Why is 0 K unattainable?
  • Context: Graduate
  • Thread starter Thread starter Kakashi
Kakashi
At constant pressure we have:
$$ dq_{p}=dH=C_{p} dT $$ which implies
The enthalpy change dH reflects the increase in internal energy associated with molecular motions such as rotational and vibrational modes. The atoms, molecules or ions that compose a system can undergo several types of motion including translation, rotation, and vibration. The greater the motion (the higher the temperature), the greater the number of possible microstates and therefore the higher the entropy. A perfectly ordered system with only a single microstate would have 0 entropy. The only system that meets this criteria is a perfect crystal at 0 K in which each component is fixed in place within a crystal lattice and exhibits no motion.
Near absolute zero, the heat capacity approaches zero:
$$ Cp \to 0 $$ as $$ T→0 $$
$$ dT = \frac{dq_{p}}{C_{p}} $$
Because it is impossible to perfectly isolate a system from its surroundings (dq_{p} =/0) (for example due to radiation from the environment), there will always be some small heat transfer. Therefore it seems impossible to keep a system exactly at T=0. Is this reasoning correct for explaining why absolute zero is unattainable?
Science news on Phys.org
I'd guess Heisenberg's uncertainty principle would disallow it? At least in theory. As for in practice...?
Proof of the Nernst heat theorem
The Nernst heat theorem is probed from purely thermodynamic arguments connected with the second law of thermodynamics, and alien to the vanishing of the specific heats, or to the unattainability of the zeroth isotherm. If the proof is accepted the second law of thermodynamics would extend its applicability and the third postulate of thermodynamics would be narrowed to the fact that the entropy of a finite-density, chemically homogeneous body must not be negative.
EDIT: I may have over-estimated the amount of time this question sat unanswered. I'm glad some real competence is getting involved. Looking forward to more....
I was hoping one of the PF QM experts would catch this one. But let me take a whack at it.
The actual refrigeration techniques are described in this wiki article on laser cooling.
Of course, once refrigerated, the atoms will tend to warm up for reasons explained in the OP.
Regarding QM effects, you can have a population of atoms at the lowest possible quantum state.
This is described in the Bose-Einstein condensate wiki article.
Your entire sample will not be at 0K, but an arbitrarily high portion of those atoms can be.
(See correction here.)
This doesn't make sense; temperature is not a property of individual atoms. It's a property of the system. For example, see here (the NIST site is relevant because they set the SI standard definition of the Kelvin, which requires assessing the various techniques for measuring temperature and cooling things towards 0 K):
https://www.nist.gov/si-redefinition/kelvin/kelvin-thermodynamic-temperature
I've seen that heuristic argument (though not in actual peer-reviewed literature), but I don' think it's correct. The uncertainty principle does not disallow a quantum system from being in its ground state. And since the ground state is an eigenstate of a Hermitian operator (it's the lowest energy eigenstate of the Hamiltonian), the uncertainty principle does not disallow an exact measurement of a system being in its ground state.
It looks reasonable to me, but I'm not sure if this argument appears in the form you give it in the literature. For example, it doesn't look to me like this argument appears in the paper on the Nernst Theorem that was referenced earlier in the thread.
Per my previous comment on this, I don't think it makes sense to describe this in terms of temperature.
I think a fair description in quantum terms would be that not all atoms in the BEC will be in the actual ground state; there will still be some distribution of states. (Perhaps a more accurate description would be that the quantum state of the condensate as a whole is a weighted superposition of multiple energy eigenstates.) But that very fact means that the condensate, as a thermodynamic system, is not at 0 K; it's at some finite positive temperature, because its average energy per atom is higher than the exact ground state energy.
The 3rd law of thermodynamics, that zero temperature cannot be attained, cannot be derived within thermodynamics itself. For that, one needs statistical physics. In thermal equilibrium the probability is given by the density ##\rho\propto e^{-\beta H}##. In classical physics it is a function (in phase space), while in quantum physics it is an operator (in Hilbert space). In any case, at zero temperature only states with zero energy are allowed. The set of states with zero energy has a measure zero, that is, the ratio between the number of zero energy states and the number of all states is zero. Hence the prior probability of the state of zero temperature is zero, which makes it statistically impossible. Q.E.D.
Note that the above is not a standard explanation of the 3rd law. It's my own explanation, which perhaps could be interpreted as some kind of a generalized 3rd law.
That's kind of why I qualified it with being theoretical. It doesn't sound like like the practical explanation. So I hit on a thermodynamic explanation (apt as we're in the the thermodynamic forum). I initially considered something involving Maxwell's Demon, but Nernst's Heat Theorem sounded more right. Then again, you know I'm often in over my head. My little excursions always teaches me something though. But as I also wrote I kind of jumped the shark.
A minor point which doesn't affect your main argument: I don't think the energy has to be zero at zero temperature, it just has to be the lowest possible energy. In classical physics I think that would be zero, but in QM I don't think it has to be--it just has to be the lowest eigenvalue of the Hamiltonian, which could be nonzero.
You are right. If the lowest possible energy is positive, then the factor ##e^{-\beta H}## vanishes at zero temperature even for the lowest possible energy. However, the density ##\rho## is only proportional to it, not equal to it. The full ##\rho## contains an additional temperature dependent normalization constant, and this constant makes ##\rho## non-vanishing at zero temperature even when the lowest possible energy is positive. Explicitly, in the quantum case, the full ##\rho## is
$$\rho = \frac{e^{-\beta H}}{{\rm Tr}\,e^{-\beta H}}$$
If the 3rd law is stated as "the zero temperature cannot be attained", I agree: it is trivially related to the fact that the "laws" are principles, taken from experience, that we want to consider as the starting point from which all the consequences of Thermodynamics can be obtained.
However, the 3rd law can be stated with different words. In such a case, the equivalence of the two statements is within Thermodynamics.
This is not a valid proof. The total number of states of a mechanical system is always infinite, and (classically) the set of states at any fixed value of energy is a zero-measure set in the phase space. Therefore, the probability of each state with a finite multiplicity (not only the ground state) would be zero.
Moreover (and more fundamentally), there could be no proof of the attainability of absolute zero (in Thermodynamics or in Statistical Mechanics) based only on the ground state properties or probability. The claim is that it is not possible to *reach* the absolute zero in a finite number of steps, starting from a finite temperature. This is something calling for some property of the systems in the neighborhood of, and not only at, absolute zero.
You are right that any state with definite energy has zero probability in that sense. But there is nothing wrong with that conclusion. We are talking about thermal equilibrium, i.e. thermal states in a canonical ensemble, while states with definite non-zero energy are not thermal states, so in this context they are impossible states. Of course, it does not mean that a system cannot have a definite energy, but it means that prior probability of any given definite energy is zero. Just like the prior probability that a real number in the interval [0,1] is exactly equal to 0.3421678 is zero, but it doesn't mean that a real number cannot be equal to 0.3421678.
Demystifier said:
... states with definite non-zero energy are not thermal states, so in this context they are impossible states.
Do you mean at T=0 K? In such a case, I agree. But this just says that the only possible state of a system in equilibrium with a thermostat at 0 K is the ground state. It has nothing to do with the possibility of cooling a system to absolute zero. At any other temperature, all the available microscopic states are possible, with a finite probability, in the canonical ensemble.
If the Hamiltonian has a continuous spectrum, then, in the canonical ensemble with non-zero temperature, any given energy has non-zero probability density, but zero probability.
  • · Replies 39 ·
