fact.
The most effective heating system I've seen to date is a heat pump where the coils are buried underground. This is because it takes more energy to move a BTU from a cold place into the house than from a warmer place.
An electric space heater is 100% efficient but the measure is how much heat you deliver to the house for a given watt of input power. (By this measure, an electric conveyor delivering chopped wood into a fireplace if far better still.)
TurtleMeister said:
So the heat pump operation is similar to physically moving an object from one place to another? Except in this case the "thing being moved" is not an object, but rather it is heat energy?
Yes. I like to use the train analogy. Imagine a train bringing coal to an electrical power plant. The energy contained in the coal is far, far greater than the energy that the train used to bring it. Yet, we don't say that the train is 100000% efficient, because it didn't create the coal...it simply moved it.
The heat pump performs the same function as the train. The energy is there, it simply brings it to where we want it.
Edit: an electric conveyor delivering chopped wood is yet another example :)
Really? Why not.
Cause it's just a fluid going around in a circle.
Good analogy.
I've come up with a thought experiment that has helped me understand the difference between the electric heater and the heat pump. Imagine two rooms, room A and room B, separated by an insulated wall. Both rooms are also insulated from the outside. There is a heat pump in the wall that separates the two rooms. Initially, both rooms have the same temperature.
Now, we want to increase the temperature in room A. So we turn on the heat pump. As the temperature increases in room A, it decreases in room B. But as the temperature difference increases we find that the average temperature of both rooms remains the same. So the electrical energy used by the heat pump is NOT being converted into heat energy.
However, if we have the same setup, except this time we use a space heater to heat room A, we find that as the temperature increases in room A, the temperature in room B remains the same. The average temperature of both rooms increases. So the electrical energy being used by the space heater IS being converted to heat energy.
TurtleMeister said:
Good analogy.
Well, almost...
The energy used by the heat pump will indeed go into heat energy, and the average temperature of both rooms will increase. However, the average temperature of both rooms will increase much less for a given delta t in the room being heated than it would with a resistive heater.
cjl said:
Well, almost...
Yes, that is true. But the nice thing about thought experiments is that you can imagine such things as "perfect heat pumps". And the point of the thought experiment was to show the main difference between heat pumps and space heaters. Another reality of heat pumps, that I haven't quite figured out yet, is that the greater the difference in temperature (between room A and room B) the less effective the heat pump becomes. Eventually you will reach a temperature difference where the space heater becomes more effective than the heat pump. Does it have anything to do with the refrigerant, and the temperature difference between the evaporator and condenser coils?
The difference in temperature is the equivalent of asking the train with the coal to go up a hill. The greater the temperature difference, the higher the hill. Eventually you get to the point where you're just better off screwing the train and digging for coal on the spot, or exploring other options.
I didn't think you could have a refrigeration cycle with strictly a fluid. Should this be; "Cause it's just a fluid/gas going around in a circle." ?
I suppose a radiator/cooling system in a car is strictly fluid. But I don't think they refer to them as refrigeration units, even though they remove heat.
hmm... http://en.wikipedia.org/wiki/Refrigeration" ?:
Refrigeration is a process in which work is done to remove heat from one location to another.
Bah!
That means I'm a refrigerator...
The car radiator is convective cooling only. In my book, to be heat pump you'd have to involve a thermodynamic cycle resembling Carnot. Unlike a radiator, such a thing can move heat from a colder into a warmer area.
Not according to the all knowing, all seeing wiki:
http://en.wikipedia.org/wiki/Convection" is the movement of molecules within fluids (i.e. liquids, gases) and rheids. It cannot take place in solids, since neither bulk current flows nor significant diffusion can take place in solids.
bolding mine
I don't know what planet you are from, but all of the automotive radiators* on my planet are solid.
*mostly made out of either copper or aluminum. both very good thermal conductors.
Note the definition of "fluid" in your next post... :wink:
A car radiator utilizes both conduction and convection: Conduction is what transfers energy to/from the two fluids and the radiator and convection which mixes/equalizes temperature inside the fluid due to turbulence.
bolding mine
I meant the heart of the radiator system of course which is a circulating convective fluid loop.
Gads!
I stand corrected. :redface:
First off, even a perfect heat pump/air conditioner actually requires some energy, and will add that to the heat leaving the hot side. The amount of energy added to the warmer room per unit of energy used by an ideal heat pump is equal to the (absolute) temperature on the warm side divided by the difference in temperature between the warm and the cold side. This also shows that as the temperature difference increases, the maximum efficiency goes down.
