Why is blackbody radiation continuous?
Blackbody radiation is continuous due to the thermal equilibrium of electromagnetic fields within a cavity at temperature T, where the cavity dimensions exceed the wavelengths involved. Real objects approximate blackbody spectra, but isolated systems exhibit well-defined energy levels. In gases, Doppler and collision broadening affect the emission spectrum, while in solids, energy levels merge into bands, allowing for continuous emission. Materials like carbon nanotubes approximate blackbody behavior despite finite sizes and energy levels.
  • Understanding of blackbody radiation principles
  • Knowledge of thermal equilibrium concepts
  • Familiarity with Doppler and collision broadening effects
  • Basic principles of solid-state physics regarding energy bands
  • Research the principles of blackbody radiation in detail
  • Explore the effects of Doppler broadening in gases
  • Study the characteristics of energy bands in solids
  • Investigate the behavior of micro- and nano-cavities in relation to blackbody radiation
Physicists, materials scientists, and engineers interested in thermal radiation, blackbody behavior, and the properties of materials like carbon nanotubes.
TheCanadian
Plasmas can emit radiation based on the acceleration of charged particles (which we generally consider as continuous), but for un-ionized matter compounds, transitions are quantized and photons have particular energies. At room temperature, collisional excitations are typically dominant. But if that is the case, what about blackbodies permits continuous spectra at all wavelengths? Why do certain materials (e.g. carbon nanotube structures) approximate well this behaviour despite being finite in size and available energy levels? Why do we not discuss/observe blackbody emissions as having discrete energies?
Science news on Phys.org
First, a blackbody is an idealisation. Real objects only approximate a blackbody spectrum; see for instance the spectrum of the sun: https://i.stack.imgur.com/tc0Mq.png
Second, only isolated systems can be seen has having well-defined energy levels. For a gas, you have to consider in particular Doppler broadening and collision broadening. In solids, the constituent atoms loose their individual character and energy levels become energy bands.
I have a slightly different answer than Dr. Claude: When an electromagnetic field within a cavity is at thermal equilibrium (at some temperature T), the spectrum is named 'blackbody radiation'. The spectrum is continuous because in the thermodynamic limit, the cavity dimensions are much larger than wavelengths. Micro- and nano-cavities do not exhibit the usual blackbody spectrum:
https://www.osapublishing.org/abstract.cfm?uri=QELS-1995-QTuG19
https://www.ncbi.nlm.nih.gov/pubmed/17358533
https://www.osapublishing.org/abstract.cfm?uri=QELS-2003-QWA25
  • · Replies 29 ·
  • · Replies 19 ·
18K
