Determine x and y coordinates of resultant force through object
The discussion focuses on determining the x and y coordinates of the resultant force acting on a concrete slab subjected to multiple vertical loads. The resultant force, calculated as Rz = -212 kN, indicates a net downward force. Moments about the x-axis and y-axis were computed, yielding Mx = -1027.1 kNm and My = 552.4 kNm, respectively. The final coordinates of the resultant force were determined to be x = -2.60566 and y = 4.8448.
  • Understanding of static equilibrium and resultant forces
  • Knowledge of moment calculations in mechanics
  • Familiarity with coordinate systems in structural analysis
  • Proficiency in basic algebra for solving equations
  • Study the principles of static equilibrium in structural engineering
  • Learn about calculating moments in two-dimensional systems
  • Explore the application of coordinate systems in force analysis
  • Review examples of resultant force calculations in engineering problems
Students and professionals in civil engineering, structural analysis, and mechanics who are involved in calculating forces and moments on structures.
Northbysouth
The concrete slab supports the six vertical loads shown. Determine the x- and y-coordinates of the point on the slab through with the resultant of the loading system passes.
Image attached
I started off by finding the resultant force. Seeing as how all the forces in the system act in only the z direction I summed them to get:
Rz = 69Kn - 69kN -42kN - 44kN - 67kN - 59kN
= -212 kN
But I'm not sure how I should proceed from this step. I would appreciate any suggestions.
Hi Northbysouth! :smile:
Assume that it goes through the position (x,y).
You know it's -212 kN, so what is the moment of that about the x-axis or the y-axis? :wink:
I've managed to solve it now. I did the following:
Rz = -212 kN
Mx = (69kN)(2.3) -(67kN)(3.1+2.3) -(44)(8) -59*(2.3+3.1+2.6)
= -1027. kNm
My = 67*2.3 + 44*6.7 + 69*6.7 -69*5.2
= 552.4 kNm
Mz = 0
M = 1166.224 kNm
Rz*y = -1027.1
y = 4.8448
Rzx = 552.4
x = -2.60566
Thanks for your help.
  • · Replies 22 ·
11K
  • · Replies 40 ·