As for why the pump becomes less effective (physically) with larger temperature differences? You're pretty much right about it being the temperature difference between the evaporator and condenser coils. To maintain a larger temperature difference between evaporator and condenser, the pressure difference between the two must be increased, which means that the compressor must work harder.
Another good analogy Lsos.
I'm thinking now that it's not just the temperature difference, but also the temperature of the cold side. The colder it is, the less heat energy there is to move. Which makes it more difficult. Similar to pulling a vacuum.
Edit:
On second thought, the vacuum analogy is probably not right. However, having less heat energy available to move may still have an effect on the effectiveness of the heat pump.
Stop already.
A purely resisitive heating element is far more efficient than a two-stage mechanism.
A 1000 watt air conditioner in reverse is LESS able to produce useful heat as a 1000 watt resistive space heater.
Not to mention the fact that you don't have to have part of the resistive heater outdoors.
pallidin said:
Stop already.
Nope, nope, nope. Read the specs on any heat pump.
[though I don't know what you mean by a "two-stage mechanism".]
Try this one: http://www.residential.carrier.com/products/acheatpumps/heatpumps/performance.shtml
It has a cooling SEER of 16.5 and a heating HSPF of 9.5. That means:
In heating mode, it produces 2.8 watts of heat for every watt of input power.
In cooling mode, it produces 4.8 watts of "cool" for every watt of input power.
Maybe you're right. However, an air conditioner in reverse doesn't PRODUCE heat, it merely MOVES it. And if your goal is to have a warm home, in a lot of cases it reaches this goal far more effectively.
OK, that's my contention!
Doesn't it take MORE energy to "move" heat than to simply produce it outright??
(In a winter condition that is)
Come on guys, anyone that knows me knows I respect PF and am very rarely argumentative.
But this whole idea seems intuitively ludicrous.
Or maybe I'm just brain dead.
@Russ: the "two-stage mechanism" I was referring to is with regards to the fact that a compressor is used.
I really must be missing something 'cause there's something that seems totally obvious to me but every seems to keep missing it...
The heat pump can't be less efficient (loosely defined) than the "resisitive heater" because heat is the necessary by-product of the heat pump (aside from the noise, I guess, but I think the energy in that is trivial)...
For example, let's compare a heat pump using 1000 W of energy to a resistive heater using the same amount of energy. Obviously the resistive heater is going to produce 1000 W of heat energy. However, the heat pump will also produce that much heat energy (as its waste by-product, otherwise heat pumps can be perfectly efficient) plus whatever heat it was pumping from whatever reservoir it was connected to. Therefore, the heat pump can't be any worse than the resistive heater, hence my originating post...
Why aren't all electrically heated homes using heat pumps?
OK...
Envision two "igloo's" in Antartica, one has a 1500 watt reverse air-conditioner mounted in a window, the other igloo has a 1500 watt resistive space heater on the floor.
I would bet my next paycheck that the resistive heater will warm my igloo much, much better.
pallidin said:
OK...
Without insult, that is a vacuous answer!
Never mind that your example didn't even necessitate the Antarctic homes being "igloos," it's a naked appeal to common sense. However, since I've never actually heated my home using my air conditioner, my common sense isn't worth very much in this scenario. I didn't ask whether you would heat your home with an air conditioner, I asked why don't you? In other words, why doesn't the heat pump heat as well as a resistive heater?
Incidentally, you may need to prepare to give up your next pay cheque!
A resistive heater (or a resistive infrared heater) is the most efficient electrically heat producing product on earth. Nothing else even comes close. Using electricity that is.
pallidin said:
OK...
You would most definitely lose that bet.
Consider this analogy: which system will provide more heat for your house:
1. A 1000w resistive heater.
2. A 1000w pump bringing a gallon of oil per minute to your furnace, where it is burned.
We are talking about reverse air-conditioners and their comparability to a resistive space heater.
Do you understand the concept of an analogy? The purpose of this one is for you to make sure you recognize that situations exist where you can get more heat out than the electrical energy you put in. So far you haven't been trying to learn how a heat pump works but instead have been arguing based on COE.
I fully understand that, russ, but that scenario is a "special circumstance"
Much like my "igloo example" is a special circumstance.
ANY heat pump specifically relies on environmental conditions; resistive heating does not.
Okay pallidin... If you're so sure of your conclusion then please point out the flaw in the reasoning I stated earlier:
If you can't spot the flaw in this logic then you should consider why it is...
